| View Poll Results: Contact Service -- Harware or Software. | |||
| Hardware |
920 | 60.01% |
| Software |
189 | 12.33% |
| Both |
424 | 27.66% |
| Voters: 1533. You may not vote on this poll | |||
#61 |
![]() ![]() ![]() ![]() ![]() Join Date: Feb 2007
Member: 445578 Status: Offline Thanks: 152
its cpu=upp problem becouse when some body try to change sim ic's with hotear gan then the upp may be demage so when need to change sim ic then use hit protector upon upp and uem!!!!!!!and use maximam hit in sim base couse if sim base distroied we can change it upp uem not
| The Following User Says Thank You to sumon.bd For This Useful Post: |
#62 |
![]() ![]() ![]() Join Date: Apr 2006
Member: 267729 Status: Offline Thanks: 17
jus undo the sim repair and check if it helps...be care full
#63 |
![]() ![]() ![]() ![]() Join Date: Dec 2005
Member: 205776 Status: Offline Thanks: 23
when u remove the ic u should be very careful. i think u have damaged uem , because when u remove the insert sim ic ur uem ic will get damaged... and u will get contact service... only one solution for contact service is that if it is water damaged clean the pcb well in white petrol or ip.. there is no solution for contact service right now..
#64 |
Member: 449518 Status: Online Thanks: 20
100% hardware bro.try da solution above n if nt bad luck.pointless spending time for a phone like 1600 for more than that.try to replace a pcb
try this |
| The Following User Says Thank You to sujan1050 For This Useful Post: |
#65 |
![]() ![]() ![]() ![]() Join Date: Jan 2008
Member: 684493 Status: Offline Thanks: 2
bro,
i check that picture solouion it is right you should try above soloution .... |
#66 |
Member: 69984 Status: Offline Thanks: 28
#67 |
![]() Join Date: Mar 2008
Member: 720374 Status: Offline Thanks: 3
thanks everbody good sheare
#68 |
Member: 682732 Status: Offline Thanks: 1
sir i have nokia 6085 which is water damage.i clean pcb very well now set on but when i start camera set is auto restart. i flash with new flash file but no result it's strip&camera section was ok i check with other 6085 set plssssssssss give me solution....
#69 |
Member: 454011 Status: Offline Thanks: 20
1000% upp prob...... re hot upp
#70 |
Member: 153805 Status: Online Thanks: 53
Hello friends I changed hot air nozzles shape from round to square and it perfectly covers the ic.I chenged many KP ic and sim IC without damaging UEM or Sim tray.Diffrent size nozzles should be used for KP ic and SIM ic.
| The Following User Says Thank You to baldev For This Useful Post: |
#71 |
![]() ![]() ![]() ![]() Join Date: Nov 2007
Member: 638416 Status: Offline Thanks: 114
i m sure uem our sim ic
#72 |
![]() ![]() ![]() ![]() Join Date: Oct 2005
Member: 188374 Status: Offline Thanks: 19
All My Friends I Face This problem. A long Time Ago. Then i
make This Solution. This Problem Came Over Temperature. I Remove Sim Ic With Smd rework station This Angle. Please Give Your Comets. |
| The Following 2 Users Say Thank You to papoo For This Useful Post: |
#73 |
Can any one explain how to reball UPP or UEM.. Please explain step by step, please show pictures if you can.
#74 |
![]() ![]() ![]() ![]() ![]() Join Date: Mar 2007
Member: 460857 Status: Offline Sonork: 1581360
Rebol UEM Or Change............................
#75 |
that may distroied uem so see my solution becouse uem is glued! also be cotact service!
