| View Poll Results: Contact Service -- Harware or Software. | |||
| Hardware |
920 | 60.01% |
| Software |
189 | 12.33% |
| Both |
424 | 27.66% |
| Voters: 1533. You may not vote on this poll | |||
#31 |
![]() ![]() ![]() ![]() Join Date: Feb 2008
Member: 698055 Status: Offline Thanks: 22
try this ,heat the cpu little hard & fls phone with same version r higher version with pm file
| The Following User Says Thank You to bathri525 For This Useful Post: |
#32 |
![]() ![]() ![]() Join Date: Dec 2006
Member: 411740 Status: Offline Thanks: 11
rehot upp gently with slight moving if no result `we cant do any thing
#33 |
Member: 115189 Status: Offline Thanks: 0
friends water loggd phones often got contact service.it s 100% hardware.try to clean well.best of luck.
#34 |
Moderator
![]() Join Date: Feb 2006
Member: 233205 Status: Offline Sonork: 100.1578108
| The Following User Says Thank You to tkowsar For This Useful Post: |
#35 |
![]() ![]() ![]() Join Date: Mar 2007
Member: 473823 Status: Offline Thanks: 0
see friend the heat was high enough to reach the uem so at first try to flash it if not solved u will have to heat uem
#36 |
Member: 69984 Status: Offline Thanks: 28
Yes bro, I solved my problem but I think its very intresting topic and I many users have this problem facing... I think this tread should continue... so members please post your results regarding Contact Serivce. just sign poll above thread... and rate this thread. please.
| The Following User Says Thank You to .:.GSM-ANGEL.:. For This Useful Post: |
#37 |
Please rate this thread..
#38 |
Please sign poll...
Contact Service -- Harware or Software or Both |
#39 |
Please share your Contact Service solving experience..
#40 |
Member: 153805 Status: Offline Thanks: 53
As I know 1110,1112,1600 go to CS when trying to remove SIM ic , as UEM is so close and under filled with glue , when overheated balls expands and when cooled shrinks and some balls loose connection.I never heated this ic after damaging 2 sets.I slowly scratch this ic with pointed needle, care should be taken not to apply too pressure as it may damage board prints.
after that apply paste and clear with fine tip iron.And make jumpers. |
| The Following User Says Thank You to baldev For This Useful Post: |
#41 |
![]() ![]() ![]() Join Date: Nov 2007
Member: 630431 Status: Offline Thanks: 72
its 70% software tre its my own..........
#42 |
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2007
Member: 422762 Status: Offline Thanks: 14
what a solution where where u from the long time.... please dont disguide anybody with fake solutions
#44 |
![]() ![]() ![]() ![]() Join Date: Nov 2007
Member: 627475 Status: Offline Thanks: 35
flash with jaf and then press unlock
#45 |
Member: 716806 Status: Offline Sonork: mr.jitendra546@rediffmail
my dear plz cpu rivbalb and insert cart ke liye aap ko sim rider ic ko nikal kar jamper se solv karna hoga
| The Following User Says Thank You to jeetu9 For This Useful Post: |
