PadFinder box Smart universal box for Chinese phones ( for all phones ) with automatic pinouts search functions. |
03-24-2008, 17:10 | #1 (permalink) |
No Life Poster Join Date: Mar 2001 Age: 43
Member: 3610 Status: Offline Sonork: 100.54638 Thanks Meter: 1,652 | PadFinder pinout detection procedure PadFinder is a hardware module with the special software that detects Rx and Tx signals for different handsets in both ways: manualy and automatically. Apart from the cables coming in PadFinder's complect, the device can work with all known RJ45 cables. It can be used as a universal interface for the cables you already have at your disposal. PadFinder should be registered and activated ( click to see the manual ). Activation process is automatic and may take couple of minutes. Before start working with the phone, the battery should be removed, because the phone takes power from PadFinder. PINOUT DETECTION PROCEDURE 1. Connect PadFinder to PC via USB AB cable 2. Plug DB26 (26 pins) to "SPECIAL" socket. 3. Plug the appropriate phone connector to the phone input. 4. Remove phone battery! 5. Using power wires from DB26 connect them insted of battery "+" (red) power wire must be connected to phone "+" contact "-" (black) power wire must be connected to phone "-" contact IMPORTANT: After you have connected the power wires instead of battery, look attentively to the box LED: if the RED LED is blinking, YOU HAVE CONNECTED THE POWER WIRES INCORRECT! You WILL NOT be able to start the Main Program and find the pinout! 6. You may check the power wires connections. For this you need to: - Run Main tool - Press Power (VCC) "ON" - Press and hold "power" button on the telephone * If the handset Powers ON, than power wires are connected correctly and you can start the pinout detection process. * If the handset can't Power ON, than the power wires are connected incorrectly and you need to double check power wires. 7. Start the Main service tool. IMPORTANT: PadFinder has two Modes: Command Mode and Unibox Mode. "Command Mode" must be chosen for searching for the pinout. For unlocking/flashing the phone you must switch to "Unibox Mode" and run the necessary service tool. 8. Detect the appropriate "Cable type" 9. Select the CPU type. In most cases "Chinese" phone you can use default selected value: "MTK62xx" 10. Press "Search" button. You will see the information message that you need to PRESS AND HOLD phone "Power" button. 11. Press phone "Power" button and keep it pressed during the whole pinout detection process. 12. You will see the detected Rx and Tx pins. 13. You can also save the found pinout and name the model, so the next time you don't need to search it again! 14. Now you can use the found/selected pinouts configuration to work with any flashing/unlock software ( for instance, "Multi-box Chinese cocktail" ) |
07-22-2008, 20:21 | #4 (permalink) |
Registered User Join Date: Feb 2006 Location: tagum,davao philippines
Member: 231606 Status: Offline Sonork: cellphone_training@yahoo. Thanks Meter: 64 | thank you so much i try this procedure and really works hope you give also the procedure on how to use the china cocktail and speadtrum software..........step by step allso |
07-22-2008, 20:33 | #5 (permalink) |
Member: 231606 Status: Offline Sonork: cellphone_training@yahoo. Thanks Meter: 64 | where is your procedure in using china cock tail cos the detection procedure it works for me and easy coz its step by step but how about the procedure in using chinba cocktail and speadtrum coz after i detect the pin i close the padfinder main tool and open the china cocktail when i run it and click the connect button i always got this error 14. Now you can use the found/selected pinouts configuration to work with any flashing/unlock software ( for instance, "Multi-box Chinese cocktail" ) Ready... Reconnecting power...OK Press and hold power on button...Timeout! |
07-22-2008, 20:50 | #6 (permalink) | |
Member: 3610 Status: Offline Sonork: 100.54638 Thanks Meter: 1,652 | Quote:
07-22-2008, 21:01 | #7 (permalink) |
Member: 231606 Status: Offline Sonork: cellphone_training@yahoo. Thanks Meter: 64 | thanks how about the multi box procedure sir i got already the procedure on detecting pin out, speadtrum guide,, how about the china cocktail procedure |
08-03-2008, 14:05 | #9 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Punjab , INDIA
Member: 153805 Status: Offline Thanks Meter: 325 | Sir I bought Padfinder 2 months ago.Now it failes to find any pin even of running phones.I tried on different PCs but fail.Is there any warranty or guaranty on Pad finder.Or can it be repaired. |
08-03-2008, 14:23 | #10 (permalink) | |
2. About warranty you have ask your reseller 3. If you have any problem with box - send first all details to support team for checking what is wrong | |
Thread Tools | |
Display Modes | |
<<< Instruction : PINOUT DETECTION >>> | VsH-GsM | MC-Tool | 26 | 12-05-2009 01:28 |
McnPro - Pinouts Detection Procedure - A Quick Scan Guide | Mcnbox | McnPro Box | 0 | 11-29-2008 21:00 |
Padfinder not detected | nmaq2003 | PadFinder box | 12 | 06-23-2008 14:59 |
Meet PadFinder - absolutely the best solution for all problems with pinout detection | SHANU | Main Sales Section | 0 | 03-30-2008 05:35 |
