Go Back   GSM-Forum > Product Support Sections > Hard/Software-Products (Non-Offcial Support) > SETool2
Old 11-20-2007, 17:11   #1
vicke_83
Member: 111023
SEtool New Update v0.914014(FREE UNLOCK CID52)
v0.914013/UNI
- added STANDALONE,FREE db2020 cid52 unlock,imei change, etc by flash patch.
how to use:
1. select db2020 model, any
2. on options mark "use server,user alternative security bypass"
if you want unlock - mark "unlock after flash"
if you want IMEI change - mark "patch otp/gdfs check, allow IMEI change"
3. back on semc tab
4. add to firmware corresponding MAIN,FSIMAGE,CUSTPACK (or script)
5. press FLASH
when asked, detach phone, remove battery, insert battery, attach phone.
i STRONGLY recommend you use DCU60 for that procedure,
cause CID52 security bypass on com/ufs require ~25 min,
while on DCU60 you need ~11mins
ps.
if you KNOW (hint: identify) main firmware version and only want
unlock/change IMEI, then you can reflash only main part of firmware.
Download Here: http://rapidshare.com/files/70938259/v0.914013.rar
v0.914014/UNI
- added .vkp processing for cid52 flashpatch
- if anybody experienced problem "bypass archive not found" it must be ok
now
- bug on ufs interface with cid52 flashpatch fixed (if anybody using it )
Download Here: http://rapidshare.com/files/70936477/v0.914014.rar
Old 11-20-2007, 18:29   #2
dindou78
Member: 515559
cid 52 is not for free ?
Old 11-20-2007, 18:37   #3
c_ahmad79
c_ahmad79's Avatar
Member: 221603
Sonork: 100.1581270
thanks for the new version
keep it up se-tool team
Old 11-21-2007, 08:51   #4
miguel_john1975
miguel_john1975's Avatar
Member: 586346
thanx for onother version to try,,, thanx team keep up!
Old 11-21-2007, 10:08   #5
loryka82
Member: 283018
thanks, super update
Old 11-21-2007, 13:19   #6
master138
Member: 344467
thx for se team
good update
Old 11-21-2007, 13:23   #7
shahzaadbutt
shahzaadbutt's Avatar
Member: 123458
Sonork: 100.1579636
CID52 Free, No Need Logs
Old 11-21-2007, 14:31   #8
Mithu
Member: 252929
what about CID51?.................................
Old 11-22-2007, 06:31   #9
gsmhelpbd
gsmhelpbd's Avatar
Member: 211318
bad username/password
se tool show badusername/password
what is username ,password
please help me.
Old 11-22-2007, 06:36   #10
lie_james
lie_james's Avatar
Member: 531344
just unlock your phone in cid52.cid 51 not free
Old 11-22-2007, 06:40   #11
bronce
bronce's Avatar
Member: 488875
Sonork: 100.1583301
please help me.
no username and password,
make it blank.
Old 11-22-2007, 07:19   #12
wasifkhan
wasifkhan's Avatar
Member: 72783
Sonork: 1578849:khan
Good update Setool Team...keep going...
Regards
Old 11-22-2007, 08:35   #13
musmankhurshi
Member: 166223
Tested Ok By M Usman
YES IT IS FREE CID 52
1005 working
good team setool
is best
m usman khurshid'
00923004201203
Old 11-22-2007, 08:55   #14
JOINEHEART
Member: 622245
thanx nice updata..........................................@} '-
Old 11-22-2007, 12:33   #15
allen128
allen128's Avatar
Member: 277327
i done unlock cid52 with setool, thanks to setool team....and there is no need credit to unlock.!!
Model:W850i
MAPP CXC article: R1EJ001 prgCXC1250204_CHINA_CY
MAPP CXC version: R1EJ001
Language Package:APAC
CDA article: CDA102295/1
CDA version: R2A
Default article: cxc1250489
Default version: R1EJ001
Operator: 000-00
RESTORATION FILE NOT PRESENT
"R1EJ001_CXC1250204_CHINA_CY"
YOU MUST PERFORM FULL FLASHING FOR PATCH UNLOCK
SECURITY UNITS BACKUP CREATED.
Elapsed:17 secs.
SERVER SUPPORT ENABLED.
ChipID:9900,EMP protocol:0301
PHONE IS RED RETAIL PRODUCT
FLASH CID detected:52
Speed:921600
Flash ID check:897E
Flash props sent ok
OTP LOCKED:1 CID:49 PAF:1 IMEI:*************** CERT:RED
FLASH CID:52 COLOR:RED
Model:W850i
CDA version: R2A
Operator: 000-00
RESTORATION FILE PRESENT FOR DETECTED FIRMWARE
Elapsed:6 secs.
Speed:921600
OTP LOCKED:1 CID:49 PAF:1 IMEI:***************** CERT:RED
PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0
LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005
Flash ID check:897E
Flash props sent ok
LDR:070410 1557 HANCXC1250562_DB2020_CSLOADER_R3A009
loader startup: executed
loader GDFS startup: executed
loader filesystem startup: executed
loader unlock: executed
resetting USERCODE..
USERCODE RESET TO "0000"
Elapsed:32 secs.
Page generated in 2.75053 seconds with 6 queries
