Go Back   GSM-Forum > Product Support Sections > Hard/Software-Products (Non-Offcial Support) > SETool2
Old 11-19-2007, 18:18   #1
falak
falak's Avatar
Member: 74749
Sonork: 100.1573876
<<<<<<<<<<<<<big Big Bomb Cid 52 Free Patch Unlock By Great Setoool>>>>>>>>>>>>
atleast ssemec market killed itself
setoool free unlock patch releasd free
v0.914013/UNI
- added STANDALONE,FREE db2020 cid52 unlock,imei change, etc by flash patch.
how to use:
1. select db2020 model, any
2. on options mark "use server,user alternative security bypass"
if you want unlock - mark "unlock after flash"
if you want IMEI change - mark "patch otp/gdfs check, allow IMEI change"
3. back on semc tab
4. add to firmware corresponding MAIN,FSIMAGE,CUSTPACK (or script)
5. press FLASH
when asked, detach phone, remove battery, insert battery, attach phone.
i STRONGLY recommend you use DCU60 for that procedure,
cause CID52 security bypass on com/ufs require ~25 min,
while on DCU60 you need ~11mins
ps.
if you KNOW (hint: identify) main firmware version and only want
unlock/change IMEI, then you can reflash only main part of firmware.
link on rapidshare:
http://rapidshare.com/files/70822013/v0.914013.rar.html
Old 11-19-2007, 18:22   #2
SM4RTBOY
SM4RTBOY's Avatar
Member: 92326
v0.914013/UNI
how to use:
3. back on semc tab
5. press FLASH
ps.
link on rapidshare:
post log if you can !
sm4rtboy
Old 11-19-2007, 18:27   #3
falak
falak's Avatar
Member: 74749
Sonork: 100.1573876
wait i m doing1 will post in few minutes
br falak
Old 11-19-2007, 18:34   #4
BuMobiles
Moderator
BuMobiles's Avatar
Member: 503346
already done one,
working fine with w580i CID52
hehe
Old 11-19-2007, 18:42   #5
unlocknas
unlocknas's Avatar
Member: 391805
do this mean db2020 is free unlock with out logs and what about cid 52 is that also free unlock
Old 11-19-2007, 18:44   #6
cianyika
Member: 3976
Sonork: 1577069
Loaded 51 flash descriptors
ChipID:9900,EMP protocol:0301
PHONE IS RED RETAIL PRODUCT
FLASH CID detected:52
Speed:921600
Flash ID check:897E
Flash props sent ok
OTP LOCKED:1 CID:51 PAF:1 IMEI:3546380xxxxxxx CERT:RED
FLASH CID:52 COLOR:RED
Model:K610i
MAPP CXC article: R1EF001 prgCXC1250589_TELEFONICA_TH
MAPP CXC version: R1EF001
Language Package:TELEFONICA
CDA article: CDA102497/25
CDA version: R19A
Default article: cxc1250376
Default version: R1EF001
Network LOCKED
Operator: MULTIPLE
RESTORATION FILE NOT PRESENT
"R1EF001_CXC1250589_TELEFONICA_TH"
YOU MUST PERFORM FULL FLASHING FOR PATCH UNLOCK
SECURITY UNITS BACKUP CREATED.
Elapsed:5 secs.
SERVER SUPPORT ENABLED.
SERVER CREDITS LEFT/USED: 28/32
CARD COUNTERS: FLASH 6, UNLOCK 2
Elapsed:4 secs.
ALTERNATIVE SECURITY BYPASS ENABLED.
Speed:921600
PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0
LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005
Flash ID check:897E
Flash props sent ok
CID52 BYPASS PROCEDURE STARTED
Processing part1...
No situable fsloader found, exiting
CID52 BYPASS PROCEDURE FINISHED
Elapsed:35 secs.
Not work ?
Old 11-19-2007, 18:45   #7
BesTCooL
BesTCooL's Avatar
Member: 18442
Sonork: 111110
laser crazy a man................ he play se... we forget cruiser name and lead.... any one remember cruiser ?
Old 11-19-2007, 18:46   #8
dayman22
dayman22's Avatar
Member: 46621
cid 52 tolally free thx setool
Old 11-19-2007, 18:48   #9
BuMobiles
Moderator
BuMobiles's Avatar
Member: 503346
you need to reflash the phone to be able to unlock.
read info
how to use:
3. back on semc tab
5. press FLASH
thanks
B.u Mobiles
Old 11-19-2007, 18:56   #10
Jr Telecom
Jr Telecom's Avatar
Member: 409725
Sonork: 100.1581478 (Jr Telecom)
FREE UNLOCK DB2020 CID52 v0.914013/UNI !!UPDATE!!! well, stupidity is rule in SEMC market today.
first, gti released cid52 patch on public - thus bringing semc market to deadline.
and now, most idiotic move, in zuliko style goes from flea & mizer - beloved kukuruzer.
they released gti patch for free, but taking logs FOR AIR.
more - they even dare to talk about "solution is protected".
what a cheap ****.
of course, we know why they release gti's patch - cause setool2 started patch sales,
while kukuruzer's "programmer" can't even make PDA flashing
so, by doing that thing, kukuruzer killed semc market.
forever shame on them.
spit on them when you can.
write "****" with big letters on their forum.
okay, enough talks.
v0.914013/UNI
how to use:
3. back on semc tab
5. press FLASH
ps.
link on rapidshare:
__________________
Old 11-19-2007, 18:56   #11
.:KHALIFA:.
.:KHALIFA:.'s Avatar
Member: 275631
again cruiser is **cked by setool...
Old 11-19-2007, 18:57   #12
t4ure4n
Member: 563011
Thumbs up Error running application
I am receiving the following wrror when i run setool2g
Internal Error
Protection card error
(8010001D)
any ideas
Old 11-19-2007, 18:58   #13
c_ahmad79
c_ahmad79's Avatar
Member: 221603
Sonork: 100.1581270
good
finally it come
freeeeee
thanks se-tool
first in the world for powerfull updates
Old 11-19-2007, 19:00   #14
LePilami
LePilami's Avatar
Member: 444025
Talking Wawo
Thank you Setooooool TEAM for this solution, I want to see the counterpart of Griffine TEAM...
Old 11-19-2007, 19:20   #15
hassan1975
hassan1975's Avatar
Member: 28819
wow
great work setool team
www.gsm-sy.com
Page generated in 0.11026 seconds with 7 queries
