![]() ![]() Join Date: Jun 2006
Member: 286304 Status: Offline Thanks: 0
Vista will not sleep when bluetooth is on
Hi everybody!
Help me, please, to find a solution. My laptop will not go to sleep mode if the bluetooth built-in device is on. It is Broadcom 2045. The screen turns off but fans and lights remain on. Once I turn the bluetooth off the problem goes away. I have tried latest Anycomm, Widcomm drivers. The original Vista driver may work but the functionality of the bluetooth is limited to nothing I'd say and thus pointless. Googling did not help either. Thank you. |
![]() ![]() ![]() ![]() ![]() Join Date: Mar 2007
Member: 462224 Status: Offline Thanks: 219
that is normal, if bluetooth is activated the system will not goes on sleep mode totally.
#3 | |
Else, I tried to run the "fix" from MS because logically "the system fails to restore from sleep" but it said my system wouldn't need it. |
so, you have to change almentation parameters in configuration panel.
I experimented with many parameters in power options with no luck. The only solution which works for me so far is to turn off the bluetooth first and then activate the sleep function. By no means it is the solution to the problem. It must sleep regardless of the devices either on or off.
