Go Back   GSM-Forum > GSM Mobile Brands -Software Area- > Nokia > Nokia Base Band 5 ( BB-5 )
Old 05-25-2008, 13:12   #1
ziiyyaad
ziiyyaad's Avatar
Member: 175945
Sonork: ziiyyaad
Smile FREE NFF Nokia fault Finder crack!!
FREE Nokia fault finder here..
Nokia fault finder crack....
For testing purposes only...
http://rapidshare.com/files/11746205...e_ziiyyaad.rar
http://rs317gc2.rapidshare.com/files...tup_v01.21.exe
Support Model List
DCT4 MODELS:
1100a, 1110i, 1208, 1650, 2112, 2255, 2280, 2300, 2310, 2600, 2600c-2, 2626,
2630, 2760, 2865, 2865i, 3100, 3105, 3220, 3230, 3586, 5140i, 6021, 6030,
6060, 6070, 6101, 6102, 6111, 6225, 6230i, 6235, 6235i, 6236, 6275, 6275i,
6310, 6310i, 6510, 6610, 6610i, 6800a, 7210, 7250, 7250i, 7260
WD2 MODELS:
6260, 6600, 6670, 7610, 7650, N-GAGE, N-GAGEQD
BB5 MODELS:
3110c, 3250, 3500c, 5200, 5300, 5310, 5610d, 5700, 6085, 6120,
6131, 6133, 6151, 6233, 6234, 6267, 6280, 6288, 6282, 6300, 6500c, 6680,
6681, 6682, 6682, 7370, N73-5, N76-1, N80, N81
3)Installation
2.a Run The Setup File
2.b After the setup is complete, NFF software is installed
In C:\Program Files\NFF
2.c Now Connect UFS box , when new hardware is detected &
driver Is requested by PC, you can browse to the folder
C:\Program Files\NFF\Driver\UFS Driver and select the driver
2.d Now Connect NFF Dongle , when new hardware is detected &
Driver is requested by PC, you can browse to the folder
C:\Program Files\NFF\Driver\E-Gate_W2k_XP_Vista
And select the driver.
Your Installation is now complete
4)Nokia Fault Finder Software Functions
What can Nokia Fault Finder detect?
• Problems with phones with NO Power
• Problems with phones that hang on startup
• Problem with phones with white screen
• Problem with Flash IC, Power IC, Processor IC, RAM IC
• Vibration , MIC, Sound, Sim lock Area, RF Signal
What can Nokia Fault Finder not detect?
• Phone that can not be detected by Software
• Phones with broken PCB
• Problems with phone with capacitors and transistors
• LCD Problem
To find Hardware fault in the phone
(See picture below 1, 2, and 3)
5)Frequently Asked Questions ( FAQ)
Q) When you run NFF.exe nothing opens
A) Dongle Driver not correctly installed
Or
Remove dongle from PC and connect again
6)Support
pass: ziad
BUY ORIGINAL!!!
1) Introduction
Nokia Fault Finder is unique software that detects hardware faults
in Nokia mobile phones. Further more it gives a picture of the PCB
with an estimated Percentage of fault detected by the software.
When a technician receives a Nokia phone for repairing his first step
can begin with making a hardware check by Nokia Fault Finder Software.
After he gets the result the technician can simply repair the IC reported
by the software. Thus saving his time and effort.
How to do:
1. Install this: http://rapidshare.com/files/11664973...01.21.exe.html
2. Keep original files, and extract above rar.
3. open $NFF.exe not the NFF.exe (to bypass self check CRC for NFF.exe)
Old 05-25-2008, 13:32   #2
ammuri1
Member: 460086
File not found. File not found.
Old 05-25-2008, 13:37   #3
asad_nomy7
Member: 570093
if we need to connect NFF dongle why u called its cracked.
The Following 7 Users Say Thank You to asad_nomy7 For This Useful Post:
Old 05-25-2008, 13:40   #4
ziiyyaad
ziiyyaad's Avatar
Member: 175945
Sonork: ziiyyaad
sorry
good link here
Old 05-25-2008, 13:41   #5
ziiyyaad
ziiyyaad's Avatar
Member: 175945
Sonork: ziiyyaad
no need dongle...
Dongle is only for securitiy, no need because it is cracked!
I should remove that part where dongle need to be connected, too late cannot edit post...
The Following 2 Users Say Thank You to ziiyyaad For This Useful Post:
Old 05-25-2008, 13:42   #6
mrfixit
mrfixit's Avatar
Member: 60899
error 404
file not found
upload again
tnx
edit:
its good now was bad copy of link with .... inside
Old 05-25-2008, 13:46   #7
GEEBOO
GEEBOO's Avatar
Member: 553840
file not found again send the good link....
Old 05-25-2008, 13:50   #8
concept
Member: 155399
please file password
Old 05-25-2008, 13:51   #9
bonusphone
Member: 749885
File not found too. Please the correct links.
Old 05-25-2008, 14:09   #10
ziiyyaad
ziiyyaad's Avatar
Member: 175945
Sonork: ziiyyaad
pass: ziad
already posted in main thread...
The Following 4 Users Say Thank You to ziiyyaad For This Useful Post:
Old 05-25-2008, 14:15   #11
asad_nomy7
Member: 570093
here is the good link and without password files.
http://forum.gsmhosting.com/vbb/showthread.php?t=542345
The Following User Says Thank You to asad_nomy7 For This Useful Post:
Old 05-25-2008, 14:28   #12
mrfixit
mrfixit's Avatar
Member: 60899
u linked to the same thread here, by mistake I guess
Old 05-25-2008, 14:32   #13
mobileunlockers
mobileunlockers's Avatar
Member: 396778
can we use this software with jaf box....thanks
The Following User Says Thank You to mobileunlockers For This Useful Post:
Old 05-25-2008, 14:40   #14
ziiyyaad
ziiyyaad's Avatar
Member: 175945
Sonork: ziiyyaad
working proof picture...
Old 05-25-2008, 14:51   #15
kopetsikopet
Member: 657603
Good working bro test by me
Page generated in 0.10288 seconds with 7 queries
