![]() ![]() Join Date: May 2007
Member: 513415 Status: Offline Thanks: 0
sendo s320 s1 pinouts
Anybody has the correct pinouts for this model and procedure for flashing. Cannot find on the support site for its specific pinout.
Tia |
I used the s3xx jtag pinouts, now here's the log. The phone turns but errors. Any ideas?
Ready... Profile file not exist! Default file will be created Error! Default flex file C:\Program Files\Multibox\Sendo_Tool\Flex\320_S1.flx not exist! Operation aborted! Connecting to update server...OK Ready... Loading MCU file... File info: FW: SND320 S1 140-P-02.1 Oi LP:ENG ESP PORT MCU Firmware file loaded... Loading LP file... File info: LP: SND320 S1 140-P-02.1 Oi LP:ENG ESP PORT Language Pack file loaded... Loading CP and EEPROM file... File info: EEPROM SND320 S1 CP file loaded... Waiting for ignition...Timeout! Waiting for ignition...Timeout! Waiting for ignition....OK Reading phone info... No version data! IMEI reading error! IMEI: 000000-00-000000 Communication with phone timeout! Communication with box error! SIM Lock reading error! ERROR: 2 Waiting for ignition...Timeout! Last edited by pinoy_gsm; 02-21-2008 at 03:49. |
More infos:
Phone now is blocked. need to change the imei/simlock but then when trying to change always communication error. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2001
Member: 3610 Status: Offline Sonork: 100.54638
Check your cable first!
I succesfully update the firmware using the cable. I was using the jtag cable with 8wires soldered to the pcb. Is there any special pinout for s320_s1, since its not exactly the same as the s2xx_s3xx pcb layout on the support site?
Tia |
Make a PCB photo please we try to help you on it
