Chinese Cocktail All info about all chinese phones supported by Multi-box and Multi-box LITE is here. Please use this section for talks about china made phones |
09-28-2007, 17:10 | #1 (permalink) |
Freak Poster Join Date: Mar 2004 Age: 47
Member: 58704 Status: Offline Sonork: 100.1618753 Thanks Meter: 43 | multi-box how to fine chinese miracle |
09-28-2007, 19:58 | #2 (permalink) |
No Life Poster Join Date: Mar 2001 Age: 44
Member: 3610 Status: Offline Sonork: 100.54638 Thanks Meter: 1,652 | Manual for finding Chinese phones pinouts ( tested on NOKIA 7300 ) 1. At first, you need to find GND signal (3pin-00.2v) 2. The second step: you need to find Tx Rx signals. Choose the pinouts, that may probably suit. You have 12 pinouts: 1pin-0.00v - this pinout is wrong 2pin-2.78 - it may correspond to Tx Rx signals 3pin-00.2v - GND signal 4pin-2.75v - it may correspond to Tx Rx signals 5pin-1.09v - LOOKS LIKE Tx Rx signals, BUT IT IS NOT! 6pin-0.00v - this pinout is wrong 7pin-4.02v - this pinout is wrong 8pin-2.89v - it may correspond to Tx Rx signals 9pin-3.05v - this pinout is wrong 10pin-0.00v - this pinout is wrong 11pin-1.09v - it may correspond to Tx Rx signals 12pin-0.02v - YOU DON'T NEED these fake signals with high and low voltage 3. In order to find Tx you need to put multimeter to test, diod ( "+" and "-" = beep ). When the phone is POWERED ON, Tx with GND make a sound beep. When it is TURNED OFF, it shows 600-700 ohm. It is suggested to do all the job using wire connection. After following the above mentioned steps you'll find, that 2pin is Tx and 8pin is Rx. Tx has to be 1.7v or 2.7v and Rx - 1.8v or 2.8v. These characteristics may change depending on the processor parameters. But Tx and Rx is not the same. Tx can be 2.78v, 2.75v, 2.7v. |
09-28-2007, 22:21 | #3 (permalink) |
No Life Poster Join Date: Mar 2005 Location: Facebook: Java John Age: 43
Member: 122246 Status: Offline Sonork: 100.50000 Thanks Meter: 4,993 | and in some pcb u can check at front side or back side some small golden points near that points u will find directly written Rx ,Tx, Gnd |
10-03-2007, 15:19 | #5 (permalink) |
Insane Poster Join Date: Dec 2003 Location: Nowshera KPK Pakistan
Member: 46549 Status: Offline Thanks Meter: 6 | بسم اللہ الرحمن الرحیم السلام علیم To day i have tried to connect a cect n95 but failed because the information give on support side in incorrect for n95 they have showed 2x6 mini connector while the set have 2x5 so at last i connect the phone to box waiting for powr on connecting ok then reset your box ............. |
10-03-2007, 15:24 | #6 (permalink) | |
Member: 3610 Status: Offline Sonork: 100.54638 Thanks Meter: 1,652 | Quote:
11-07-2007, 10:48 | #8 (permalink) |
Product Manager Join Date: Jan 2006 Location: 亚洲 / Asia Age: 36
Member: 222198 Status: Offline Sonork: 100.102981 Thanks Meter: 3,813 | Did u find it on support? If its not available then post number 2 is helpful for u. B.R., Viru Last edited by viru; 11-07-2007 at 12:16. |
11-07-2007, 11:43 | #9 (permalink) | |
01-18-2010, 10:21 | #11 (permalink) |
Junior Member Join Date: Oct 2008 Location: WEST BENGA, INDIA
Member: 876561 Status: Offline Thanks Meter: 3 | Not found PINOUT & FIRMWARE for Bluetooth FM N958; MCU:E559_JJF3F8F.V60.01.4_25S00; BB CHIP:MT6225, E03; MS Board:EVEN25_HW On connecting Log: Power on...OK, reading booting info; Box communication timeout, reset box... I have two same phones one working one not working but failed to connect both. Also unable to backup firmware from working phone.[IMG][IMG][/IMG][/IMG] PlZ Help |
01-31-2010, 20:14 | #14 (permalink) |
Member: 876561 Status: Offline Thanks Meter: 3 | Sorry for including url in a wrong way Chinese miracle 9.4 => Phone setting used Model:Autodetect, MT5219-B..6226 Based connected to special input of multibox Lite Phone Details:Bluetooth FM N958; MCU:E559_JJF3F8F.V60.01.4_25S00; BB CHIP:MT6225, E03; MS Board:EVEN25_HW LOG:- Ready... Profile file not exist! Default file will be created Profile file not exist! Default file will be created Press and hold power on button...OK Loading Boot... Box communication timeout! Please check connections and reset box -------------------------------------- Need PINOUT & FIRMWARE for Bluetooth FM N958; MCU:E559_JJF3F8F.V60.01.4_25S00; BB CHIP:MT6225, E03; MS Board:EVEN25_HW I have two same phones one working one not working but failed to connect both. so unable to backup firmware from working phone and flash it to another phone. any one know or worked with the phone as seen on image download link below: Phone pics download http://ifile.it/ldvpi6m/N958.zip Unable to predict whether cable wrong connection problem or any other? Plz help |
can anyone teach me how to flash chinese miracle by infinity | premaswarupa | Infinity-Box | 9 | 05-20-2009 15:47 |
Please help to Infinity Chinese miracle connection | lath123 | Infinity-Box | 3 | 05-17-2008 10:14 |
[Request] How to write Chinese Miracle phone empty board | GuruKids | Infinity-Box | 1 | 01-31-2008 08:47 |
i have box problem to connect china miracle....plz help | manish665 | Chinese Cocktail | 5 | 09-30-2007 07:53 |
How To Fine Language T68 | Sun | Sony Ericsson | 7 | 11-24-2002 06:36 |
