#31 |
Member: 163833 Status: Offline Sonork: 100.1579554
check shoting in nokia 6131,6133,6126......
![]() imp*****to check shoting in this model first remove flex slider from main pcb if ur shoting is gone then there is shoting is in ur uper display portion because there are some ic in upper portion which got +b from batery. through flex..***** 1..remove this coil mark in (1)...if u want to check is pf is short,..... 2..remove this coil mark in (2)..if u want to check rf ic is short because rf ic also got +b volt from battery.... 3..remove the resistance mark in (3) ..if u want to check irda module ... because irda module got +b from batery.... 4..remove this coil mark in (4)..if u want to check the light ic is short....because light ic got +b from batery.... 5..remove this coil mark in (5) if u want to check memory card driver ic n3200 it also got +b from batery....... 6..remove this coil mark in (6)..if u want to check blutooth ic is short because bluetooth ic also got +b volt from battery.... 7..remove this ic n3300 mark in (7)..if u want to check the v.cam maker ic ..this v.cam maker ic got +b from batery....this ic make volt for camera ..... 8...remove this ic n1200 mark in (8).....this ic also got +b from batery.... 9....at end remove retu and tahvo ic to check shoting is gone or not.... all the component which are mark in pink colur these all are coils and resistance these are place in series and +b of batery is gone throw them so if u remove the coil and resistance u not have to remove ic to check the shorting in pcb it save time and ur ic .... digitized
| The Following 28 Users Say Thank You to digitized For This Useful Post: | 9khuongmobile, ansari_shahid80, bijet, coolRAJ, dedeyk, gsmkiller173, Honey kalra, IMAM PUDJI D, irfanb20, jesse_25, jun piczon, LIKI, luckyzaib, man van ho, mardan mobile, mobile star, mukund_orange, nader-g, najim uddin, NAZTY, ncellking, parsa86, raie, robf1rst@yahoo, salahbeb, shakir_pc, varun20, yny_1976 |
#32 |
![]() Join Date: Jan 2007
Member: 439620 Status: Offline Thanks: 12
SIR I HAVE PROBLEM WITH 6630 WHEN I CONNECT IN HWK AND CHECK THERE IS ERROR IS THIS
1ST BOOT : C0,0C [Rm-1] [2.0.8.0] OMAP ID : 17100701 OMAP MODE : 00 OMAP PBID : FBAB039B06BD6ABEA83C4FA64C14B37FB47770CF OMAP HASH : 2C05369F57CC3C4CF9E783E83D9B512B OMAP ROID : AB5E4ADB27A06946 RAPx ID : 000000010000022600010006000C192101002100 EM 1 ID : 00000232 EM 2 ID : 00000352 RAPx PBID : 148002087BD346518DD04BEF9D046CBCE001FDAB RAPx MODE : 00 RAPx HASH : E9EFF4BFAA5393217CA6B17755FC3E14 RAPx ROID : F28A211FAC901AEE CMT 1ST Boot OK CMT 2ND Bt: RAP3Gv2_2nd.fg, Ver: 1.21.0 CMT FLID0 : 00EC2250-00000121, Sam K8S6415ETB CMT FLCNT : 000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF CMT MCID0 : FFFF0000-00000000 CMT 2ND Boot OK CMT ALGO : RAP3Gv3_algo.fg, Ver: 1.40.0 CMT VPP : Internal DUAL LINE : True CMT ALG Boot OK APE 2ND Bt: helen3_2nd.fg, Ver: 1.35.0 00000090: 00 00 .. ERR: APE 2ND Boot FLB1_MSG_C2: 00000400000000B172 APE 2ND CONF: Rebooting Mobile |
| The Following 5 Users Say Thank You to NARESH_RANGLANI For This Useful Post: |
#33 | |
check shoting in nokia 6270..... ![]() 1....remove this COIL mark in (1) if u want to check the shoting of pf .......remove the coil and ur shoting is gone then there is shoting in ur pf ....... 2..remove this coil mark in (2)..if u want to check rf ic is short because rf ic also got +b volt from battery.... 3..remove the resistance mark in (3) ..if u want to check irda module ... because irda module got +b from batery.... 4..remove this coil mark in (4)..if u want to check the shoring cause flash light driver ic n1471 ....because this ic got +b from batery.... 5...remove this coil mark in (5)..if u want to check the light ic is short.... 6...remove bluetooth ic mark in (6)..if u want to check blutooth ic is short because bluetooth ic also got +b volt from battery.... 7...remove this coil mark in (7)... to check the shoting cause by ringer ic......because ringer ic got +b from battery through this coil....... 8..remove ic mark in (8)....it is memory card driver ic....remove this if u want to check the shoring cause by this ic....because this ic got +b from batery...... 9..remove this ic mark in (9) ...it is vcam maker ic which make vcam for camera ......remove this ic to check shoting because this ic got +b from batery...... 10..at end remove retu and tahvo ic to check shoting is gone or not,,,.... all the component which are mark in pink colur these all are coils and resistance these are place in series and +b of batery is gone throw them so if u remove the coil u not have to remove ic to check the shorting in pcb it save time and ur ic .... digitized
| The Following 32 Users Say Thank You to digitized For This Useful Post: | 9khuongmobile, anshulbhola, ashwani gupta, ayogya, aztig678, bijet, bong echavez84, dollar78, ehsan nasiri13, gsmkiller173, Honey kalra, ilukmega, IMAM PUDJI D, imran777750, irfanb20, jesse_25, LIKI, mamalvanda, mardan mobile, mukund_orange, narendra001, NAZTY, nelsonic, o6En9, pappu4877, parsa86, raie, robf1rst@yahoo, SAQIBSHAIKH, sentosa56, shakir_pc, varun20 |
#34 |
check shoting in nokia 6085,6086........... 1..remove this coil mark in (1)...if u want to check is pf is short,..... 2..remove this coil mark in (2)..if u want to check rf ic is short because rf ic also got +b volt from battery.... 3..remove this coil mark in (3)..if u want to check the light ic is short.... 4..also check the memory card driver ic n3200 mark in (4) it also got +b it can be check by only removing this ic..... 5..remove this ic mark in (5)..if u want to check blutooth ic is short because bluetooth ic also got +b volt from battery.... 6..remove this ic mark in (6)....this is wlan pf this also got +b from batery this ic is not in 6085.... 7..remove this ic mark in (7)....this is wlan ic this ic got +b from batery this ic is not in 6085.... 8..at end remove retu and tahvo ic ..to check shoting is gone or not.... all the component which are mark in pink colur these all are coils these are place in series and +b of batery is gone throw them so if u remove the coil u not have to remove ic to check the shorting in pcb it save time and ur ic .... digitized
| The Following 23 Users Say Thank You to digitized For This Useful Post: |
#35 | |
![]() ![]() ![]() ![]() Join Date: Nov 2006
Member: 384984 Status: Offline Thanks: 274
first remove this pf 90 %this pf is short in this model i repairemany pc whith this solulation |
| The Following 25 Users Say Thank You to suneel For This Useful Post: |
#36 | |
yes these pf are shot when ur set is in water damage case..... any way thanks ..... br. digitized... |
| The Following 5 Users Say Thank You to digitized For This Useful Post: |
#37 |
![]() ![]() ![]() ![]() ![]() Join Date: Aug 2007
Member: 567490 Status: Offline Sonork: 100.1577032
i have problem n 70 1ST BOOT : C0,0C [Rm-84] [2.0.8.0]
OMAP ID : 17100701 OMAP MODE : 00 OMAP PBID : 058CE61DE17DE231BBEFCCFD1231E18BF0F23AC9 OMAP HASH : 2C05369F57CC3C4CF9E783E83D9B512B OMAP ROID : AB5E4ADB27A06946 RAPx ID : 000000010000022600010006000C192101002200 EM 1 ID : 00000232 EM 2 ID : 00000353 RAPx PBID : 0EA0010DD1765A5192B1F83BEA188EE37257AE16 RAPx MODE : 00 RAPx HASH : E9EFF4BFAA5393217CA6B17755FC3E14 RAPx ROID : F28A211FCEA7B19D CMT 1ST Boot OK CMT 2ND Bt: RAP3Gv2_2nd.fg, Ver: 1.21.0 CMT FLID0 : 00EC2250-00000121, Sam K8S6415ETB CMT FLCNT : 00000000000000000000000000000000000000 CMT MCID0 : FFFF0000-00000000 CMT 2ND Boot OK CMT ALGO : RAP3Gv3_algo_fps8.fg, Ver: 1.12.5 CMT KSIG0 : 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D CMT VPP : Internal DUAL LINE : False CMT ALG Boot OK IMAGE : RM84_50717301.C0 CMT NOR Erase Area: 0x00000000-0052B515 CMT NOR Erase Area: 0x006A0000-006BFFFF CMT NOR Erase Area: 0x006DF000-006EFFFF CMT NOR Erase Area: 0x00700000-007EFFFF CMT FLASH ERASE OK, Time: 00:44 CMT FLASH WRITE OK, Time: 00:30 1ST BOOT : C0,0C [Rm-84] [2.0.8.0] OMAP ID : 17100701 OMAP MODE : 00 OMAP PBID : 058CE61DE17DE231BBEFCCFD1231E18BF0F23AC9 OMAP HASH : 2C05369F57CC3C4CF9E783E83D9B512B OMAP ROID : AB5E4ADB27A06946 RAPx ID : 000000010000022600010006000C192101002200 EM 1 ID : 00000232 EM 2 ID : 00000353 RAPx PBID : 0EA0010DD1765A5192B1F83BEA188EE37257AE16 RAPx MODE : 00 RAPx HASH : E9EFF4BFAA5393217CA6B17755FC3E14 RAPx ROID : F28A211FCEA7B19D CMT 1ST Boot OK CMT 2ND Bt: RAP3Gv2_2nd.fg, Ver: 1.21.0 CMT FLID0 : 00EC2250-00000121, Sam K8S6415ETB CMT FLCNT : 00000000000000000000000000000000000000 CMT MCID0 : FFFF0000-00000000 CMT 2ND Boot OK CMT ALGO : RAP3Gv3_algo_fps8.fg, Ver: 1.12.5 CMT KSIG0 : 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D CMT VPP : Internal DUAL LINE : False CMT ALG Boot OK APE 2ND Bt: helen3_2nd.fg, Ver: 1.35.0 00000000: 04 00 00 00 00 B1 72 ......r ERR: APE 2ND Boot FLB_MSG_C2: APE 2ND CONF No Info IMAGE : RM84_50717301.C0 Process Failed, Repowering Mobile what is problem help me |
| The Following 3 Users Say Thank You to gsm3_zaman For This Useful Post: |
#38 | |
![]() 1..remove this coil mark in (1)...if u want to check is pf is short,.... 2...remove this coil mark in (2)..if u want to check the display light ic is short.... 3..remove ic mark in (3)... this is memory card driver ic this also got +b from batery....remove it to check shoting is gone or not....... 4...remove this transistor ic mark in (4)...this is transistor ic for key pad light ....remove this if u want to check the shoting cause by this transistor....because this transistor got +b from batery...... 5..remove this transistor ic mark in (5)...this ic make volt for lcd 2.5v (vlcd)....this ic got +b from batery ....remove this if u want to check the shoting cause by this transistor..... 6...remove boot ic mark in (6)..if u want to check shoting cause by boot ic if it is short replace it with new one...... 7..remove ringer ic mark in (7) ....if u want to check shorting throug ringer ic is gone or not... 8.....remove this smps ic mark in (8)... to check the shoting cause by this ic.........this ic make v corea volt for upp... 9..at end remove uem to check shoting is gone or not..... all the component which are mark in pink colur these all are coils and resistance these are place in series and +b of batery is gone throw them so if u remove the coil and resistance u not have to remove ic to check the shorting in pcb it save time and ur ic .... digitized
| The Following 30 Users Say Thank You to digitized For This Useful Post: | 9khuongmobile, anshulbhola, bijet, bong echavez84, dabing, damvin2, defrianto, DOSTI, ehsan nasiri13, fadz1701, ghaffardik, golam_maula, gsmkiller173, IMAM PUDJI D, jesse_25, khalique ghotki, LIKI, luckyzaib, mahmoudmod, mamalvanda, man van ho, mardan mobile, mukund_orange, NAZTY, o6En9, parsa86, raie, robf1rst@yahoo, sinar baru, Tariq Khan |
#39 |
check shoting in nokia 1680-c...
![]() 1...remove this coil mark in (1)..if u want to check the light ic is short.... 2..remove this v.camdig ic n3301 mark in (2)..if u want to check the v.camdig maker ic ..this v.camdig maker ic got +b from batery....to make v,cam for camera..... 3..remove ringer ic mark in (3)..if u want to check shoting remove it and check if shoting is gone replace it because ringer ic also got +b volt from battery.... 4..remove the pf n7700 mark in (4)...if u want to check is pf is short remove it and check shoting...if it is shot then replace it... 5..at end check the power ic and reemove it to check shoting is there or not.. all the component which are mark in pink colur these all are coils these are place in series and +b of batery is gone throw them so if u remove the coil u not have to remove ic to check the shorting in pcb it save time and ur ic .... wbr. ..:Preet:..
| The Following 21 Users Say Thank You to digitized For This Useful Post: |
#40 |
check shoting in nokia 6600 slide....
![]() 1..remove these both coil mark in (1)..if u want to check rf ic is short because rf ic also got +b volt from battery.... 2...remove these both COIL mark in (2) if u want to check the shoting of pf .......remove the coil and ur shoting is gone then there is shoting in ur pf .......this pf is only used in this circuit for tranmiting signal...(in tx section we say) 3...remove this COIL mark in (3) if u want to check the shoting of pf .......remove the coil and ur shoting is gone then there is shoting in ur pf .......this pf is work for both reciving and transmiting of signal..(this work as antena switch and pf as example in nokia 1110..) 4..remove this coil L3301 mark in (4) if u want to check the shoting cause by n3301,n3302,n3303.....these ic make volt for camera ic ...these ic got +b from batery ...so remove this coil to check shoting is gone or not .. 5..remove this light ic mark in (5)..if u want to check the light ic for display is short.... 6..remove ic mark in (6)... this is memory card driver ic this also got +b from batery....remove it to check shoting is gone or not....... 7...remove bluetooth module mark in (7)..if u want to check blutooth ic is short because bluetooth ic also got +b volt from battery.... 8..remove this ic mark in (8)..if u want to check the shorting cause flash light driver ic ....because this ic got +b from batery.... 9...remove this ic mark in (9)..if u want to check the key boad light ic is short.... 10...remove this resistance mark in (10)...if u want to check the ic which are place for controlloing and switching usb charging for the phone these ic are (n2006,n2005)...these ic got +b from batery to work... 11...remove this coil mark in (11)...if u want to check n2001 ic ...this ic is for usb controlling......this ic got +b from batery... 12...remove this ic n2002 mark in (12)...if u want to check this ic ....this ic also for usb controlling......remove this ic because this ic got +b from batery.... 13...remove this ic n2000 mark in (13)...if u want to check this ic ....this ic is for controlling usb charging......remove this ic because this ic got +b from batery.... 14...at end remove avilma and bety ic to check shoting is gone or not,....... all the component which are mark in pink colur these all are coils and resistance these are place in series and +b of batery is gone throw them so if u remove the coil and resistance u not have to remove ic to check the shorting in pcb it save time and ur ic .... ![]() wbr, ..:Preet:.. Last edited by digitized; 11-24-2008 at 09:34. |
#41 | |
![]() ![]() ![]() Join Date: Feb 2008
Member: 702077 Status: Offline Thanks: 20
| The Following 5 Users Say Thank You to amalou For This Useful Post: |
#42 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2005
Member: 161728 Status: Offline Thanks: 72
| The Following 17 Users Say Thank You to HUM For This Useful Post: |
#43 |
![]() ![]() ![]() ![]() Join Date: Oct 2005
Member: 195513 Status: Offline Thanks: 0
try this solution http://rapidshare.com/files/18269216...tions.rar.html good luck
| The Following 4 Users Say Thank You to glenntelecom For This Useful Post: |
#44 |
![]() ![]() Join Date: Jan 2009
Member: 943447 Status: Offline Thanks: 25
pls can some one pls help me with the solution for nokia 3110c blank sreen ps
| The Following 2 Users Say Thank You to mobileland139 For This Useful Post: |
#45 |
check shoting in nokia phones in one exe ....
![]() credit goes to benua3 ...for making this nice software.... here is link.... http://www.ziddu.com/download/289824...wSafi.rar.html wbr, ..:Preet:.. |
| The Following 31 Users Say Thank You to digitized For This Useful Post: | .::ADNAN440::., akskbn, amn32, anshulbhola, anugrahniel, anvaranvar, arun gurung, Ashwaa0404, biochemistali, chaimomgkol, ernie78, goondy, henaalam, IMAM PUDJI D, joelcabuyaban, mamalvanda, mardan mobile, masoom_masoom20, mnofal11, mukund_orange, najim uddin, NAZTY, paresh_mobi, parsa86, rajasekar, rmobile, robf1rst@yahoo, salim ansari, sniperegypt, talhaml, watari31 |
