01-04-2008, 04:35 | #1 (permalink) |
No Life Poster Join Date: Feb 2007
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | code corrupt of unlock v3i 0A.30 S-Card: xxxxxxxxx Smart-Clip dongle, v 2.01, assigned Smart-Clip: xxxxxxxxxxx Europe, initializing... OK Clip serial: xxxxxxxxxxxxx version: 4.01, initializing... OK Searching for phone... found Motorola Phone (V3i iTunes), getting test interface... OK Reading <Model>... clip communication failed Clip serial:xxxxxxxxx, version: 4.01, initializing... OK Searching for phone... found S Flash Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Searching for phone... found S Flash Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... A.30 Sending boot... OK Erasing flash memory OK Sending firmware OK Searching for phone... found S Flash Neptune LTE2 Switching to flash mode... OK Reading phone boot version... A.30 Boot prepare... failed |
01-04-2008, 08:07 | #2 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | Please specify what power supply do you use and was the phone battery fully charged? Best Regards GSMServer team |
01-04-2008, 13:23 | #4 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ chris2007, What power supply you are using? Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
01-06-2008, 22:09 | #5 (permalink) | |
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | Quote:
01-07-2008, 04:22 | #7 (permalink) |
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | for now i prepare and full flash and now the phone it unlock but the one more fings dat i break two resistor and now i fixed it and late reply for the result |
01-13-2008, 23:46 | #8 (permalink) |
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | v3i now in boot mode boot loader OA.30 SW Version R47A_G_08.D9.76R any higher SW version so that i flash my phone to a normal..... i was flash it with this full flash file R47A_G_08.d9.76R_lp0033.full_flash.mfw the phone it power up and auto off |
01-14-2008, 08:22 | #9 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ chris2007, The highest available firmware version is R47A_G_08.d9.76R. Perform Repair PDS procedure and after that Full Flash the phone with it. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
V3i 0A.30 R479_G_08.B5.86R Bootmode only...!!! | Viga_10 | Smart-Clip | 19 | 06-06-2008 23:43 |
code corrupt of unlock v3i 0A.30 | chris2007 | Smart-Clip | 1 | 01-04-2008 08:10 |
V3i 0A.30 R479_G_08.B5.86R Flash File in RSD LITE badly needed..., | Viga_10 | Smart-Unlocker | 2 | 10-13-2007 12:56 |
How write lang to V3i 0A.30 (white out TP) | GsmLiberty | Smart-Clip | 9 | 02-04-2007 14:21 |
Is V3i 0A.30.SW Version R479_G_08.B4.34R Supported? | James-R | Smart-Clip | 0 | 01-11-2006 15:36 |
