![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2005
Member: 149032 Status: Offline Thanks: 63
ALL CHINESE MOBILE SOFTWARE AND HARDWARE 100% solution
maximus ex60,sprint7700,nckia n95,nokla,cgc,mpeg4,nokia6300,
and all mtk chip chinese mobile problem! send post and take easy solution. city mobile khulna,bangladesh. mob:+8801717004797 |
Member: 786455 Status: Offline Thanks: 0
Is there any software available for UFO 933 Digital Mobile Cheers!! |
| The Following 15 Users Say Thank You to roshini57 For This Useful Post: |
Find Rx .tx Signles easyyy
HOW TO FIND RX .TX SIGNLES . It is tasted and also you can test it. 1 step is, we need to find GND from phone. 2 step is, we should power on phone (operation with dead phone: phone must be 100% dead by software)and take multimater put it to voltage. 3 multimeter (-) line put it GND and with (+) line check each connectors , and usually Tx= 1.8v or 2.8v and Rx=1.7v or 2.7v (it will be change by processor but strongly 1.7v or 2.8v not 3v or 4v) This way is too easy and you will save a more time. For example! You have got new brand China miracle phone with USB cable. It has got 12 pin. You must find (Infinity team give good Idea 1.2.3 punkts): 1) GND usually it has got 2 GND. (now we have got 10 pins) 2) We will uncheck USB + and USB- (VSS) just with checking by USB cable (now we have 8 pins) 3) By USB cable we also uncheck V bat+, ac adaptor + polarization (now we have 7 pins) 4) Now from this 7 pins you will find 1 or 3 not used pins (last operation we have 3 or 6 pins to find Rx Tx signals) 5) Now at last operation you should use good multimeter just to find Rx Tx with 1.7v-2.7v or 1.8v-2.8v 6) WHEN PHONE IS POWERD OFF TX AND GND WITH MULTIMETER MAKING BEEEEEP (DIOD TEST OPERATION), WHEN PHONE POWERED ON IT WILL SHOW LIKE DIOD RESISTANS 600-700 OHM BETWIN TX AND GND. I think I have give for every body more information’s. Just try to find. If you find 2-3 phone signals and you will be profi mobile Tx and Rx signals finder. Some times you will not find with this method some phones, but why we have forum? I'm not saying it is 100% solution but I'm saying it is TESTED solution. I'll make some guide or FAQ by pic. if I have a free time! |
| The Following 64 Users Say Thank You to gopalhot For This Useful Post: | adnan sarwar, alok_chp, ameen.mu, Ani One, BATAK, chamaileon, cocoyolive, DhimanElectx, ecs_lk, elink_tech, everstarnirmal, fessi, globaltelecom, gsmlover4u, hasankhan, hero-1984, jamil25, JAMIR 2005, javedarif, jewel526, jidan, jirapat@, karikari, krish1969, loxmn, man313, Masudur Rahman, max0066, mdsujon, minde7, mitko8103, mizancoxr, morton1984, Mr.jaber, mtrao, Muhammad Zakria, multi_ele, NeTiZenN, Nicogalan, nicookta, omid sharafy, prem_airtelsp, Raheel Shah, raiaur, rakibmhr, rehanctg, ruwanjk, saiftc2, sampat_shah, seoni, shahid555, shahzad_786, shimul_777, shubhashish0187, snisar, soshan, sujan islam, sumon fulbare, sumon_alim, ttms, vnmanda9, yamkey, zafar78, zima_1st |
![]() ![]() ![]() ![]() ![]() Join Date: Jul 2004
Member: 71721 Status: Offline Sonork: 100.106320
@gopalhot
you are giving attachment link to other site which need user and pass its against forum rules if you have somthing then post here....other wise stop posting other forum direct link |
| The Following 12 Users Say Thank You to TURNING POINT For This Useful Post: |
How can one flashes Nokia 1200 with UFS3 i know
call me use old ufs it is pasebal
| The Following 13 Users Say Thank You to gopalhot For This Useful Post: |
Post Here All China Phone Driver
http://file.hit2hosting.com/download.php?id=6427E9F51
http://rapidshare.com/files/10525119...llection_1.rar Here Some Drivers MTK_DRIVER MT6227__Driver Winbond_CPU_Driver VIA_CPU_Driver Philips_CPU_Driver SpreadTrum_CPU_Driver |
| The Following 33 Users Say Thank You to gopalhot For This Useful Post: | ..::Vinod::.., adnan sarwar, arashpart, atiefoo-gsm, chaimomgkol, dinkar_008, hassan27, HO_TUANLOANTF, ilvsjs, inderdmw, ismailmobile, jamil25, JAMIR 2005, javedarif, jewel526, karikari, mazentel.., minde7, mithon, mithoshilpi, Mr.jaber, Mr.ps_mobile, raagavan, Raheel Shah, rakibmhr, robf1rst@yahoo, rorobles1, rrim11, ruwanjk, sameer2050, shimul_777, shubhashish0187, sumon_alim |
Tv Mobile Avi Video Solution 100% Workin ~
P90 TV MOBILE AVI VIDEO SOLUTION 100% WORKIN ~
here is setting use total video converter 3.10 1.audio ch**** single 2.audio codec ; pcm16le sample rate; custem 8000 bitrate 64 video setings video codec mjpeg frame rate 15 bitrate custen 1600 video resize as set 208x 176 or 176x 144 |
| The Following 25 Users Say Thank You to gopalhot For This Useful Post: |
Hey, Why my post has got deleted??
| The Following 7 Users Say Thank You to roshini57 For This Useful Post: |
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2003
Member: 44229 Status: Offline Thanks: 26
| The Following 8 Users Say Thank You to gsmbac For This Useful Post: |
Member: 300866 Status: Offline Thanks: 0
hi everybody
i am looking for software for read firmware for spreadtone based mobile phone (i think it is spreadtone processor cause in the bluetooth menu the name of phone is "spreadtone z95" the model of phone is BI t200+) can you tell me the name for the program or a download link? regard |
| The Following 9 Users Say Thank You to jy06 For This Useful Post: |
![]() ![]() ![]() Join Date: Aug 2006
Member: 330470 Status: Offline Thanks: 8
i need info about china nokla 5310 bad software mt chip 6225
| The Following 8 Users Say Thank You to mrmisudnjbd For This Useful Post: |
Member: 14934 Status: Offline Thanks: 31
got 1000% working solution trow them in garbage and buy a real phone
| The Following 8 Users Say Thank You to forhike For This Useful Post: |
Member: 786024 Status: Offline Thanks: 0
hello
so please i need help. i have an chinese iPhone called "GSM Cellular Telephone with Bluetooth and two dual-sim and 4Go" model number A1203 and FCC ID: BCGA1203" designed by apple in california assembled in china. when i link it to my computer i should shut it off to open its storage folder (G,H) but when i connect it when it was "on" windows xp cannot reconise it so please give me an driver or anything to do to connect it when it is "on" to my computer and wanna know too if i can activate and synchronise it with itunes. thank you very very much. |
| The Following 7 Users Say Thank You to freedream For This Useful Post: |
![]() ![]() ![]() ![]() Join Date: Apr 2003
Member: 26420 Status: Offline Thanks: 7
hi,
I'm looking for tv mobile V918 firmware anyone can help with 2 sim and dual cpu mt6205. Thank's anyway. |
| The Following 6 Users Say Thank You to vin79 For This Useful Post: |
![]() ![]() ![]() ![]() Join Date: Dec 2007
Member: 655261 Status: Offline Thanks: 0
thanks , but how the way find USB+ and USB- , I have'n USB cable !!!!
| The Following 5 Users Say Thank You to vnsun For This Useful Post: |
