![]() ![]() ![]() ![]() Join Date: May 2007
Member: 509348 Status: Offline Thanks: 1
experts or seniors never help juniors like me
i requested a post for help for chinese fault but noone can help me is there is nothing values for juniors
i have a chinese phone a common model v180 when i switch on the handset with sim itswitches off after 4 or 5 seconds plz note that it doesn't restarts, it switches off and when i switch on the handset without sim it doesn't switch off but but but when we dial 112 or any other emergency call without sim it also shut down that whole means it also shut down without sim on calling so plzzzzzzzzz everyone help me and tellme the solution for this fault i formatt it but same result i also flash it by reading flash and eeprom from same set which works fine but the fault remain same plzzzz help me
Member: 102598 Status: Offline Thanks: 16
First U Change Bettery If Not Done Formet Ffs If Not Done Full Flash Ur Fone With Repair Eeprom
i have more than 10 handsets with same fault i done allthis but remain same
![]() ![]() ![]() ![]() ![]() Join Date: Oct 2005
Member: 190344 Status: Offline Thanks: 737
for all china models that works ok with out sim but restarts when sim is inserted, for those mobiles to repair , you need to have , infinity/spiderman,vpro like devices and just format the set , you handset will be ok in a few seconds. iam using vpro that works good for me.
any thing else you want to know....wel come. br hamid |
dear sir my handsets couldnot restart it switches off
you mean when you insert the sim it goes into searching then power off and power on or restarts but with out sim works ok?
or your sets are completely dead? |
when i switch on the handset with sim it switches off after 3 or 5 seconds when i switch on the set without sim it doesn't off but when i call 112 it shut down
![]() ![]() ![]() ![]() Join Date: Jun 2006
Member: 287529 Status: Offline Thanks: 6
its software problem my friend.Just format your phone,all will be ok.Before format don't forget to take flash backup of your phone.
![]() ![]() ![]() Join Date: Feb 2006
Member: 233949 Status: Offline Thanks: 24
phone restart
use infinity , make backup and format your phone. simple and your phone will be ok....
. i did it everytime
![]() ![]() ![]() ![]() Join Date: Apr 2008
Member: 740993 Status: Offline Thanks: 9
according to me if phone is switching off while dialing 112 without sim then it is hardware fault ,,, if phone restart then only its software fault ,, in ur case check ur network section .. ......
br smartengg |
![]() ![]() ![]() ![]() ![]() Join Date: Mar 2007
Member: 478791 Status: Offline Thanks: 102
brother change pfo 1000000 pfo is shourt ...................try and happy did many of phones ..............post results here .........wbr varun |
sir will u plz post pfo location in the board sorry i am unexperienced plz help me
