View Poll Results: Contact Service -- Harware or Software.
Hardware 920 60.01%
Software 189 12.33%
Both 424 27.66%
Voters: 1533. You may not vote on this poll
Old 03-08-2008, 17:59   #46
meindy
Member: 719145
just rehot u're upp. 100% succses. good luck
The Following 3 Users Say Thank You to meindy For This Useful Post:
Old 03-16-2008, 15:15   #47
bathri525
Member: 698055
bro try this fls u r phone with 1600pm before that rehot upp applying liquid flux if this not u r prb remove upp and re ball it then place it care .
The Following User Says Thank You to bathri525 For This Useful Post:
Old 03-16-2008, 16:00   #48
samer82
Member: 163954
i have problem like this in 1112 but i solved this problem by reball upp ic and it's ok
The Following 2 Users Say Thank You to samer82 For This Useful Post:
Old 03-17-2008, 20:33   #49
nasirahmed
nasirahmed's Avatar
Member: 57760
Yes, reballing UPP solved this problem.
The Following 2 Users Say Thank You to nasirahmed For This Useful Post:
Old 03-17-2008, 21:07   #50
Shakeel_pattoki
Shakeel_pattoki's Avatar
Member: 437195
Sonork: 100.1586277
Originally Posted by acay View Post
hardware problem! cek if ur phone stanby contant service can shut down if u press on/of its cpu problem!!
if phone stanby contant service can't shut down by press on/of its uem problem!!!
br,
acay
Bro.in contact service fone will never shutdown by ON/OFF key.
The Following User Says Thank You to Shakeel_pattoki For This Useful Post:
Old 03-17-2008, 21:15   #51
Shakeel_pattoki
Member: 437195
Sonork: 100.1586277
a good job for this pro
Old 03-17-2008, 22:19   #52
jabed-mobilenet
jabed-mobilenet's Avatar
Member: 538824
Good Share Everybody.it's A Useful Share.
The Following 2 Users Say Thank You to jabed-mobilenet For This Useful Post:
Old 03-18-2008, 20:41   #53
SHOEB AHMED
SHOEB AHMED's Avatar
Member: 161115
Sonork: No Optional
I AM SOLVED SOME 1600,1200,110i MOBILE PROBLEM BY CHANGING LCD DISPLAY.ITZ NOT FAKE SOLOTION BRO I FOUND IT AS LIKE IMAGING.
100% CONTACT SERVICE....................PROBLEM!!!
40% SOFTWARE AND
60% HARDWARE.
THISE MY IDEA...............MAY BE ALL MEMBER AGREE TO MY COMMENT.
B.R
MZONE
The Following 4 Users Say Thank You to SHOEB AHMED For This Useful Post:
Old 03-19-2008, 09:23   #54
mabidkhan
Member: 727806
Sonork: pakistan
it is uem problem in your phone or u try flash with jaff box four to five time.
The Following User Says Thank You to mabidkhan For This Useful Post:
Old 03-21-2008, 16:59   #55
sujan1050
sujan1050's Avatar
Member: 449518
100% Contact Service Solotion
File Type: jpg nokia 1112 (contact service) or Local Mode.jpg (69.5 KB, 1723 views)
The Following 4 Users Say Thank You to sujan1050 For This Useful Post:
Old 03-25-2008, 16:38   #56
sjawall
Member: 291927
clean it with ctc and reheat it on light hoeat level.if still contect service then change the uem and flash it by jaf.........best of luck.....
Sjawall
Old 03-26-2008, 13:15   #57
/ARIF/
Temporary banned !!
Member: 546766
did you test it.as fer as i know you success 1 0r 2.no more without it.
if you solved this problem with many phones so that you will say me how to it possible.
pls more explain about this
Old 03-27-2008, 09:30   #58
SHIJILFONOTLY
SHIJILFONOTLY's Avatar
Member: 351924
Sonork: 100.1581941
brother
u said after change sim ic phone contcat service right?
then remove sim driver then check same problem show?
75%upp or 25%uem problem
first reflow UPP
POST RESULT
Old 03-28-2008, 08:44   #59
arnold marpaung
Member: 659586
thanks to you bro, nice share.......
Old 03-28-2008, 09:23   #60
akhil_bbsr
akhil_bbsr's Avatar
Member: 271478
so long thread ........i faced same problem when i replaced sim COG ..i ...was in trouble...i removed the UPP and reball it and done erase and full flash in mt box...but same problem,,,,,,,,,,,,,,,then i remove the UPP again ....replaced from a dead phone full flashed and unlocked set..........ok......i found form is this ............99% UPp damages after the heat ..now solution is that ..when ever .............removing SIM COG give a protection to upp and uem by keeping a damaged PFO on top of both ic...now i repired 20 sets witout CS.
The Following User Says Thank You to akhil_bbsr For This Useful Post:
Page generated in 0.10435 seconds with 8 queries
