![]() ![]() ![]() ![]() Join Date: May 2007
Member: 503334 Status: Online Thanks: 5
I HAVE ZTC ZT303.
PHONE 100% PROCCES THEN OFF. I DONE FLASHING & FFS FORMAT. BUT PHONE NOT NORMAL ON PLEASE HELP ME ![]() ![]() ![]() :confuse d:![]() ![]() ![]() :confuse d:
![]() ![]() ![]() ![]() Join Date: Apr 2006
Member: 264597 Status: Offline Thanks: 0
you must read full flash from other hand that good hardware then write to it and after flashing if the phone not working make ask\rpl the phone must be worked if the phone not working after ask\rpl check hardware
you must read full flash from other hand (ZT303) that good hardware then write to it and after flashing if the phone not working make ask\rpl the phone must be worked if the phone not working after ask\rpl check hardware
#4 | |
Device: Autodetect 6228 NAND Checking data, wait... Action: write NAND flash "format ffs" active write: Firmware skip: Customization skip: Language Pack skip: Eeprom protocol ver: 04 ver. sw1: U6_PCB04_GPRS_MT6228_S02.U6V10B015.BIN ver. sw2: U6V10B015 id-page Ok nfi area detection finished: Ok Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6228:8A02:8A02]... chip-id: 0000:0101 boot step size: 0400 Release Power button now ! Boot Done Initialize... version: 3.1 NAND: Hynix HY27XS08121M 512+16 32 pages, 66Mb NAND id: AD76AD76 page size: 200+10 pages/block: 20 bits i/o: 08 address cycles: 04 blocks: 1000 ram size: 00800000 NOR: 0000:000000000000 [00000000] NAND: 00AD:007600AD0076 [04200000] warning: NOR flash chip not supported or not detected Initialize Done Set baud... 921600 Set baud Done Identification... converting data... done protocol ver: 04 ver. sw1: U6_PCB04_GPRS_MT6228_S02.U6V10B19.BIN ver. sw2: U6V10B19 ffs offset/size: 01700000/02900000 id-page Ok nfi area detection finished: Ok structure: 2nd [standard] (or higher) generation Identification Done Manipulation... Manipulation Done Finalization... Finalization Done Write... write core area 1 of 2... write core area 2 of 2... formatting... Write Done Finished, time used: 296 sec Remove/Install battery now ! SAME PROBLUM BRO PLS HELP ME |
I Have Got Five Pcs For Same Problum
![]() ![]() ![]() ![]() ![]() Join Date: Oct 2005
Member: 187451 Status: Offline Thanks: 7
You guys face this problem coz u dont read its full flash before formatting ffs and writing another firmware.now check with charged bettery.it will take 1 minute to power on.dotn use power supply.
Member: 130995 Status: Offline Thanks: 4,396
@KASAM
here is detailed instruction, please, follow it step-by-step: http://forum.gsmhosting.com/vbb/showthread.php?t=447277 |
![]() ![]() ![]() Join Date: Jun 2005
Member: 154627 Status: Offline Thanks: 4
I Need Pinout For Zt303(ztc)
Please Help Me
I Need Pinout Cable For Zt303 |
Member: 42408 Status: Offline Thanks: 1
cannot find the similiar firmware....
phone:ZTC-ZT303 protocol ver: 04 ver. sw1: U6_PCB04_GPRS_MT6228_S02.U6V10B28.BIN ver. sw2: U6V10B28 what firmware can i write to this phone???? thnaks |
#11 | |
you can find similar firmware in support area: flashfiles\ChineseMiracle\_MT6228 please, before you flash your phone, make "read firmware" procedure before flashing and send backup_flash and backup_system_log files to InfinityBoxSupport@gmail.com |
my phone loading 100 % then off....
try all the step but still same problem.... -full back up -format ffs safe and complete -then write U6_PCB04_GPRS_MT6228_S02[1].U6V10B21__En_Fr_Es_Indonesia_Vn_Ru_Th_Cn.B4M.bin - after that phone still loading 100% then off please maybe another solution???? |
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2006
Member: 222009 Status: Offline Sonork: 100.1576751
ZTC 313 pinout need...............
#14 | |
Member: 44031 Status: Offline Thanks: 6
even i am looking for the same file there are other files in the support area. but they do not end with no. 28 ie: U6V10B28.BIN. can the files currently present in the support area ie: 15, 18, 20, ...... be used insted. |
![]() ![]() ![]() Join Date: May 2005
Member: 148515 Status: Offline Thanks: 332
hello!
make full backup of your existing firmware and then is safe to try 15, 18, 20. if they will not work properly- you can always return phone to original state by writing back your backup |
