Go Back   GSM-Forum > Product Support Sections > Hard/Software-Products (official support) > Advance Box > AdvanceBB5
Old 04-25-2008, 05:37   #1
ayhen42
ayhen42's Avatar
Member: 575851
I need v2.13 plssssssss
i have try to download the new version my advaance but cannot download yet what the problem my box i have to decide to all advance user plss give the new update for advance box i hpoe understand what i main sory foe english
Old 04-25-2008, 05:43   #2
userinfinity
Member: 679382
Yes check this...
Not Found
The requested URL /support/for_download/AdvanceBB5_Installer_v1.15.rar was not found on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
Old 04-25-2008, 05:47   #3
rea1One
rea1One's Avatar
Member: 236564
2.13 temporarily removed in support
@Advance users
Sorry, I temporarily removed the v2.13 in our support site. I will upload the latest version after few hours.
Brr,
ulymar
Old 04-25-2008, 09:27   #4
bronce
bronce's Avatar
Member: 488875
Sonork: 100.1583301
email to the product supporter,
they will help you......
Old 05-10-2008, 07:12   #5
jashun
Member: 564917
where the 2.13????????
Old 05-10-2008, 07:37   #6
Warptech
Member: 498524
Register on site, login and download 2.14 and 2.14a and all other files and your problem will be solved
Old 05-10-2008, 07:42   #7
Warptech
Member: 498524
//Software Installation
1. Download 2.14 from support site
2. Download 2.14a from support site
3. Download UFS2XX.rar
4. Extract 2.14 to your PC
5. Put dll from inside UFS2XX.rar into where you extract 2.14
6. Extract 2.14a, then put the contents into the folder where you extract 2.14 (overwrite old files)
7. Copy and paste Flash Loader.ini to Flash Folder (overwrite old files)
//Hardware Installation for AdvanceBB5 for DCT4+ FREE module
1. Connect AdvanceBB5 to ROOT USB Port of PC
2. Connect UFS Box to any USB port of the same PC (UFS box must be firmware 2.7 or lower)
3. Run AdvanceBox exe and wait for 7-10 seconds.
4. Click Icon on the Taskbar, then click DCT4+ tab
//Hardware Installation for AdvanceUFS for DCT4+ FREE module
** you need two pieces UFS box (no exemptions)
1. Connect two UFS boxes to your PC (UFS box firmware must be 2.7 or lower)
2. Connect AdvanceUFS Box to one of the UFS boxes connected (any will do)
B.R.
X-Shadow
Old 07-16-2008, 10:33   #8
Zukison14
Member: 221355
I just got Advance BB5, which files do I download? What would be the installation procedure. I am asking because I already installed everything from support and it is not working. Please advice.
Old 07-16-2008, 14:41   #9
Advance-Box
Advance-Box's Avatar
Member: 651945
@Zukison14
What is the ERROR that you are experiencing?
Can you explain further?
B.R.
X-Shadow
Old 07-16-2008, 15:53   #10
denisirias
denisirias's Avatar
Member: 309299
i just got 2.12 and 2.14 here are the links of versions i got maybe one of those could help you
http://rapidshare.com/files/12789774...eBox_v2.12.rar
http://rapidshare.com/files/12789774...eBox_v2.14.rar
http://rapidshare.com/files/12789774...eBox_v2.15.rar
http://rapidshare.com/files/12789774...eBox_v2.16.rar
http://rapidshare.com/files/12789775...eBox_v2.17.rar
http://rapidshare.com/files/12789775...eBox_v2.18.rar
http://rapidshare.com/files/12813042...eBox_v2.19.rar
http://rapidshare.com/files/12917013...eBox_v2.20.rar
Old 07-16-2008, 23:59   #11
Zukison14
Member: 221355
Advance-Box
I installed the following:
Advancebb5 Interface Driver
Advancebox Usb Drivers
Ufs2xx
I connected the box and installed the drivers. I then try to open AdvanceBox and I get the following: Advancebox Not Found
Please advice.
Old 07-17-2008, 17:46   #12
Zukison14
Member: 221355
Advance-Box
Ufs2xx
Please advice.
Old 07-19-2008, 01:57   #13
Zukison14
Member: 221355
Advance-Box
Would you provide some assistance with installing this box. I have been reading throughout the forum and I can't just figure out what I am doing wrong.
Old 07-19-2008, 14:14   #14
Advance-Box
Member: 651945
@Zukison14
Why are you trying to install 2.13? The latest version is already 2.20 ;-)
1. Go here: www.advance-box.com
2. Create Username Login for Support Section.
3. Download the following inside Support Section:
Advancebox V2.17 <-- all-in-one installer
Advancebox V2.20 <-- latest exe update
Pdf V10 Final <-- user manual
4. Extract V2.17 and run the Installer Package.
5. After Installation, extract V2.20 to a new folder.
6. Connect AdvanceBB5 Box to USB port.
7. Right Click "My Computer" select Properties then Select "Device Manager"
*** You should find "AdvanceBox Interface" under the USB Connections.
If you can't find "AdvanceBox Interface in the USB Connections, then it means
you have not properly installed the Supplied Driver for your BOX.
To fix this, just right click "AdvanceBox Interface" then select Update Driver, then
select the driver that came inside "V2.17".
8. Run the AdvanceBox.exe inside the 2.20 extracted files.
Now you will be running the latest version.
If you still cannot load the AdvanceBox software, then try to install a standard
UFS Box to your PC. After installing the drivers for the UFS box, try to run the
AdvanceBox.exe again.
B.R.
X-Shadow
Old 07-21-2008, 02:59   #15
Zukison14
Member: 221355
X-Shadow
I followed your instructions exactly, but I still cannot make it to work. After I run the AdvanceBox.exe inside the 2.20 extracted files, the Feel The Power title appears and then after 10 seconds the software appears for one second and dissappears.
I have noticed that my UFS\HWK software is freezing when I try to initialize it.
Am I having problems because I have in my computer installed UFS\HWK, MT-Box, Cruiser Suite, Vygis, or SeTools?
I would appreciate some advice from your part. Thanks.
Page generated in 0.09781 seconds with 6 queries
