Old 08-09-2002, 14:12   #1
iqballk
iqballk's Avatar
Member: 13932
Alcatel DB- 5 Phones 3 Problems...
1. Dispaly "SOS Calls Only".
2. Phone going to off mode after inserting a sim card.
3,4,5. Dead. When I insert a bettery, small sound appear (like "trick").
Old 08-10-2002, 05:24   #2
Magdi
Magdi's Avatar
Member: 14287
try to connect it to pc com1 and read it at andormida 5.9 after connect again and choose repair phone then take the battery off return it back see it will work if not contact methis can be done for all db
Old 08-10-2002, 14:53   #3
vanitas69
Member: 3620
If you can connect with try Mihnea sw, will do it.
Regards, Vanitas69
Old 08-11-2002, 05:37   #4
iqballk
iqballk's Avatar
Member: 13932
Where i can download Mihnea software
Old 08-13-2002, 02:03   #5
george gsm
george gsm's Avatar
Member: 14200
hi jqballk,
send your request at geogsm@yahoo.com or geo_gsm@hotmail.com
i will send all soft 4 this
geo
Old 08-14-2002, 21:02   #6
joe locks
Member: 6689
try this to repair
i have a few alctel with the same problem after a few sec check sim with sim inside i tried this
1 i read the phones flash with andromeda 5.7
2 reflashed with same flash
3 using repair function on anromeda i flashed one of the flash bins from minhea
and quess what the phones worked perfectly
Old 10-11-2002, 10:55   #7
iqballk
iqballk's Avatar
Member: 13932
when connecting 1+2+3 pins of ptw ic. Some phones on...
Old 10-11-2002, 19:01   #8
GSMsurgeon
GSMsurgeon's Avatar
Member: 6524
Friend
Replace power ic...
Old 10-12-2002, 13:46   #9
gsmsalers
Member: 11208
Hi.
Change flash ic. Most cases it is 1mb ic,some is 2 mbyte flash. Works for 3,4,5. Dead. When I insert a bettery, small sound appear (like "trick").
Old 10-13-2002, 06:26   #10
iqballk
iqballk's Avatar
Member: 13932
thanks for your reply..
Page generated in 0.07395 seconds with 6 queries
