Sagem Hardware Repair Area All the Discussions for Repairing Sagem Phones are located here, No software Probelms you can find, all inside are Hardware Problems. |
07-27-2002, 20:07 | #1 (permalink) |
Freak Poster Join Date: Jan 2002 Location: Moldova Age: 44
Member: 8442 Status: Offline Thanks Meter: 0 | Battery tatus unknown!? I have 4 Sagem 922 with the same problem: “Battery unknown!” when turn on. Phones also don’t take charge. I changed charging controller, but nothing. Anybody knows how to repair this? IS NOT BATTERY CONTANTS PROBLEM!!! |
09-29-2003, 15:17 | #3 (permalink) |
Junior Member Join Date: Feb 2003 Location: Ukraine Age: 49
Member: 22505 Status: Offline Thanks Meter: 0 | I have no solution, but some time ago I have problem with outgoing calls with not good akku. Well, after add capacitor to the supply one (yellow under lcd - 477) phone write - "unknow battery" May be it help you. |
09-29-2003, 18:19 | #4 (permalink) |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,552 | ... Hi ! I got read of this problem by rewritting the eeprom on both m41/m51. But not allways this problem come from bad eep settings. best regards, .:hack3r2k:. |
09-29-2003, 18:31 | #5 (permalink) |
No Life Poster Join Date: Apr 2002 Location: Flash Age: 44
Member: 11208 Status: Offline Thanks Meter: 11 | Hey. Check the backside 4 baterey connector for baterey. All of them can fully touching surface. Also change baterey. Check your charger. Hopes it can help |
10-07-2003, 22:14 | #8 (permalink) |
Freak Poster Join Date: Jun 2002 Location: Georgia Tbilisi Age: 47
Member: 12524 Status: Offline Thanks Meter: 3 | if any have pictures for sagem board i send repear solution please send board pictures [email protected] |
12-10-2003, 06:21 | #9 (permalink) |
No Life Poster Join Date: Jan 2003 Location: Iassy Age: 59
Member: 19723 Status: Offline Thanks Meter: 359 | Your mail is not working !!! ([email protected]) |
12-10-2003, 19:25 | #10 (permalink) |
No Life Poster Join Date: Jun 2002 Location: East Europe Age: 51
Member: 12837 Status: Offline Thanks Meter: 2,740 | Battery status unknow... Hi2all The problem occurrence while phone can't read battery ID resistor... Possible cause is a: bad battery ID resistor (change batt!); bad wireing between batt connector and ASIC chip - for 9xx chip is SAGEM 18599662-5 ( check wires and resolder all connected components); bad ASIC chip ( change/resolder ASIC); Bad PCB - destroyed or some deformation(no solution!); |
03-30-2004, 09:15 | #11 (permalink) |
Member: 22505 Status: Offline Thanks Meter: 0 | Problem solved. (At Mx9xx. But i think at other models not big difference) Battery Pin-out: 1- +Vbatt 2- -Vbatt (Gnd) 3- Indicator battery type 4- At board must be closed to GND Beetwen pin 3 and 4 at battery set resistor. Resistance - battery type . I have two type - 7k5 and 13k. At board set capasitor. Pin 3 through fuse or resistor (0 ohm) (white or black smd near pin 3 ) go to the 21 pin interface IC (18599662-5). The resistence beetwen pin 3 and GND on board must been 150 - 2500 ohm. Chek all this values. And good luck. P.S. At my board resistence beetwen pin 3 and GND go to Mohms. And after change interface IC all problems solved. |
Thread Tools | |
Display Modes | |
CloneFlashs / Ot310_BF3 -Unknown Lang Pack / Operator: Unknown- | 3umer | Multi-Box | 0 | 10-07-2007 12:19 |
Myx5-battery status unknown | valibuzauro | ARM9 BASED M62 / M62+ | 0 | 02-27-2005 10:32 |
MC926 battery unknown | ataman | Infineon C16X M51 & ARM7 M52 BASED | 3 | 01-25-2004 19:32 |
sagem mc922 battery unknown | OMBOSSMAN | Infineon C16X M51 & ARM7 M52 BASED | 4 | 12-01-2002 14:49 |
Help please - BATTERY UNKNOWN on Sagem 735 | Chulitmg | Infineon C16X M51 & ARM7 M52 BASED | 3 | 10-30-2002 23:00 |
