Old 07-07-2008, 15:14   #1
Wynsak
Member: 458909
E90 gps
Where can i get keygen for nokia E90?
Should i rather use Garmin?
Where can i get South Africa maps?
Old 07-17-2008, 21:17   #2
fugglefeet
Member: 757575
Wynsak,
I dunno if you came right, I have managed to get GMXT to work on an E90 with the newest Garmap maps.
Old 07-18-2008, 13:54   #3
Wynsak
Member: 458909
I have gmobileXT on my phone. Followed instructions in forum, but cant get it to work. Keep searching for bluetooth GPS. I allso dont have South african maps.
Old 07-19-2008, 11:50   #4
fugglefeet
Member: 757575
Wynsak,
Will a quick guide help you how get it going? I got mine up and running with the latest GMXT (v4.20.00) from Garmin and it gives a quicker locate. Here goes anyway. I take it you have a copy of Jetmouse's keygen (preferably v1.3).
1) Download GMXT from here:-
http://www8.garmin.com/support/agree.jsp?id=3939
Follow the link "I agree to the above terms and want to proceed to the download page." and download the file.
Download the basemap file and support file from Garmin too (or if you have them, use the existing ones).
2.) Uninstall the existing GMXT from your phone as follows:
Go to Menu/Installations and highlight GMobileXT
Select Options/Remove/Yes
3.) Once the old GMXT is removed do the following:
Connect the phone via USB cable in Data Transfer mode and delete the Garmin Folder on the MicroSD card.
4.) Install GMXT as follows:
With the phone still connected, install the application (GMXT) first to the removable drive.
Then install the basemap to the removable drive.
Lastly, install the support files to the removable drive.
5.) Disconeect the removable drive and either GMXT will install automatically or navigate to the Garmin/Apps/Symbiam/Res folder and select GarminMobileXT.sis
6.) Start GMXT and follow the prompts to configure the GMXT. When it scans for a bluetooth GPS select cancel.
7.) Go to Settings/About and record the Card ID No.
8.) Start keygen and enter the Card ID No. into the Unit ID text field and click Generate. Highlight the GMXT device unlock code and press Ctrl - C.
9.) Open NotePad and press Ctrl - V. Now you have your unlock code in Notepad. Now a crucial step is to save it. Click File/Save As and select All Files from the Save as type dropdown box. Enter sw.unl in the File name dropdown box. Where you save it to is irrelevant, because you can copy it to the /Garmin/ folder on the microSD card later.
10.) Once you have copied the sw.unl to the /Garmin/ folder on the microSD card, start GMXT and select cancel when it starts to search for a bluetooth device. Select Settings/System/Remote GPS and select Assisted - GPS. Then select enable and done.
11.) Once you are at the main menu wait about 5 - 10 minutes for the GPS to acquire signal. When it has acquired signal for the first time, it's pretty quick at getting signal afterward.
The loading of the maps is another story
The Following 2 Users Say Thank You to fugglefeet For This Useful Post:
Old 07-19-2008, 13:00   #5
fugglefeet
Member: 757575
Wynsak,
Here's the link for the SA mapset. It's a gmapsupp.img in zip format, so you just have to copy it to the /Garmin folder.
http://rapidshare.com/files/130843839/FAM_1214.zip.html
Old 07-21-2008, 09:21   #6
Wynsak
Member: 458909
Thanks for great reply. My program is working now, just strugling to download maps from rapidshare. Dont have paypall account, and paypall takes time to setup. Thanks again for very thorough reply.
Old 07-21-2008, 11:06   #7
Wynsak
Member: 458909
Is it necessary to unlock map and create gmapsupp.unl file?
How do i download voice?
Sorry for all the questions, but i'm new to gps.
Old 07-21-2008, 18:00   #8
fugglefeet
Member: 757575
Wynsak,
You can optionally create the gmapsupp.unl file and copy it into the /Garmin folder on the microSD card. The voice guidance is part of the support files the you can download from www.garmin.com. Check the following settings in GMXT:- Settings/Audio/Voice and select English (American) and Settings/Audio/Voice Prompt is Enabled.
Hope this helps.
Old 07-22-2008, 13:04   #9
Wynsak
Member: 458909
Thanks, working like a charm.
Old 07-22-2008, 19:07   #10
fugglefeet
Member: 757575
Wynsak,
Nice to hear you came right.
Old 08-11-2008, 09:33   #11
keloggs
Member: 834842
hello fuggle,
thanks for he brief tutorial. I was on the verge to giving up upgrading to 4.20 from 4.10. But I have done it, and ... so far, I can see the same ****ty painful route planning interface, same sloooow map drawing, same snail-speed route calculation / recalculation, and obvious improvements to the speed of browsing the menus. So, it is pretty good for such a crap application .
You were saying about AGPS feature ? Is AGPS some sort of lo-fi version of WADGPS ? Anyway, how to enable it ?
I only have 2 options at Settings/System/Remote GPS, and they are:
use bluetooth gps
use attached/ builtin gps
hint me!
thanks
Old 08-11-2008, 13:19   #12
Wynsak
Member: 458909
Go to: Tools- settings- general- positioning- positioning methods and select agps. On E90 you have to upgrade your software to get agps.
Old 08-11-2008, 19:06   #13
keloggs
Member: 834842
thanks,
I didnt realize AGPS is E90-specific. Tried to find it on my E61 with no luck. However, I did find some interesting option called "network based positioning" that is checkable along with "bluetooth gps". Had no idea this kind of positioning was available by default in nokias. Cool
Old 08-17-2008, 21:49   #14
fugglefeet
Member: 757575
keloggs,
AGPS means Assisted GPS which refers to the built-in GPS of the device (in this case the E90). The E61 network based positioning uses (and please correct me if I'm wrong) the cellular towers of the network you are subscribed to triagulates your position by means of echo-location or pinging of the towers. None of the network companies will tell you this but the odds are that the towers transmit latitude and longitude co-ordinates for relative accurate locations of phones in a cell. Be careful though using this method, as you would have to find out if there are cost implications from your service provider for using this feature.
Old 01-01-2009, 10:34   #15
umarch10
Member: 807542
Sonork: 1581878
please i need Garmin Uk map plzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz
Page generated in 0.09442 seconds with 6 queries
