Old 10-09-2009, 05:07   #166
deepoottan
Member: 922090
thanks a lot.i want the dead handsets repairing solution can you please send me that for all sets.my id is anishpoovathukunnel@gmail.com
Old 10-15-2009, 19:59   #167
Nonem77
Member: 959567
Digitized that's all it's a great solution...Many2 thank u....
Old 10-16-2009, 23:11   #168
riya2000r2k
Member: 460522
still dsnt work
Originally Posted by digitized View Post
check shorting in nokia 6670,7610.......
1..remove this coil mark in (1)...if u want to check is pf is short,....
2...remove this coil mark in (2)..if u want to check the display light ic is short....
3..remove ic mark in (3)... this is memory card driver ic this also got +b from batery....remove it to check shoting is gone or not.......
4...remove this transistor ic mark in (4)...this is transistor ic for key pad light ....remove this if u want to check the shoting cause by this transistor....because this transistor got +b from batery......
5..remove this transistor ic mark in (5)...this ic make volt for lcd 2.5v (vlcd)....this ic got +b from batery ....remove this if u want to check the shoting cause by this transistor.....
6...remove boot ic mark in (6)..if u want to check shoting cause by boot ic if it is short replace it with new one......
7..remove ringer ic mark in (7) ....if u want to check shorting throug ringer ic is gone or not...
8.....remove this smps ic mark in (8)... to check the shoting cause by this ic.........this ic make v corea volt for upp...
9..at end remove uem to check shoting is gone or not.....
all the component which are mark in pink colur these all are coils and resistance these are place in series and +b of batery is gone throw them so if u remove the coil and resistance u not have to remove ic to check the shorting in pcb it save time and ur ic ....
digitized
hi
I have removed 1,2,3,4,5,7,8 I havnt remove 6 and i cant find 9 in the diagram.
Also still my phone dsnt work.This phone was dropped on water and i have cleaned and heated by sunlight, now its more than 6 month,Then i found this site and remove above i mentioned but still it dsnt work.I meant power cnt on.
pls help
The Following User Says Thank You to riya2000r2k For This Useful Post:
Old 10-17-2009, 08:05   #169
digitized
digitized's Avatar
Member: 163833
Sonork: 100.1579554
Originally Posted by riya2000r2k View Post
hi
pls help
no 9 is uem means power ic
check the pic .....
The Following User Says Thank You to digitized For This Useful Post:
Old 10-17-2009, 09:17   #170
siang8788
siang8788's Avatar
Member: 205283
n82 water damage,when put battery got red light automatic,solution?
Old 10-17-2009, 15:08   #171
khaja mohideen
Member: 1142118
i need for n95 shoting testpoint
Old 11-05-2009, 07:45   #172
digitized
digitized's Avatar
Member: 163833
Sonork: 100.1579554
check shoting in nokia 2700c-2....
1..Remove this coil mark in (1)..if u want to check the light ic N2301 is short....
2..Remove N3200 ic mark in (2) ...this is memory card driver ic .remove it to check shoting is gone or not....
3..Remove this ic n6000 mark in (3)..this is blutooth & radio ic remove it to check shoting is gone or not because this ic also got +b volt from battery....
4..remove this coil mark in (4) ....if u want to check the shoting cause by handfree ic ...handfree ic got the +b.....
5..Remove this ic n1002 mark in (5)...if u want to check the pf N1002 this pf based on new tecknology... this this ic got +b from batery ic ... this ic work for network...
6..Remove ic N1001 mark in (6) ..if u want to check it ..this is rf ic based on new tecknology ...this ic got +b from batery ic ... this ic work for network...
at end remove betty and avilma ic to check shoting is gone or not........
..::digitized::..
The Following 5 Users Say Thank You to digitized For This Useful Post:
Old 11-09-2009, 15:01   #173
arun@22
Member: 1092807
Sonork: histar
der,
iwant nokia cabel findar we'r link to downloading this software ,
tkx,
Old 11-09-2009, 15:13   #174
arun@22
Member: 1092807
Sonork: histar
dear,,,,,,galaxyman nokia cable finder ver10.2 downloading this software ..........txs
Old 11-10-2009, 02:24   #175
abdelouahabido
Member: 821750
Sonork: 19790515
take this brother...........................
Old 11-18-2009, 09:30   #176
faaiq5
faaiq5's Avatar
Member: 980523
Sonork: Faaiq5
Talking wow DEAR..
Nyc dear....
good work amazing ....
thx alot......
Old 11-18-2009, 13:10   #177
asif-rashid
Member: 792254
Sonork: al_jadeed
plz help me 3110c mmc sulotion
Old 11-19-2009, 16:26   #178
Yonas Tewelde
Member: 1157279
I wish you success for all Technicians and specialists!There is a cell phone nokia 1110i inserted in water before 4months and I reflowed the pcb and I tried it with nice battery.I heard sounds but no display picture and the keypad is not turning on!What should I do to repair it? please,help me!My grandfather is so worried to lose the phone.Waiting for your answers now!Or U can send me through yahoomessenger offline message at yo_na_lee@yahoo.com
Page generated in 0.08326 seconds with 7 queries
