Old 10-30-2007, 01:00   #1 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
..::1112 insert sim problem::..
dear friends in nokia 1112 water damaged, no backlight ,some keys not working and now say insert sim card,thats the history of this phone,now after cleaning and change keypad ic ,keys are ok,but no backlight, i change every single part related to light at bottom,but when i short both positive & negative of led than it works,also insert sim card,i try to make jumper in place of sim ic and also apply rashid sir last solution but still insert sim card.chk this picture.
..::HUM::..
Old 10-30-2007, 06:34   #2 (permalink)
Member: 207494
Thanks Meter: 22
no but you must verifier conecteure (charging and litle usb)
claire or remplace
Old 10-30-2007, 06:44   #3 (permalink)
Member: 295868
Thanks Meter: 3
Check battery connector sensor pin for dry soldered, and for light check coil
Old 10-30-2007, 08:14   #4 (permalink)
Member: 522149
Thanks Meter: 1
thats problem only in battry conactor unbalanced 1000%%%%%%%%%%
me tested many time
i am not changed only one time sim ic or other components
all the best
[img]http://i23.*******.com/u/f23/11/59/93/86/134-4210.jpg[/img]
www.******.***********.com
www.******************.net
Old 10-30-2007, 08:44   #5 (permalink)
Member: 614910
for back light check vbb to coil................may b track open make the jumper
Old 10-30-2007, 16:39   #6 (permalink)
ansari123's Avatar
Member: 292789
Thanks Meter: 636
..::HUM::..
SALAM DEAR check this and reply
File Type: jpg 1600_1110_6030 INSERT SIM CARD FULL WAY 1.JPG (191.6 KB, 694 views)
Old 10-30-2007, 21:36   #7 (permalink)
r a nadeem's Avatar
Member: 241039
Thanks Meter: 4,170
dear hum
check it by my method , put red prod of multi meter at GND . now put black prod at each input side of sim IC , it will show some value . mean show some resistance . if any pin not show , that is mean UEM prob . now check pic
rashid
The Following 2 Users Say Thank You to r a nadeem For This Useful Post:
Old 10-30-2007, 21:41   #8 (permalink)
r a nadeem's Avatar
Member: 241039
Thanks Meter: 4,170
Thumbs up Another
dear hum
another thing is that check some rust at where charging base connect. change base too
rashid
Old 10-30-2007, 21:57   #9 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
walaikum-asalam rashid sir and ansari ,thnx for giving the solution,but i solved insert sim problem,but backlight still not solved,and also bell is not working,circuit is very very rusted bcoz of water,so kindly tell me that i go for more progress or return to customer?
Old 11-04-2007, 09:57   #10 (permalink)
gsm st's Avatar
Member: 143007
Thanks Meter: 141
SIR CAN YOU GIVE 6230I,........insert sim problem
Old 11-04-2007, 11:45   #11 (permalink)
ansari123's Avatar
Member: 292789
Thanks Meter: 636
DEAR CHECK THIS AND REPLY ME
The Following User Says Thank You to ansari123 For This Useful Post:
Old 11-04-2007, 14:46   #12 (permalink)
gsm st's Avatar
Member: 143007
Thanks Meter: 141
@ ansari 123 tankx a..lottt...... good work.
Old 11-04-2007, 16:17   #13 (permalink)
ansari123's Avatar
Member: 292789
Thanks Meter: 636
its ok my dear its my work its ur work
Old 11-04-2007, 23:01   #14 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
problem solved..............!
topic closed!
..::HUM::..
Old 11-05-2007, 07:29   #15 (permalink)
ansari123's Avatar
Member: 292789
Thanks Meter: 636
ok close it now \\\\\\\\\\\\\\\><
..::1208 strange insert sim card problem::.. HUM Nokia Hardware & Hardware Repair 17 06-04-2013 11:07
6610i insert sim i try all jumper and track but same insert sim shani72 Nokia Hardware & Hardware Repair 1 09-07-2009 08:02
..::c450 insert sim problem::.. HUM Samsung Hardware Repair 0 08-04-2009 22:19
insert sim chip with phone se k550im insert sim lyne Old Ericsson Phones & Sony Phones 0 03-16-2009 08:50
3210 - "Insert SIM", but SIM is inserted !?! MaRiN Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 12-29-2000 17:08
Page generated in 0.26157 seconds with 10 queries
