05-29-2008, 21:19 | #1 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Infinity-Box University project: Lessons What is this project: As we can see during last 10 years the avarage technical knowledge level of people who serve mobile phones become very low. In fact current avarage knowledge level become probably near 1% of avarage level of this kind of people 10 years ago. As a result we will try to make a free open University for people who has near zero educational level in mobile phone hardware, software and technology. What is the reason of this project: We hope that this project will helps us to avoid many strange questions in Infinity-Box support forum Here is discussion thread: http:///vbb/showthread.php?t=532406 Here will be Infinity-Box manuals in Arabic: http:///vbb/showthread.php?t=540730 Last edited by InfinitySupport; 05-29-2008 at 22:11. |
The Following 54 Users Say Thank You to InfinitySupport For This Useful Post: |
05-29-2008, 21:36 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Lesson #1: Rx, Tx, Gnd terms explanation There is an interface to connect different devices with name "serial" (different terms may be used for this interface such as UART, COM port and probably something else). Many mobile phones use "COM port" interface for flash, unlock and other operations. Three wires should be used to connect Box to Phone: 1. Rx (receive data) 2. Tx (transmit data) 3. Gnd (ground, common wire). If you want to connect Box to Phone you must connect wires this way: 1. Box Rx (receive) should be connected to phone Tx (transmit), so Box can receive data that was sent by Phone 2. Box Tx (transmit) should be connected to phone Rx (receive), so Phone can receive data that was sent by Box 3. Box Gnd should be connected to phone Gnd (common wire) As you can see, word "Rx" and word "Tx" is just a words without any reasonable meaning. When you mention Rx or Tx you must specify what device is owner of Rx or Tx. For example, you can say "I connected Box Rx ..." (device is Box) or "I disconnected Phone Tx ..." (device is Phone) but you can not say "I connected Rx ..." (no device mentioned). Leçon #1: Explication du Rx, Tx, Gnd Big thanks to Mr. elhoukka for translation ! Il y a une interface pour connecter de différents objets qui s'appellent "série" ( plusieurs termes sont utilisé pour cette interface comme UART, Port COM et probablement d'autres nominations) Beaucoup de téléphone mobile utilise l'interface "port com" pour le flashage, le désimlockage et d'autres opérations. Trois fils doivent être utilisés pour connecter une Box a un Téléphone mobile : 1. RX ( Récepteur de données) 2. TX ( Transmetteur de données) 3. GND ( masse, appelé aussi "terre" ou "masse terreuse") Si vous voulez connecter une box a un mobile, vous devez connecter les 3 fils de cette manière: 1. Le récepteur de la Box (RX) doit être connecté au transmetteur du mobile (TX), pour que la Box puisse recevoir les données envoyées par le mobile. 2. Le Transmetteur de la Box (TX) doit être connecté au Recepteur du mobile (RX), pour que le mobile puisse recevoir les données envoyées par la Box 3.Le GND de la Box doit être connecté au GND du Mobile. Comme vous pouvez le voir, les mots "Rx" et "Tx" a eux seules n'ont aucune signification, quand vous mentionnez Rx ou Tx vous devez spécifier l'objet auquel appartient ce "Tx" et "Rx" Example: Vous pouvez dire " J'ai connecté le Rx de la Box ..." (l'objet et la box) ou "j'ai déconnecté le Tx du mobile" ( l'objet et le mobile). mais vous ne pouvez pas dire "j'ai connecté le Rx.." (aucun objet mentionné) Lección #1: Rx, Tx, Gnd definición de los terminos (traducción al español) Big thanks to Mr. ybru for translation ! Hay una interface para conectar diferentes dispositivos llamada “puerto serial” (se le llama también UART, puerto COM, etc.) Muchos teléfonos se utilizan a través del puerto "COM" para recargarles el software, desbloquearlos y otras operaciones. Tres cables deben de utilizarse para conectar la caja al teléfono: 1. Rx (recibe los datos) 2. Tx (transmite los datos) 3. Gnd (tierra común). Si quieres conectar la caja al teléfono tienes que conectar esos cables de esta manera: 1. El RX de la Caja (recibe) debe de conectarse al TX (transmite) del teléfono, así la caja puede recibir los datos que le envía el teléfono. 2. El TX (transmite) de la caja debe de conectarse al RX (recibe) del teléfono, así el teléfono puede recibir los datos que le envía la caja 3. La TIERRA de la caja debe conectarse a la tierra del teléfono Como puedes observar, las palabras “RX” y “TX” son solo palabras sin sentido. Cuando dices RX o TX tienes que especificar cual dispositivo es el propietarios del RX o del TX. Por ejemplo, debes decir “Conecté el RX de la caja…” (el dispositivo es la caja) o "Desconecté el TX del teléfono ..." (el dispositivo es el teléfono) pero no debes decir "Conecté el RX ..." (sin mencionar de que dispositivo). Last edited by InfinitySupport; 05-29-2008 at 22:03. |
The Following 32 Users Say Thank You to InfinitySupport For This Useful Post: |
05-29-2008, 21:36 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Lesson #2: CPU and Flash chip information CPU chip: main part of phone. In most cases it's most big chip that you can see at phone PCB. CPU makes all calculations, manage pressed keys, sounds manage, LCD manage etc. If CPU is broken this means that phone can't work (in most cases can't Power-On). CPU chip examples: D751685A AD6537B AD6526ACA CM6357EL/3C3/5A MT6219AT MSM6250 ... Flash chip: another one big chip at phone PCB. This chip is a software and data storage, CPU commands stored in Flash as well as other data, such as phone calibration data, imei, simlock, user code, phonebook, melodies, images etc. Flash chip should be programmed (data should be written into Flash chip) with correct data so CPU can understand what to do. Flash chip examples: 71PL127J80BAW9U 84VD22190FM LRS18531 ... Leçon #2 : Information sur Le Processeur et le FLash Chip Big thanks to Mr. elhoukka for translation ! CPU Chip ou Processeur : Dans la plupart des cas c'est le plus grand composant que vous pouvez voir sur une carte mère d'un mobile, Le CPU ou processeur s'occupe de tous les calculs, de la gestion des touches pressées, Gestion des sons, Gestions D'affichage...etc. Si le CPU est endommagé, le mobile ne peut pas fonctionner ( dans la plupart des cas il ne s'allumera pas) Example De CPU's D751685A AD6537B AD6526ACA CM6357EL/3C3/5A MT6219AT MSM6250 ... Flash Chip: un autre grand composant sur la carte mère, il sert a stocker le logiciel et les données, les commandes de CPU sont stockées dans le FLash avec d'autres données, comme l'imei, simlock, code utilisateur, contacts, sonneries, images etc. Le Flash Chip doit être programmé ( les données sont écrites dans le flash chip) avec des données correct pour que le CPU peut comprendre quoi faire. Examples de Flash Chip: 71PL127J80BAW9U 84VD22190FM LRS18531 ... Lección #2: Información sobre el CPU y Flash chip (traducción al español) Big thanks to Mr. ybru for translation ! CPU: Es la parte principal del teléfono. En la mayoría de los casos es el chip más grande que puedes ver en la tarjeta lógica del teléfono. El CPU hace todos los cálculos, manega los botones que oprimes, maneja los sonidos, la pantalla, etc. Si el CPU se rompe quiere decir que el teléfono no puede funcionar (en la mayoría de los casos no puede encender). Ejemplos de CPU: D751685A AD6537B AD6526ACA CM6357EL/3C3/5A MT6219AT MSM6250 ... Flash chip: Es otro chip grande que se puede ver en la tarjeta lógica del teléfono. Este chip es donde se almacena el software y la información, el CPU ordena que la información se guarde en el Flash chip, así como otros datos como la calibración del teléfono, el imei, el bloqueo del sim, el código del usuario, el directorio, los timbres, las imágenes, etc. El Flash chip debe de ser programado (los datos deben de ser guardados en el Flash chip) de una manera que el CPU pueda entender que es lo que debe de hacer. Ejemplos de Flash chip: 71PL127J80BAW9U 84VD22190FM LRS18531 ... Last edited by InfinitySupport; 05-29-2008 at 22:03. |
The Following 21 Users Say Thank You to InfinitySupport For This Useful Post: |
05-29-2008, 21:53 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Lesson #3: What is FLASH chip Each phone is asmall computer with it's own brain (CPU) and memory (flash). In compare with ordinary PC: Phone CPU = PC CPU = brain Phone Flash = PC Hard Drive (HDD) = memory = data storage So to make phone workng it's need to write into flash chip software (program) and some data (f.e. battery calibration, imei etc.) There are different flash chip types: NOR flash: almost all phones has it, used for firmware and data storage NAND flash: ordinary used as a data storage, but some newest phones used NAND as a firmware storage too Flash chip is a complicate device. To write data into flash chip it's need to make special procedure (also called Algorithm, make several important steps one by one). Flash chip from different manufacturers used different algorithms (f.e. AMD algorithm, INTEL algorithm). As a result of different algoritms that used in different flash chip by different manufacturers, some phones must use only AMD (or only INTEL) type of flash chip. This means that when you need to replace flash chip (f.e. if it become damaged) you need to replace flash chip with the same type (same algorithm) flash chip to avoid additional problems with phone functionality. Leçon #3 : C'est quoi un Circuit Flash (ou Flash Chip) Big thanks to Mr. elhoukka for translation ! Chaque mobile est un petit ordinateur avec son propre cerveau (CPU ou processeur) et mémoire (flash) En comparant un mobile avec un PC ordinaire on a : Processeur du Mobile = Processeur du PC = Cerveau Flash du mobile = Disque Dur du PC (HDD) = Mémoire = stockage des données. Alors pour que le mobile marche, il a besoin d'écrire le logiciel a l'intérieur du flash Chip (programme) et autres donnée (ex: calibration de la batterie, imei..Etc.) Il existe différent type de flash Chip: NOR Flash: il se trouve dans la plupart des mobile, il est utilisé pour le stockage du firmware et des données. NAND Flash: Généralement utilisé pour le stockage des données, mais il existe de nouveaux modèles qui l'utilisent aussi pour le stockage du firmware. Le Flash chip est un composant compliqué, écrire des données dans le flash chip nécessite une procédure spéciale (appelé aussi algorithme, qui consiste à exécuter plusieurs étapes une par une) L'algorithme utilisé diffère d'un constructeur a un autre (ex : algorithme AMD, Algorithme Intel). Vu les différents algorithmes utilisés dans les Circuit flash de chaque constructeur, quelques téléphones doivent utiliser seulement AMD (ou Intel) comme type de flash Chip. Donc si vous avez besoin de remplacer un flash Chip (Ex: Dans le cas ou il est endommagé) vous devez le remplacer par le même type (même algorithme) pour éviter tout problème de fonctionnement du téléphone mobile. Ps: All lesson in french language can be found here : http://www.centralmobile.net/vbb/showthread.php?p=45296 Lección #3: Qué es el FLASH chip (traducción al español) Big thanks to Mr. ybru for translation ! Cada tele´fono es una pequeña computadora con un cerebro (CPU) y una memoria (Flash chip). Comparándo el teléfono con una computadora ordinaria: El CPU del teléfono = CPU de la computadora = cerebro Flash chip del teléfono = Disco duro de la computadora (HDD) = memoria = almacenamiento de datos Entonces para que el teléfono funcione necesitas almacenar en el Flash chip el software (el programa) y algunos datos (por ejemplo la calibación de la batería, el imei, etc.) Hay diferentes tipos de Flash chip: NOR flash: Casi todos los teléfonos lo usan, lo utilizan para almacenar el firmware (los programas fijos) y los datos NAND flash: Se utilizan comúnmente para almacenar datos, pero en algunos teléfonos de modelo reciente también se utiliza para guardar el firmware también El Flash chip es un dispositivo complicado. Para almacenar algo en el Flash chip se necesita un procedimiento especial (también llamado Algoritmo, que lleva a cabo importantes procedimientos paso a paso). El Flash chip puede ser de diferentes fabricantes y usar diferentes algoritmos (por ejemplo el algoritmo AMD, el algoritmo INTEL). Como resultado se los diferentes algoritmos utilizados en los Flas chip por los diferentes fabricantes, los teléfonos deben usar sólo un Flash chip AMD (o INTEL). Esto quiere decir que cuando necesitas reemplazar el Flash chip (por ejemplo si está dañado), necesitas reemplazarlo por otro Flash chip del mismo tipo (con el mismo algoritmo) para evitar problemas adicionales a la funcionalidad del teléfono. Last edited by InfinitySupport; 05-29-2008 at 22:06. |
The Following 19 Users Say Thank You to InfinitySupport For This Useful Post: |
05-29-2008, 22:07 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Lesson #4: What is Multimeter and how to use it It's not a secret that each mobile repair service engineer must have some tools that helps him to service mobile phones. All tools van be divided for two big parts: 1. hardware tools (f.e. screwdriver, multimeter, bga soldering tools etc.) 2. software tools (f.e. Infinity-Box software) Here is a description of one of most important tool with name Multimeter, very usful diagnostic tool. With Multimeter you can measure voltage, resistance and make other diagnostic operations. There are many different type od Multimeters available on market, below you can see example of very portable and cheap Multimeter. Example #1: if you need to check is your battery enough charged you must measure it's voltage and compare measured voltage with value that you can see on battery. How to measure voltage with Multimeter: 1. connect wires to Multimeter according to voltage measurement marks 2. set Multimeter to voltage measurement mode (see marks at picture below) 3. connect Multimeter wires to battery "+" and "-" contacts (black wire to "-" and red wire to "+") 4. you will see battery voltage value at Multimeter's LCD Example #2: if you nead to find Gnd pin at phone connector you can find it with Multimeter this way: 1. set Multimeter to resistance measurement mode with voice signal (see marks at picture below) 2. remove battery from phone 3. connect one Multimeter's wire (any wire, not depends on color) to phone PCB Gnd 4. connect other Multimeter's wire to all phone connector pins one by one until you will hear voice signal or you will see 0 (zero) resistanse at Multimeter's LCD Leçon #4: C'est quoi un Multimètre et comment l'utiliser? Big thanks to Mr. elhoukka for translation ! Ce n'est pas un secret que chaque service de réparation a quelques outils qui l'aide a travailler sur les téléphones mobiles. Ces outils peuvent être divisés en deux grandes parties: 1. Outils hardware ( Ex: Tournevis, Multimetre,Outils de dessoudage etc.) 2. Outils Soft ou logiciel ( Ex: Infinity-Box Software) Voici la description de l'un des plus important outils qu'on appelle le Multimetre, un outils très utile pour le diagnostic. Avec le Multimetre, vous pouvez mesurer le voltage, résistance et faire d'autres opérations de diagnostic. Il existe plusieurs types de Multimetre disponibles dans le marché, en bas vous pouvez voir un exemple d'un Multimetre portable pas chère. Exemple #1: Si vous avez besoin de vérifié si votre batterie et bien chargée vous devez mesurer son voltage et le comparer avec la valeur que vous voyez sur la batterie. Comment mesurer le voltage avec un Multimetre. 1. connecter les files du Multimetre sur l'endroit de mesure de voltage. 2. régler le Multimetre sur le mode de mesure de voltage ( regardez la photo en bas) 3. connecter les files au "+"et "-" de la batterie ( Fil noir au "-" et fil rouge au "+") 4. Vous aller voir le voltage de la batterie dans l'afficheur du Multimètre. Exemple #2 : Si vous avez besoin de trouver la masse (ou GND) dans le connecteur du téléphone, vous devez le faire de cette façon: 1. Régler le Multimetre sur le mode de mesure de résistance avec signal son ( regardez la marque dans l'image en bas) 2. Enlever la batterie du téléphone. 3. Connecter un fil du Multimetre ( n'importe le quel, ça ne dépend pas de la couleur) sur le GND de la carte mère du téléphone. 4. Connecter l'autre fil du Multimetre a tous les pins du connecteur un par un jusqu'à ce que vous entendez le signal ou vous voyez la valeur 0 (zero) sur l'afficheur du Multimetre. Ps: All lesson in french language can be found here : http://www.centralmobile.net/vbb/showthread.php?p=45296 Lección #4: Que es un Multímetro y como usarlo (Traducción al español) Big thanks to Mr. ybru for translation ! No es un secreto que cada ingeniero de servicio técnico debe tener algunas herramientas que le ayuden a dar servicio. Todas las herramientas están divididas en dos grandes grupos: 1. Herramientas de hardware (por ejemplo destornillador, multímetro, estación de soldado de bga-s, etc.) 2. Herramientas de software (por ejemplo Infinity-Box software) Aquí está una breve descripción de una de las herramientas más importantes llamada Multímetro, que es muy usada para diagnosticar. Con el Multímetro puedes medir el voltaje, la resistencia y hacer otras operaciones de diagnóstico. Hay muchos tipos diferentes de Multímetros disponibles a la venta, más abajo puedes ver el ejemplo de uno portátil y barato. Ejemplo #1: Si necesitas checar si tu batería tiene carga suficiente, debes de medir el voltaje y compararlo con el voltaje impreso en la batería. Como medir el voltaje con el multímetro: 1. Conectar los cables del multímetro de acuerdo a las marcas de polaridad. 2. Selecciona en el multímetro la función de medición de voltaje (ve la imagen) 3. Conecta el extremo de los cables del multímetro en los contactos de la batería marcados con + y – (el negro al – y el rojo al +) 4. En la pantalla del multímetro verás el voltaje de la batería. Ejemplo #2: Si necesitas encontrar el pin de la tierra en el conector del teléfono, puedes usar el multímetro así: 1. Fija el multímetro en la función para medir resistencias con el símbolo de zumbido (ve en la imagen) 2. Quítale la batería al teléfono. 3. Conecta uno de los cables del multímetro (cualquiera de los 2, no importa el color) a alguna tierra de la tarjeta lógica 4. Conecta el otro cable del multímetro a los pins del conector del teléfono de uno por uno hasta que escuches el zumbido del multímetro o en la pantalla del mismo veas un 0 (cero) en la resistencia. Last edited by InfinitySupport; 06-02-2008 at 22:49. |
The Following 35 Users Say Thank You to InfinitySupport For This Useful Post: |
05-31-2008, 08:17 | #6 (permalink) |
No Life Poster Join Date: Jul 2005 Location: France Age: 48
Member: 165812 Status: Offline Sonork: 100:1627635 Thanks Meter: 4,267 | Great Move And Here Will Be The Four Lessons Which Posted By This Box Supporter In Arabic : They Are In Pdf Format So U Can Download And Read Without Internet Connection As Some Of The Members Asked |
The Following 26 Users Say Thank You to tsarkh For This Useful Post: |
07-14-2008, 10:36 | #7 (permalink) | |
Member: 165812 Status: Offline Sonork: 100:1627635 Thanks Meter: 4,267 | Here Is It Man Quote:
Good Flashing For All | |
The Following 4 Users Say Thank You to tsarkh For This Useful Post: |
08-18-2008, 20:23 | #8 (permalink) |
Freak Poster Join Date: Apr 2004 Location: Made In Brazil
Member: 62561 Status: Offline Thanks Meter: 706 | Here is all 4 lessons translated to Brazilian Portuguese language. As soon as new lessons will be released, it will be translated too. b.r. Cryspim |
The Following 6 Users Say Thank You to Cryspim For This Useful Post: |
02-02-2009, 02:15 | #9 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | One more step in continue University project: http://forum.gsmhosting.com/vbb/showthread.php?t=675707 |
The Following User Says Thank You to InfinitySupport For This Useful Post: |
02-25-2009, 19:55 | #10 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Here is Knowledge base, please, check it if you need to get general information about phone repair process, keyboard codes etc: http://www.infinity-box.com/wiki |
09-09-2009, 10:17 | #11 (permalink) |
No Life Poster Join Date: Aug 2005 Location: All Americas Age: 44
Member: 168246 Status: Offline Sonork: 100.110734 Thanks Meter: 79 | would be cool if u inifnity guys post some boot access methods, loaders , and some algos, for some old models for example best regards |
Infinity-Box University project | InfinitySupport | Infinity-Box | 271 | 02-26-2023 11:09 |
Universal sim, Infinity Box & Pinfinder Etc !! | amitks_in | Main Sales Section | 0 | 07-14-2008 09:41 |
infinity-box + universal auto find pin-out box | djamel852 | Infinity-Box | 22 | 02-03-2008 15:44 |
need video how to connect infinity-box + universal auto find pin-out box mtk | GSM-SKY | Infinity-Box | 0 | 12-11-2007 12:36 |
Hot devices: Infinity Box, Ultima Box, Universal Box, Dreambox, VygisToolbox - BEST $ | Gobi | Main Sales Section | 0 | 02-07-2006 17:50 |
