Old 07-31-2002, 14:20   #1
farsands
Member: 11508
BE1 "batt. charge impossible!"
Hello! How to fix this problem or where can I get service manual, anyone?
[GLOW=crimson]wrong section moved from Alcatel BE1-BE5 [/GLOW]
Old 07-31-2002, 20:56   #2
mr_x4you
mr_x4you's Avatar
Member: 4989
Try clean battery contacts !
Old 07-31-2002, 23:54   #3
farsands
Member: 11508
Hi! Thanks for your reply.
Have cleaned all contacts and even replaced external charging interface. Sometimes, even with newly charged battery, the unit does not power on but after a while I try it again and then it powers on. Once on, the unit works fine, but it still does not charge. I think I have to look further than batt. contacts...what next?
Old 08-01-2002, 00:55   #4
GSMlearner
Member: 3876
change ic PTWL2207
Old 08-01-2002, 07:10   #5
george gsm
george gsm's Avatar
Member: 14200
hi,
take in this order:
1. clean the contacts conector & board . clean contacts of batery(see mr_x4you answer)
2. repair soft. if u have not soft 4 this send a mail to geogsm@yahoo.com and i will reply
3. change power ic (see GSMleaner's answer)
geo
Old 08-01-2002, 14:22   #6
cosmo
Member: 3262
Hi!
I think Your problem is software cose It happend many times to me! Contact me on icq: 149039664! I will help U!
My best regards to all!
cosmo
Old 08-01-2002, 14:55   #7
mr_x4you
mr_x4you's Avatar
Member: 4989
Try to unlock it again with Andromeda, sometime works ! If not try repair with Mihnea flashes !
Old 06-12-2003, 07:19   #8
iqballk
iqballk's Avatar
Member: 13932
Replace your battery..., if not, change big Capacitor..
Old 06-12-2003, 08:14   #9
Syed
Moderator
Syed's Avatar
Member: 19979
these are the problems for Batter Charge Not possible problem
1) Software
2) Power IC
3) Chinese made battery...(use original battery)
.... rest is yet 2 be found...
regards
Old 06-13-2003, 00:06   #10
ukaryagar
Member: 26583
charge problemi...
hello from TURKEY...
CHARGE PROBLEM FOR BE1 AND BE3...
ONLY WAY .....YOU CHANGE IC PTWL 2207....
TAKE CARE...
www.interfon.8m.com
Old 06-16-2003, 10:34   #11
robba
robba's Avatar
Member: 16275
what if if the fone is indicating that it s charging by itself i.e without being connected to the charger could power ic replacemnt solve this?
Old 06-16-2003, 15:46   #12
farsands
Member: 11508
Hello!
Thanks for your replies....You happen to have schematics/service manual? That would help a great deal!
Sandy
Old 06-16-2003, 15:56   #13
farsands
Member: 11508
Hello Robba!
In principle, charging indicator showing charging but without charger means the charging control IC or switch is defective...there is a short...if only I can get a schematics/diagram for that to help locate the part (or the adjoining resistors/gnd connect/capacitor to replace), then I can fix it.
Sandy
Old 06-20-2003, 12:38   #14
robba
robba's Avatar
Member: 16275
@ farsands
this should help in schematics
Old 06-21-2003, 09:54   #15
megone
megone's Avatar
Member: 31594
hi is a hard problem, no soft. try replace power ic whith another one.
Page generated in 1.44036 seconds with 6 queries
