| View Poll Results: Contact Service -- Harware or Software. | |||
| Hardware |
920 | 60.01% |
| Software |
189 | 12.33% |
| Both |
424 | 27.66% |
| Voters: 1533. You may not vote on this poll | |||
Member: 69984 Status: Offline Thanks: 28
1600 Contact Service by Changing SIM IC.
Dear Friends, When I was changing SIM IC of 1600, I got Contact Service in it.. its first time I got. I tried to do via flash I could'nt solved. If any body have correct solution please reply urgent....
Please Help.. |
| The Following 54 Users Say Thank You to .:.GSM-ANGEL.:. For This Useful Post: | -=MR_Gsm=-, 3G_phi., 4strangers, 6ayatri, ajeetjoy, alihussaindua, alzir512, anuj_manchanda, aonguda, arvind55, asadnow2k, asef_55, bhuttamobo, birdmobile, buzz_makulitz, cmtcentre, djbrekele, eubs2008, fakhre, farazjaan, gsm-iran, gsmashfaq, gsmmore, haji rahim, hima010, hs.com, ismile ali, kisma1977, max0066, md_amin3, mizan, mobilesharif, multi_ele, nisarp, oky3ms, parham20, Q-GEN, raghavnipun, rana2, rising star, Rizwan ch08, ronyi, s.muthukumar, saleservzone, salinkhan, salman khan22, sandeeproli, shad_killer, shaiful islam, shoeb7, sonpari, thethi, ttms, zakira |
Member: 197916 Status: Offline Thanks: 3
hardware problem! cek if ur phone stanby contant service can shut down if u press on/of its cpu problem!!
if phone stanby contant service can't shut down by press on/of its uem problem!!! br, acay |
| The Following 48 Users Say Thank You to acay For This Useful Post: | -=MR_Gsm=-, 4strangers, 6ayatri, ajeetjoy, alksander, aonguda, arushar1, ashrafi580, chetangajjar, cmtcentre, colepipo, defrianto, Dinesh4all, dreamshifts11, FreshBohn, gaathey, genius2005, gul-fraz, haji rahim, janki_amreli, jaysu09, jecams, Kethey, kuang2242, max0066, md_amin3, mithon, mmmfaruk, oky3ms, optionzali, ovi cellular, pacephone, prasad2, rana2, Rizwan ch08, sadiq123, salahbeb, shakhawat, she_mul, shivamobiles, sunamuni_1985, syed lateef, syed.n, thethi, ttms, vijaykumar_1971, Waseem-y, zahidnawaz |
![]() ![]() ![]() ![]() Join Date: Oct 2007
Member: 618734 Status: Offline Thanks: 17
see if it is ok on normal mode by software and contact service by battery than 100% uem problem it is due to overheating
| The Following 24 Users Say Thank You to RUVAIZ For This Useful Post: |
![]() ![]() ![]() ![]() Join Date: Jul 2006
Member: 308296 Status: Offline Thanks: 167
brother dip ur phone in petrol for 15 min and after that clean ur pcb or give heat on cpu ur problem is solved 100%
| The Following 19 Users Say Thank You to tarunvishal For This Useful Post: |
![]() ![]() ![]() ![]() Join Date: Nov 2007
Member: 641058 Status: Offline Thanks: 5
its must be hardware i feel u messed up balls in uem when u changing sim ic hope u gentle heat uem with good paste careful becoz uem moulded
best of luck |
| The Following 17 Users Say Thank You to sphameed For This Useful Post: |
![]() ![]() ![]() ![]() ![]() Join Date: Jun 2007
Member: 528679 Status: Offline Thanks: 16
hi to all ,
finaly i will lockout this problem . problem is pp file if write same pp file then we can solved this type problem.or others solution is change sim ic then flash or make sim jumper then flash......good luck |
| The Following 14 Users Say Thank You to sopnil For This Useful Post: |
#7 | |
![]() ![]() ![]() ![]() ![]() Join Date: May 2006
Member: 275631 Status: Offline Thanks: 9
so bro its hardware problem... first remove that sim n chek ... if contact service gone than just put another ic.... secondly if the problem still there after removing sim ic ... than simply reball or change upp... 90% ur problem will b solved with this.. n the 10% is dew to uem
| The Following 19 Users Say Thank You to .:KHALIFA:. For This Useful Post: |
![]() ![]() ![]() ![]() ![]() Join Date: Aug 2006
Member: 340957 Status: Offline Thanks: 90
hi, personally iv stop doin des models,1600,1200,1110 etc cuz da mother boards are very weak, just as if nokia made dem 2 b disposible fones.
| The Following 11 Users Say Thank You to joe cellular For This Useful Post: |
| The Following 7 Users Say Thank You to .:KHALIFA:. For This Useful Post: |
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2006
Member: 409725 Status: Offline Sonork: 100.1581478 (Jr Telecom)
I agree with @:KHALIFA:
"""""""""""""""""""""""""""""""" while somebody change the sim ic then upp/uem destroyed by high temparature...sometimes by rehot/reball phone will be alive...........
| The Following 40 Users Say Thank You to Jr Telecom For This Useful Post: | -=MR_Gsm=-, 4strangers, alamgir80, anshulbhola, arjun_kics, ashmac, babar117, cmtcentre, eatter real, eubs2008, ganja-fahad, gunno, ivansell, jhonson, kamrul_satkhira, max0066, mizanbd, mmmfaruk, mmuzaffar, multi_ele, nagendrapatil, Nishanudeen, ozukum, pakwaysmobile99, payabo, rajresh2007, Rizwan ch08, rohit_123, saeedsaeedsaeed, shad_killer, sidar2007, sonwin, suba3366, syed lateef, tata_beneth, thethi, towhidbd, trungmobile1984, VERMAGSM, vijaykumar_1971 |
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2005
Member: 207308 Status: Offline Thanks: 163
yes
| The Following 26 Users Say Thank You to adnanali For This Useful Post: |
![]() ![]() ![]() ![]() Join Date: Mar 2007
Member: 479496 Status: Offline Thanks: 94
| The Following 4 Users Say Thank You to adalaqeel For This Useful Post: |
and what is upp....
| The Following 5 Users Say Thank You to adalaqeel For This Useful Post: |
![]() ![]() ![]() ![]() Join Date: Aug 2005
Member: 169384 Status: Offline Thanks: 18
After removing Sim IC u got ContactService its 99% UEM problem...
| The Following 14 Users Say Thank You to gokul2005 For This Useful Post: |
Member: 318277 Status: Offline Thanks: 10
Agree with al mates (CS due to over heating)
100% hardware bro.try da solution above n if nt bad luck.pointless spending time for a phone like 1600 for more than that.try to replace a pcb Cheers' |
| The Following 12 Users Say Thank You to mobilelink For This Useful Post: |
