05-18-2008, 16:25 | #1 (permalink) |
No Life Poster Join Date: Feb 2004 Age: 44
Member: 52956 Status: Offline Thanks Meter: 49 | ~~~strange error in K800!!! I have problem with 2 k800 here my log : -- Security Bypass-------------------------------------------- User selected phone K800 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 357315-01-******-6 OTP CID = 51 Error : Failed. THIS PHONE iS IN RED BLINK STATUE any body have idea? I change flash IC and test again but nothing changed!!! what is problem???????? |
05-19-2008, 07:57 | #3 (permalink) | |
Member: 52956 Status: Offline Thanks Meter: 49 | Quote:
here my log : [19/05/2008 18:14:49] --- Security Bypass------------------------------------------------------------ [19/05/2008 18:14:49] User selected phone K800 using Test Point boot mode [19/05/2008 18:14:50] Stage 1 started [19/05/2008 18:14:50] 1) Turn OFF the phone. [19/05/2008 18:14:50] 2) Connect the phone to DreamBox cable. [19/05/2008 18:14:50] Boot Responce = 5A [19/05/2008 18:14:50] Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) [19/05/2008 18:14:52] NOR Flash ID = 897E [19/05/2008 18:14:52] OTP Status = Open [19/05/2008 18:14:52] OTP IMEI = 048575-55-048575-4 [19/05/2008 18:14:52] OTP CID = 32783 [19/05/2008 18:14:52] Error : Failed. any idea???????? | |
05-19-2008, 08:24 | #4 (permalink) | |
Freak Poster Join Date: Feb 2005 Location: Ukraine Age: 44
Member: 117914 Status: Offline Thanks Meter: 96 | Quote:
Dream Box for the present moment can't work with Empty Flash IC, so You can use flash IC from the other phone (DB2020 platform) or use SeTool for empty flash IC (Empty Fill). Good luck. | |
05-19-2008, 08:58 | #5 (permalink) | |
I write that at first dream box show error with this log: -- Security Bypass-------------------------------------------- User selected phone K800 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 357315-01-******-6 OTP CID = 51 Error : Failed. and then I replace flash ic but again show same error so this error not depend to flash ic and attach log for empty flash ic what is problem ,I dont know but I know problem isnt depend on flash ic!!!! | |
05-19-2008, 09:09 | #7 (permalink) | |
phone ID cant read by setool at first and then after change I dont test it again with setool for connect and stages for EMPTY flash IC ... becuse I search for reason of this error becuse I have 2 K800 that is in situation (REd BLINK)but in connection show this error and again put first flash ic with imei and again same error | |
05-20-2008, 05:35 | #8 (permalink) |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | Till now i have 2 pcs K800 with same problem and haven't resolved... there is something that kill DB2020 flash IC-s in TP stage, but was to fast and i'm was behind scope and can't to catch it, so only new empty IC-s was solution at me and filling with SeTool... May be this IC-s with errors have some internal HW damage, may be not - no way to learn it - on each PCB ( K800 / K610 tested ) where was mounted after this for experiments - again appear same error . P.S. need to be correct - in both cases phone come with RED blink state - mean SW dead ... Dream recognise it on first "normal" reading ( Info ) but after try to repair it via TP - totaly go to unusable state. |
05-20-2008, 06:57 | #9 (permalink) | |
two phone at frist recognize by dreambox but at the end show error -- Security Bypass-------------------------------------------- User selected phone K800 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 357315-01-******-6 OTP CID = 51 Error : Failed ******************************************* ******************************************* 19/05/2008 18:14:49] --- Security Bypass------------------------------------------------------------ [19/05/2008 18:14:49] User selected phone K800 using Test Point boot mode [19/05/2008 18:14:50] Stage 1 started [19/05/2008 18:14:50] 1) Turn OFF the phone. [19/05/2008 18:14:50] 2) Connect the phone to DreamBox cable. [19/05/2008 18:14:50] Boot Responce = 5A [19/05/2008 18:14:50] Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) [19/05/2008 18:14:52] NOR Flash ID = 897E [19/05/2008 18:14:52] OTP Status = Open [19/05/2008 18:14:52] OTP IMEI = 048575-55-048575-4 [19/05/2008 18:14:52] OTP CID = 32783 [19/05/2008 18:14:52] Error : Failed. I see the pcb and for the first time be opend and I dont see any hardware problem ... I have this problem previously but not solved....... and for these phone I want to earch and find out were is problem if anybody have idea please share with us!!!!!!!!!!!! | |
05-20-2008, 11:01 | #10 (permalink) | ||
No Life Poster Join Date: Dec 2005
Member: 214480 Status: Offline Thanks Meter: 2,087 | Quote:
05-20-2008, 15:01 | #12 (permalink) |
Insane Poster Join Date: May 2006
Member: 273560 Status: Offline Thanks Meter: 8 | Gsm Lover2010: Yr Problem 100% In Ic Flash What"s The Solution: 1. normal And Good Heat On Ic Flash And Then Unlock And Security By Pass Procses 2.chang Yr Ic Flash With New Ic Flash And Empty Board Procduer With Se Tool Br Dream Gsm |
05-20-2008, 15:13 | #13 (permalink) | |
for2=======>>>>>>>I replaced but when see the error same as first error I replaced with first IC and not test it with setool I test it again (with EMPTY FILL with setool3 and post results) | |
guide me error in k800 | solution4mobile | Sony Ericsson Hardware Repair | 2 | 10-12-2009 08:55 |
Strange error on k800 | AbdulKadir | Universalbox | 1 | 06-30-2009 11:07 |
k800 strange error after flashing | RAND CELLULAR | Cruiser Suite | 6 | 10-21-2008 10:15 |
Strange Error in Nokia 6230i | sDinesh | Twisterflasher | 8 | 02-25-2006 19:01 |
