Member: 532005 Status: Offline Thanks: 0
problems with dell bluetooth 355 module..
I have a M1330 with vista on it and the widcomm bluetooth drivers (I have also tried the newest anycom drivers). Problem is this, i have a bt microsoft wireless presenter 8000 mouse and bluetooth motorola BT820 headphones. Individually both work perfectly, but if i try to use them both at the same time the headphones skip quite often. I have read that you can have something crazy like 78 bluetooth devices connected so i am wondering why 2 are giving me problems? is there anyway to tweak the bluetooth module to work with this stuff or anything at all i can do to make both of these work well at the same time?
![]() ![]() ![]() Join Date: Sep 2005
Member: 177301 Status: Offline Thanks: 17
The Bluetooth 2.0 bandwidth is not sufficient to sustain A2DP + almost any other bluetooth devices. My suggestion is either give up using other BT devices while listening to the music, or get a earphone phone that only tranmits mono channel.
PS. I am using my BT355 with Logitech MX5000 keyboard/mice combo. That pretty much eats up the bandwidth of the module. |
thats strange because my anycom usb adapter can do it, its just the dell module that cant...
![]() Join Date: Aug 2005
Member: 170891 Status: Offline Thanks: 1
check the Audio tab in your bluetooth devices window.
if dell has installed both stereo audio and telephony device for your motorola headset, just remove telephony device and then connect to headset. this worked for me as I also was getting skips on my SE HBH-DS970 headset |
