Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Nokia Fault Finder Box
Old 05-10-2008, 14:47   #1 (permalink)
Member: 765141
Thanks Meter: 661
Frequently Asked Questions ( Instalation Problems etc )
When you run NFF software, logo appears and then closes and nothing happens then
Cause of problem
1) Either you have not installed Main Setup software 3.0
2) Either you have not upgraded your dongle using dongle upgrade tool
3) Driver for dongle is conflicting
Solution :
1) Install Main Setup software 3.0 and then install updates
2) Download dongle upgrade tool and upgrade your dongle , dongle upgrade tool will display dongle Serial and version
Latest firmware version of dongle is version 2.0
3) You need to uninstall dongle driver and install again to solve driver conflicting
How to Uninstall and Reinstall dongle drivers
To Uninstall
1) Remove dongle from PC
2) Go to Control Panel > System > Hardware > Device Manager > Smart card readers > egate USB Smart card readers
Right click on egate USB Smart card readers and select uninstall , Press Ok to confirm uninstall
To Install driver
1) Connect Dongle to PC
2) Your PC will detect new hardware
3) Either it will install driver automaticaly or It will ask you for driver
4) Give the link where driver is located and let your PC install the driver
5) Run NFF.exe and all will be ok
The Following User Says Thank You to NFF Box Team For This Useful Post:
Old 08-26-2008, 10:08   #2 (permalink)
Member: 765141
Thanks Meter: 661
Problem
When you run dongle update tool to upgrade your dongle you get an error
Dongle upgrade started:3:25:17 PM----------
Locating Emeralda server...
Emeralda server found!
Connecting to Emeralda server...
Connection to server failed: Socket Error # 10060
Connection timed out.
Solution
Contact [email protected] with this log
Problem
When you try to upgrade your dongle you get this error
--------Dongle upgrade started:11:45:11----------
Server connection successfully established.
Authenticating on server...
Authentication stage error: Server reported error:No more upgrade logs.
Solution :
Contact [email protected] with this log and your dongle serial number
we will answer you with repair instructions
Old 08-26-2008, 10:27   #3 (permalink)
Member: 765141
Thanks Meter: 661
Download problems and Virus detection problems
How to get access to Support area ?
You need to download supporter.exe from HERE
Install dongle driver
Open Supporter.exe application and click enter
Your broswer will open and take you inside support area
When I try to download supporter.exe or any other software
my Antivirus detects Virus what should i do ?
we can guanratee you there is NO Virus in our software
Antivirus detects virus because it scans internal code of
our software, our software codes have loops wich is
missinterpreted by antivirus software as virus
Solution
Disable antivirus and perform download and instalation
of NFF Box softwares
F.A.Q., Contacts, Supported models, Cables/pinouts InfinitySupport Infinity-Box 7 08-05-2015 15:57
[FAQ] FuriousGold - Frequently Asked Questions !!! READ BEFORE ASKING ANYTHING ! .:hack3r2k:. FuriousGold 4 03-23-2011 08:03
F.A.Q - Frequently Asked Questions !!! READ BEFORE ASKING ANYTHING ! Mohsin-* FuriousGold 0 11-10-2008 16:00
Frequently Asked Questions SoftMobile MT-BOX 47 12-21-2007 10:03
F.A.Q - Frequently Asked Questions !!! READ BEFORE ASKING ANYTHING ! .:hack3r2k:. FuriousGold 0 08-02-2007 20:08
Page generated in 0.18705 seconds with 9 queries
