Go Back   GSM-Forum > Product Support Sections > IMEI or online Server Products > Gsmfather The Wholesale Unlocking Database
Old 02-20-2008, 15:25   #1 (permalink)
Ron2pet's Avatar
Member: 17609
Sonork: 100.64817
Thanks Meter: 1,694
[ FAQ ] How To Enter Unlock Codes
How to enter my Unlock Code on Alcatel?
Model : Method Generic
1 - Switch ON your phone without SIM Card,
2 - Then compose : *#0000*CODE#,
3 - To finish compose : *#0001*CODE#.
Model : 531 & 535
2 - Press * and without release compose 787292,
3 - A new menu "Unlock Network" will appear, then select "YES",
4 - Enter the Code we send to you.
Model : All other Alcatel
1 - Switch on your phone with a not allowed SIM Card,
2 - When the message "Enter Network Key" appear enter the Code we send to you
Old 02-20-2008, 15:31   #2 (permalink)
Ron2pet's Avatar
Member: 17609
Sonork: 100.64817
Thanks Meter: 1,694
How to enter my Unlock Code on BENQ?
Model : All Benq
1 - Switch ON your phone with a not allowed SIM Card,
2 - Enter the Unlock Code we send to you.
Old 02-20-2008, 15:35   #3 (permalink)
Ron2pet's Avatar
Member: 17609
Sonork: 100.64817
Thanks Meter: 1,694
How to enter my Unlock Code on BlackBerry?
Model : BlackBerry 8700.8800.8300.8320
You must have a SIM card in your phone to complete these steps ( Can be
active or inactive )
WARNING: The Wireless Mode MUST be OFF before performing the given SIM
Unlock instructions in order to avoid causing the device from becoming
defective.
How to turn Wireless Mode Off:
1. Scroll to (Turn Wireless Off.)
2. Press Select.
3. Wireless Mode will turn off.
How to Unlock the device:
1. On the Home screen, click the Tools icon ( Setting Menu ). The Options
screen appears.
2. In the Options screen, select "Advance options".
3. Scroll to "SIM Card" and select it. You should see the phone number and
the SIM ID number.
5. Press and Hold ALT key and Type MEPE
6. It will say "Enter Network MEP Code", then you type in the Unlock
code.
7. Press ENTER and reboot handheld.
8. Your phone is now unlocked
Model : BlackBerry 8100c 8100r 8100g 8100v Pearl
1 - This can be done with or without sim card.
2 - Go to Options Menu => Advanced Options.
3 - Go to Sim Card Menu
6 - Now Type MEPP2 (Press, and hold the ALT key while typing 2. you will not see anything on screen while typing. ALT key is beside * key, symbol like arrow key.)
7 You will see "Enter Network MEP code (number of attempts left will appear
in brackets).
8. Enter your Network MEP code (unlock code) GsmFather server provided, than press enter.
10. You will see "Code Accepted."
11. You have permanently unlocked your BlackBerry.
12. Power off your BlackBerry, than insert your desired SIM card.
Model : BlackBerry 8100 (Vodafone Australia)
PLEASE READ THE INSTRUCTIONS CAREFULLY BEFORE YOU ATTEMPT ANY UNLOCK PROCESS
This procedure unlocks the handset from being network restricted from only using SIM cards from Vodafone Australia. In case of difficulties, please refer to the FAQ listed below
1. Take note of the unlocking code shown above
2. Insert a Non-Vodafone Australia working SIM card.
3. Ensure the phone is charged and then switch the phone on.
4. Optional Step: If the SIM card has a PIN, enter your PIN number. (See FAQ below)
5. The phone will then display a message. The most common is “Invalid SIM card”. (Different message? See FAQ below)
6. Select “Turn Wireless Off”
7. Select “Settings” Menu , then go to Advanced Options > SIM Card
8. Type alt-MEPT by holding the ALT-key and typing the letters MEPT with multitap i.e. type hold ALT, type {M}{ER}{OP}{OP}{TY}
9. When prompted with “Enter Network MEP code (255 left)” on the screen, enter the 16-digit network unlock code provided for your phone, then press Enter. (Unlocking code is shown above)
10. Reset the phone by pulling the battery
11. Switch the phone on and the handset will be unlocked automatically. This will be confirmed if you can make and receive calls with the Non-Vodafone Australia SIM card. (You will need reception and phone credit with the different network provider)
Please Note:
If the unlocking code is entered incorrectly the next attempt to unlock the device will be delayed for 10 seconds increments. The number of unlocking attempts is limited to 255 tries only. When 255 attempts is reached the phone will be permanently blocked.
To unblock the phone, it must be taken to a RIM service centre. No outgoing calls including emergency call is possible when the phone is blocked.
FAQ:
Question: My phone asks to enter a PIN number
Answer: For SIM cards with PIN ENBLED you will be required to enter a PIN. This is not the unlocking code that has just been provided. For information concerning the PIN, PIN2, PUK and PUK2 codes for a SIM card please read the manual that came with your phone. This is not a handset unlocking difficulty.
Question: My handset displays a different message then what is shown in this procedure when I insert a Non Vodafone Australia SIM card.
Answer: The most common message the phone will display is “Invalid SIM card”. Because each handset may have a different variation in software there is no common message. If your handset displays a different message it is recommended to move onto the next step. Note: Faulty SIM Cards - The handset may also display messages indicating the SIM you are using to unlock the handset is faulty, it could display “Insert SIM” “Bad Card”, “Card Error” or “Card Rejected”, confirm the SIM card is inserted correctly – Gold area downwards and the cut of the corner matches correctly. You will need a working Non Vodafone SIM card to unlock the handset, Vodafone can not assists with other networks faulty SIMs.
Question: I am outside of Australia and experiencing difficulties unlocking the phone that I purchased from a Vodafone Australia outlet
Answer: Clearly note this in the difficulties description. Vodafone Australia can only send a reply to the difficulty by email.
Model : All BlackBerry
1 - Using the menu go to Settings Menu -> SIM card pressselect.
2 - While holding the SHIFT key, type mepd
3 - You should now see the five locking categories listed.
4 - While holding the SHIFT KEY, type mep2.
5 - Release the shift key.
6 - You are now prompted to enter the Network MEP code (it will also state how many attempts left)
7 - Enter the code
8 - Enter Return/Enter
9 - The device should then be unlocked
Old 02-20-2008, 15:37   #4 (permalink)
Ron2pet's Avatar
Member: 17609
Sonork: 100.64817
Thanks Meter: 1,694
How to enter my Unlock Code on Bosch?
Model : All Bosch
2 - When the message "Enter Network Key" appear enter the Code we send to you.
Old 02-20-2008, 15:38   #5 (permalink)
Ron2pet's Avatar
Member: 17609
Sonork: 100.64817
Thanks Meter: 1,694
How to enter my Unlock Code on Ericsson?
Model : All Ericsson
2 - Press 1 time the left arrow,
3 - Press 2 times the button * ,
4 - Press 1 time the left arrow,
5 - The message "Personalize with MNC2" will appear,
6 - You can now enter the Unlock Code we send to you.
Old 02-20-2008, 15:38   #6 (permalink)
Ron2pet's Avatar
Member: 17609
Sonork: 100.64817
Thanks Meter: 1,694
How to enter my Unlock Code on Palmone Treo?
Model : TreoŽ 600
1 - Switch ON your phone with Allowed SIM Card,
2 - Go to Menu and select "Phone Tool" or "Phone Application"
3 - Type on Virtual Keyboard *#*#CODE#
4 - Select with PEN "Number" and phone will show that's unlocked now !
or
1 - Switch ON your phone with a not Allowed SIM Card,
2 - Enter the Unlock Code we sent to you.
Model : TreoŽ 650/680
1 - Remove TreoŽ battery, unplug cable
2 - Insert incorrect SIM card (1 the phone does not accept)
3 - Power on your Treo, “Sim not allowed” is displayed, click “ok”
4 - Go to the dial pad, and use the stylus to enter code *#*#CODE#. Then press “Dial”
5 - Phone will reset and display “sim lock removed”
Ensure you enter the codes in this manner *#*#CODE# (e.g. *#*#12345678#)
Troubleshooting:
Error Message: "The SIM Lock has NOT been removed from this phone"
Solution 1: Please make sure you are entering the correct code and enter it using this method *#*#CODE# dial
Solution 2: If the phone says that the SIM lock has not been removed, ensure that the phone radio (wireless mode) is on.
Model : Treo 750
1 - Power on handset With Non accepted Sim card
2 - Enter the unlock code
3 - Your phone will be unlocked.
Note = If you get invalid code, Soft reset the device and make sure battery is fully charge, and try above procedure again.
Old 02-20-2008, 15:39   #7 (permalink)
Ron2pet's Avatar
Member: 17609
Sonork: 100.64817
Thanks Meter: 1,694
How to enter my Unlock Code on Kenwood ?
Model : All Kenwood
1 - Switch ON your phone with a not Accepted SIM Card,
Old 02-20-2008, 15:41   #8 (permalink)
Ron2pet's Avatar
Member: 17609
Sonork: 100.64817
Thanks Meter: 1,694
How to enter my Unlock Code on LG Electronics ?
Model : LG KU990 Viewty
1. insert original sim card and turn phone on.
2. Press telephone icon at bottom of screen to bring up the phone keypad
3. Enter 2945#*990#
4. A menu will pop up, select sim unlock
5. Enter your unlock code and press ok
6. The phone will then reboot and the unlock is complete.
Model : LG CT810
1. Insert original sim card and turn phone on.
2. Enter 2945#*810#
3. Sim unlock mode pop up .
4. Enter your unlock code and press ok
5. Then reboot and the unlock is complete.
Model : LG VU CU920
1) Power ON your phone with an accepted SIM card
2) Type *#865625# Warning message will appear, press ok
3. enter nck code provided by Gsmfather server, you have to re-enter code again.
3) Press OK
4) Device is now unlocked
Model : LG TU720 CU720 And All Shine SERIES
2) Type *#865625#UNLOCK CODE
3) Press OK
Model : LG CU400
1 - Insert SIM Card from a unsupported network provider,
2 - Power on the handset,
3 - Phone will display "Invalid SmartChip"
4 - In Idle screen, enter : 159753#*#
5 - Phone will display "Enter NCK, Remaining 5"
6 - Enter the 8 digit SIM Unlock code
7 - Select "OK"
8 - The handset is now successfully unlocked
Model : LG CU515
1.Put a SP-locked sim in the phone, phone say invalid smart chip
2.Now enter *#865625# then select option 1 and then again select 1 and enter your 16 digits code
Phone will be unlocked!
Model : LG CU915
3) Press OK
Model : LG U8150
1 - Switch ON your phone with a NOT Allowed SIM Card,
2 - Compose : 2, 7, 7, 6, 3, 4, #, *, #,
3 - Go to menu "SIM Lock",
4 - Enter the Unlock Code we send to you.
Model : LG U400
1. Insert the Accepted Sim Card.
2. Enter 2945#*88110#.
3. The phone will then prompt 'Unlock sim'. Press OK.
4. The phone will then prompt 'Network Unlock'. Press OK.
5. The phone will then prompt- 'Input Network Control Key'.
Enter the 8 digit unlocking code. Press OK. If the unlocking code comes with only 7 digits, add a 0 in front of the 7 digit code. If the unlocking code comes with only 6 digits, add 00 in front of the 6 digit code.
6. It should give you the message Success.
7. Come back to the main screen and Enter 2945#*88110#.
8. The phone will then prompt unlock sim. Press OK.
9. The phone will then prompt Network Unlock/ Lock but if you scroll down you will see a message Enter SP Lock. Enter SP Code.
10. Then press OK
Model : LG KF600
2. Enter 2945#*71001#
5. The phone will then reboot and the unlock is complete.
Model : LG KF750
2. Enter 2945#*750#
3. A menu will pop up, select sim unlock
4. Enter your unlock code provided by Gsmfather.com server and press ok
Model : LG KT520
1. Switch ON your phone with Accepted SIM card
2. Then compose: 2945#*520#
3. Security Menu pops up, choose Unlock USIM
4. Choose Network Lock, enter unlock code given by Gsmfather.com Server
5. Enjoy unlocked phone
Model : LG KU580
2. Then compose: 2945#*580#
Model : LG KC550
1. Insert original sim card and turn phone on. (Sim from the operator which locked it)
4. Enter your unlock code given by GsmFather.com server and press ok
5. The phone will then reboot and your phone will be unlocked.
Model : All other model
1 - Switch ON your phone with an Allowed SIM Card,
2 - Then compose :
2945#*5101# - (if you have a LG 510w)
1945#*5101# - (if you have a LG 1200 & B1200)
2945#*5221# - (if you have a LG 5200 & 52200)
2945#*5301# - (if you have a LG 5300)
2945#*5401# - (if you have a LG 5400)
2945#*70001# - (if you have a LG 7020)
2945#*7101# - (if you have a LG 7100)
2945#*1201# or 2945#*70001# - (if you have a LG 1100)
2945#*70001# - (if you have a LG7250T)
2945#*2201# - (if you have a LG C2200)
2945#*5301# - (if you have a LG T5100)
2945#*3311# - (if you have a LG C3310)
3 - Go to "Menu" and then to "Settings",
4 - Then select "Security",
5 - To finish select "Network Provider" and select "Desactivate"
6 - Enter the Unlock Code we send to you.
Model : To Classify
For the next models u must to insert the original SIM:
LG C3100 press 2945#*3101#
LG C3380 press 2945#*7101#
LG F2300 press 2945#*7101#
LG KE260 press 2945#*2601#
LG KE970 press 2945#*9701#
LG KG120 press 2945#*1201#
LG KG220 press 2945#*1201#
LG KG240 press 2945#*3311#
LG KG280 press 2945#*7101#
LG KG290 press 2945#*7101#
LG KG800 press 2945#*7101#
LG KU250 press 2945#*250#
LG KU380 press 2945#*380#
After that will appear an secret menu,go to settings-security- sim lock ,enter NCK and press OK.
For next models insert one SIM ,not the original SIM:
LG KU311 press 815118#*#
LG KU800 press 82652#*#
LG L600v press 815
The Following 2 Users Say Thank You to Ron2pet For This Useful Post:
Old 02-20-2008, 15:43   #9 (permalink)
Ron2pet's Avatar
Member: 17609
Sonork: 100.64817
Thanks Meter: 1,694
How to enter my Unlock Code on Mitsubishi ?
Model : Trium Mars
1 - Swith ON your phone without SIM Card,
2 - Press * and without release compose : 787090 or 787292,
3 - The menu "Unlock Network" will appear,
4 - Select "YES" and enter the Unlock we send to you.
Model : Mitsubishi M341i
1 - Swith ON your phone with an Accepted SIM Card,
2 - Press * and without release compose : 787292,
Model : Mitsubishi M342i
2 - Press * and without release compose : 787090,
Model : All Mitsubishi
2 - Press * and without release compose : 787292 or 78729,
Old 02-20-2008, 15:44   #10 (permalink)
Ron2pet's Avatar
Member: 17609
Sonork: 100.64817
Thanks Meter: 1,694
How to enter my Unlock Code on Motorola ?
Model : All Motorola
2 - Phone show "Enter Special Code",
3 - You can now enter the Unlock Code we send to you.
WARNING : If one of theses messages appear :
- "Contact Service Provider"
- "Tampert Alter"
- "Wait before enter special Code"
- "Contact Service'
It's because you or somebody allready enter too many wrong codes, you just have to let phone ON on theses errors messages and after 40 min to 2 hours maximum the message "Enter Code Special" will appear again !
Model : Motorola Z8 A1000 and other A series models (Symbian UIQ operating system phones)
1 - Click on the icon Phone
2 - Enter the following keys: ** 057 *
3 - Mobile displays "locking enter personalization"
4 - Enter the unlock code
5 - Click Ok
Model : Motorola L6i & L7i (not L6 and L7 without "i")
1 - Press and hold "*" key by dialing code 787090
2 - The mobile displays: "Menu. Network"
3 - Choose 'yes' and then press OK
4 - The mobile ask you for code
5 - Enter the code for unlocking.
Model : v3xxr boot 6.24
1-insert original AT&T sim or test sim,and turn flight mode on
2-conect charger,and turn the phone on
3-during the phone start on just press c bottum
4-wait for small time (5 to 20 min) and dont close the flip
you will see on screen enter subsidy password
enter the 16 digits code you got from Gsmfather.com server
the phone is unlocked
5-turn the flight mode off
6-restart
Old 02-20-2008, 15:45   #11 (permalink)
Ron2pet's Avatar
Member: 17609
Sonork: 100.64817
Thanks Meter: 1,694
How to enter my Unlock Code on NEC ?
Model : Nec N342i
2 - Compose : **00012*CODE#.
Model : All others NEC
2 - Compose : #7320*CODE#.
Model : old NEC
2 - Compose : #3210*CODE# and press Call Button.
Old 02-20-2008, 15:46   #12 (permalink)
Ron2pet's Avatar
Member: 17609
Sonork: 100.64817
Thanks Meter: 1,694
How to enter my Unlock Code on Nokia ?
Model : All Nokia
2 - Compose #PW+CODE+1#
The letter P appear after press 3 times quickly the button star ( * )
The letter W appear after press 4 times quickly the button star ( * )
The letter + appear after press 2 times quickly the button star ( * )
3 - The phone show "SIM Restriction Off" and was unlocked !
Old 02-20-2008, 15:47   #13 (permalink)
Ron2pet's Avatar
Member: 17609
Sonork: 100.64817
Thanks Meter: 1,694
How to enter my Unlock Code on Panasonic ?
Model : Panasonic GD67/68 & GD87/88 & x70 & P341i
2 - Compose : 746 and press 2 times the button "OK",
3 - A new menu will appear, select "NCK",
4 - You can now enter the Unlock Code we send to you.
Mode : Panasonic G60
1 - Switch ON your Phone with a not allowed Accepted SIM Card
2 - Enter your PIN Code and Confirm
3 - Press a second time on OK button
4 - The phone now ask for Unlock Code !
Model : Panasonic GD50 & GD55
Model : Panasonic X60 & X400
1 - Switch ON your phone with an Accepted SIM Card,
2 - Compose : 52824**,
or
3 - Compose : 746 and press 2 times the button "OK",
4 - A new menu will appear, select "NCK",
5 - You can now enter the Unlock Code we send to you.
Model : Panasonic X100
2 - Compose : #*7465625*638*CODE#
Old 02-20-2008, 15:47   #14 (permalink)
Ron2pet's Avatar
Member: 17609
Sonork: 100.64817
Thanks Meter: 1,694
How to enter my Unlock Code on Philips ?
Model : All Philips
2 - Phone ask for "Enter NCK",
How to enter my Unlock Code on Pantech ?
1 - Insert non-accepted SIM card
2 - Power on the device
3 - The display will show "Change SIM" and Left Soft Key will be labeled "Unlock"
4 - Press Left Soft Key - A "Password" box will appear on display
5 - Enter Unlock Code
6 - Press "OK" - Center Soft Key
The device will display "rebooting" and then power cycle
7 - The device is now unlocked
Old 02-20-2008, 15:48   #15 (permalink)
Ron2pet's Avatar
Member: 17609
Sonork: 100.64817
Thanks Meter: 1,694
How to enter my Unlock Code on Sagem ?
Model : Sagem My-S7
2 - Compose : *#*#CODE# and press "Call" button.
Model : All Sagem
2 - Phone will show "SIM VERROU"
WARNING : if your mobile show "CODE POSTE" it's because you have a Security Code, can be 0000 or 1234 but we can't calculate this code with your IMEI because it's not code from Phone but code from the User of the Phone !
The Following User Says Thank You to Ron2pet For This Useful Post:
How to enter unlock codes in samsung s3650, not accept codes when i enter,why? svchost NSPRO 22 05-07-2014 11:00
Cable Finder + Secret Code + How to Enter Unlock Code V 1.6 Ready !!! mughalG Universal GSM Software 17 11-04-2010 18:37
how to enter unlock code in modem after getting unlock code from MXKEY (Answered) NAVEED74 MXKEY FREE ADD-ONS: HTC Unlocker, HUAWEI and VODAFONE MODEMS Unlocker 1 03-06-2010 14:25
************* How to enter unlock codes -=- How to Master Reset & More************ F C Xpresscodes.com 4 06-09-2009 01:58
[FAQ] Code by IMEI : How to enter Unlocking Code on my Mobile Phone ? UnlockBase.com UnlockBase 93 08-06-2008 14:59
Page generated in 0.31282 seconds with 9 queries
