Go Back   GSM-Forum > GSM Mobile Brands -Software Area- > Nokia > Nokia Base Band 5 -BB5-
Nokia Base Band 5 -BB5- Baseband-5 Phones: 3250, 6131, 6133, 6125, 6126, 6270, 6280, 6282, 6630, 6680, 6681, 6682, 7370, E60, E61, N70, N70, N72, N80, N90, N91, N92
Old 11-24-2007, 15:33   #1
florim
Member: 504627
Cool How to reset Security code on BB5 Nokia phones - easy solution
Here's how to reset Security code on BB5 Nokias.
You need a Data cable that comes with your phone and Nemesis Service Suite(later named as NSS)installed on your PC.Download and pdg4fbus.dll patch that is offered there-at the bottom of the page,the installation instructions for him are included in same zip archive.
Connect normally turned on phone to the cable and install drivers for it,is asked.
Start NSS and click on magnifier glass - marked with mouse cursor.
When driver and other NSS software informations are displayed,click on big Phone Info (1.) button and then on little Scan (2.) button.If everything is OK you will get message Done! (field marked with arrow).
Now click on big Tools (3.) button,
then on tab Factory Settings (4.)
http://img340.imageshack.us/img340/9334/nss4gl9.jpg
now here,if you have a Symbian phone then you must check Symbian box (it is above the Reset button marked with 6.),if you have S40 3rd phone then leave Symbian unchecked.
Select User code (5.) if not allready selected and click on Reset (6.) button.
If everything goes well message Done will appear again in that field marked in second picture+those messages in regular information window.
That's it,your Security code is set to factory 12345 again.
Old 11-24-2007, 19:05   #2
m4m
Member: 126208
if the phone locked u can't found the phone by nemesis tools
which mean if the phone ask for the security code at start u can't use usb mode!!!
correct me if im wrong?
its usfulll if the phone start and u can use it but u dont know the security code then u can use this tools.
Old 11-24-2007, 20:09   #3
vmin81
Member: 304251
If The Fone Is Lock So We Will Connect It To Applcation Dude We Are Still Not Login Fone So Howww
Old 11-24-2007, 20:11   #4
Gall
Member: 197849
Thumbs down
Old method...
Author is a stupid man, use SEARCH!
Old 11-24-2007, 20:13   #5
vmin81
Member: 304251
Originally Posted by Gall View Post
Old method...
WHAT DO MEAN MAN IT RUMMER OR WHAT MORE EXPLAIN
Old 11-24-2007, 20:15   #6
**RABIOS-TE@M**
Member: 439283
old !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 11-24-2007, 20:23   #7
mkwatis
mkwatis's Avatar
Member: 22893
@florim;
How to with nokia 5200/5300
Old 11-24-2007, 20:41   #8
ahhongchai
Member: 68833
yes ...................u rite , phone cant found went lock by usb
Old 11-27-2007, 23:21   #9
pitone02
Member: 13999
put 5kohm resistor to bsi phone connector so phone goes in testmode.
then use the nss
Old 11-27-2007, 23:41   #10
nagold
Member: 92487
Sonork: 100.1575647
This easy solutions its for people who dont have a box, the phone must be in test mode to make connection and its verry useful in this case.
Put 5 Kohm resistor to BSI line and phone goes in test mode.
Old 01-19-2008, 17:38   #11
kalodner
Member: 683938
When i try to reset the user code on my 5500 with NSS i get an error (Reset Factory... Error!)... What can i do to reset the user code?
Old 01-19-2008, 19:28   #12
sairat
sairat's Avatar
Member: 337837
Sonork: .:: Intel Inside ::.
Exclamation
then use the nss
ITS GOOD I THINK ITS USEFULL...........................!
Old 01-19-2008, 22:56   #13
layna
layna's Avatar
Member: 135795
yes that's right, phone must to be in local or test mode to read user code
you can use nss or jaf crack.
Old 01-19-2008, 23:05   #14
Jr Telecom
Jr Telecom's Avatar
Member: 409725
Sonork: 100.1581478 (Jr Telecom)
Modem driver ll not get while phone is security locked
So need Fbus modified usb not usable that mode.......
Old 01-19-2008, 23:23   #15
layna
layna's Avatar
Member: 135795
as i say ,if your phone is in local mode you can use usb data cable , no matter if it security locked
Page generated in 0.10055 seconds with 6 queries
