Go Back   GSM-Forum > GSM Mobile Brands -Software Area- > Chinese Models & Cloned Phones
Old 05-13-2008, 10:40   #1
PIMP1811
Member: 752431
white screen on chinesse phone..
hi can you pls give me a hint...how to solve white screen on china phone...
many phone i encounter like 6300,cect 123,mobile tv...same white screen..but both phone are working...you can call it...and can receive messages....
i try to format the phone...but still same problem...
is there any HW..tricks or solution...aside from replacing new lcd..
Old 05-13-2008, 20:04   #2
hasnut
Member: 242868
Smile
I have got same problems, what I do backup current one(in case of put it in same state), and flash it as much versions I have with that particular model.
so solution is try to get as much flash file as you can and flash it until it solved.
No hardware tricks or changing lcd.
Old 05-14-2008, 22:07   #3
InfinitySupport
Member: 130995
You must flash phone with another firmware that will be suitable for your phone LCD type.
Old 05-19-2008, 15:37   #4
bathri525
Member: 698055
Bro Change U R Lcd This Will Slove Problem 100%
Old 05-21-2008, 01:12   #5
hasnut
Member: 242868
Changing LCD is not solution here. Its problem with Flash file as we need to flash it with the flash file that matches with the LCD.
Old 05-26-2008, 17:03   #6
bathri525
Member: 698055
bro u come to undersand that u r phone is working thatsall u said ,the chines phone display stripe r very weak one u remove it will damage. i got same problem then i changed lcd it ok try
Old 05-27-2008, 10:43   #7
shaheb_anl
shaheb_anl's Avatar
Member: 622382
change ur lcd 100% ok
Old 10-15-2008, 08:03   #8
malupet
Member: 152087
6300 china white screen after flashing
i have good 6300 china mtk BA i read the flash file then i reflash with the same files after...... dead i re flash to other flash files ok but white screen i change lcd but no luck ..... so there is something wrong with the files lcd is not good....to change
Old 10-15-2008, 10:13   #9
dhiraj_telecom
Member: 474118
brother just read eeprom fresh same china mobile and write another white light china phone and your phone 101% start normally
Old 10-15-2008, 17:55   #10
navin71
navin71's Avatar
Member: 101891
bro i solved cect and tv mobile white screen problem by replacing charging connector (just try to remove charging connector and than check if ok than replace it)
Old 10-25-2008, 10:35   #11
malupet
Member: 152087
still no luck
i did not mention that i used to flash my 6300 china in spider..... can you xplain... how to write eeprom to my china ..... i still believe that there is a solution for this phone best regard.......
Old 10-25-2008, 12:14   #12
sabir2008
Member: 872522
firstly check LCD pin and pasted.
Old 10-25-2008, 12:39   #13
omairbutt786
omairbutt786's Avatar
Member: 158032
Lightbulb china white lcd
Bro can you tell us what's the postion of your set when you got is it all ready on white screen or it's due to software if it happend with software the change the right firm ware if not then try to resold the lcd connector if not ok then use good flux paste and heat on the cpu and all will be ok try and post the result....take care...
Omairbutt786
Old 10-25-2008, 17:03   #14
abhi01
Member: 271106
always we need to see the no. of lcd otherewise it can't work
it is not confirmed if u have 2 sets same models same functions but lcd can be different
size & pins dose'nt matter main is lcd no. u have to see
i faced these problems many times but the last is same no. lcd then phone goes ok.
The Following User Says Thank You to abhi01 For This Useful Post:
Old 12-19-2008, 18:55   #15
yogesh_prj
Member: 604726
bro 100000000000000000000%%%%%%%%%%%%% sucses
hit cpu ic
Page generated in 0.12304 seconds with 6 queries
