Go Back   GSM-Forum > GSM Mobile Brands -Software Area- > Samsung > Trident/AGERE Platform
Trident/AGERE Platform C200, C210, C225, C230, D100, D410, D415, D418, D428, D520, D825, D710, D720, D730, E105, E300, E310, E315, E316, E318, E360, E400, E530, E600, E608, E610, E620, E650, E658, E710, E715, E718,E720, E728, E750, E770, E810, E818, E850, E860, E880, Q100, Q105, Q200, Q300, Q400, Q605, I700, N700, P100, P108, P400, P408, P710, P718, P720, P730, P738, P777, S100, S105, S108, S200,S 208,S300, S300m, S341, S342, S400, S400i, S410i, S500i, V100, V200, V205, V208, VE888 , X105, X120, X130, X140, X150, X200, X400, X408, X426, X430, X438, X450, X458, X480, X610, X630, X640, X710, X475, X630, X660, X700, X800, X900.
Old 04-29-2008, 13:04   #1
crack3war
crack3war's Avatar
Member: 179308
Talking Samsung's unlocking for FREE (J700 :D)
This method is maybe known for some of you , i test it for some models (like E250 ,J700 ..) and i think , it can work for all other models ..
It's easy ,no risk at all , no cable , no drivers , but need to be handled well
Today i test it on J700 , as we know ,many of us have a bad result after using box to unlock that fone ,, (bad Imei ,bad BT adress ... ) but with this method ,, EVERYTHING is FiNe
1- Power on fone ,, type : *#7465625#
you will identify wich code is active , wich is inactive
2- Remove battery ,, Put your sim card , not all of it ,, just to prepare it to be full inserted , put your battery back and power on fone ,, you must see " insert sim" not "invalid sim.."
3- type : *2767*3855#
your fone should restart after 1 min ,,
now ,, and before it restart , push your sim card ,,without removing battery
4- your fone should work and accept the sim card ,, but if you chek locks you will find that your fone is still Loked
5- now type : *7465685*638*00000000*00000000#
your UNLOCK CODE is 00000000 now , hh Enjoy
6- now , back to Locks table with : *#7465625# ,, and for each active code you can disable it ,,,here details :
* Disables CP lock : #7465625*27*00000000#
* Disables Network lock : #7465625*638*00000000#
* Disables SIM lock : #7465625*746*00000000#
* Disables SP lock : #7465625*77*00000000#
* Disables Subset lock : #7465625*782*00000000#
I wish It help ,
Regards
Old 04-29-2008, 13:13   #2
Uvedovle
Uvedovle's Avatar
Member: 10905
i´ll test it!!
Wbr
Old 04-29-2008, 13:16   #3
f164
Member: 184351
I wish It help ,
Regards
for your method we must use an external power supply for sim inserting
The Following User Says Thank You to f164 For This Useful Post:
Old 04-29-2008, 13:49   #4
crack3war
crack3war's Avatar
Member: 179308
Thanks for reply
It's easy to insert sim back .. i think no need to power supply
The Following User Says Thank You to crack3war For This Useful Post:
Old 05-01-2008, 19:54   #5
*phone-company*
*phone-company*'s Avatar
Member: 60001
Sonork: 100.106474
well, this method is well known but this can only unlock NETLOCK not SP or other locks. anyway...maybe it helps some customers. Thanks for posting this solution
Old 08-04-2008, 17:06   #6
ziiyyaad
ziiyyaad's Avatar
Member: 175945
Sonork: ziiyyaad
wonderful!!!! Help me to save money to buy cable!!! Coooooool!!
Old 08-04-2008, 19:17   #7
ziiyyaad
ziiyyaad's Avatar
Member: 175945
Sonork: ziiyyaad
yes not working on a c180...
Old 08-04-2008, 19:27   #8
ziiyyaad
ziiyyaad's Avatar
Member: 175945
Sonork: ziiyyaad
wow!!! crack3war mega thanks... You have open my mind!!!!
Old 08-06-2008, 11:25   #9
globalsystem
globalsystem's Avatar
Member: 521295
Sonork: 150.150.10.20:80
i think that a risk to loste imei or eprom damage.can you confirme that no risk?
Old 08-06-2008, 11:35   #10
themoomin
themoomin's Avatar
Member: 59751
Sonork: 100.63504
carefull with imei sometimes it can make imei 0000000000000000's
Old 08-06-2008, 17:17   #11
ziiyyaad
ziiyyaad's Avatar
Member: 175945
Sonork: ziiyyaad
j750 not work!!!!! tried today...
Old 08-06-2008, 17:36   #12
abdulwajid147
abdulwajid147's Avatar
Member: 213172
Sonork: 1582799
use original Tools and softwares .dont take tension of cracks and fack tricks......
Old 08-06-2008, 17:41   #13
mamepap
Member: 532853
the past week it work well for me with 2 j700 1 e250v and 1 c180 and imei were perfectly.
Old 08-12-2008, 13:55   #14
satcomhedi
satcomhedi's Avatar
Member: 72925
i tryed with E250, and i have imei 0000000000000
Old 08-15-2008, 11:34   #15
john45
Member: 100651
Great solution!
Saved me buying a new cable, tried it on a new Purple J700V just purchased from the UK, with Network lock only.
Respect to you Crack3war!
John 45
The Following User Says Thank You to john45 For This Useful Post:
[IMG] code is Off
Page generated in 0.10420 seconds with 6 queries
