Member: 411385 Status: Offline Thanks: 1
hi people.. i got a new bluetooth USB device and it doesn seem to detect any devices when i run the scan neighbour hood... my phones also don seem to detect any device... i managed to identify that it is a BROADCOM device and the software used is WIDCOMM Bluetooth software 5.0.1.801 can any 1 help me fix the problem... please thank u in advance...
Member: 145139 Status: Offline Thanks: 0
Hello,
I have attached a picture with the same device, which was also defective on delivery. I tested it with different Widcomm versions and also with BlueSoleil. There was never a BT device detected (tested with headset and mobile phone). Hope this helps. DocNetwork P.S. Will upload file later. Upload doesn't work. |
Member: 828130 Status: Offline Thanks: 0
I have a bRoadcom 2045 USB Bluetooth device. I get the device in the Device Manager OK, but there is no Icon in the System Try. I have tried to disable the Firewall without any difference. When I started to install the driver (I got the Trust Installer (v 5.6) from the CD which came with the device) and cklicked on "Install driver", I didn't get the screen "WIDCOMM Bluetooth Software 6.0.1.4900" as I should get according to the Install Papers.
I allways get the information "No Bluetooth device found". How should I fix this problem? |
Member: 200440 Status: Offline Thanks: 0
I have the same problem with my dongle but only in the last few weeks while I was fiddling around with different operating systems. It's a Belkin F8T009 which is also a BCM2035 chipset. The only way I can get it to work is by using Widcomm 6.0 in Vista.
If I search for any devices using WIDCOMM under XP (it came with version 3.0 but I also tried 5.1.0.4200 from Broadcom's website) it appears to scan for about 10 seconds, no devices are detected and the following messages appear in the status bar: "Your local Bluetooth device has stopped" ... followed by the Windows USB disconnect sound "Your local Bluetooth device is now up" ... followed by the Windows USB connected sound I tried using the Microsoft Bluetooth stack in Vista x64 (didn't try it in XP) - it scanned for about one minute and said no devices were found. At the same time, the following message appeared in the system event log: Level: Warning Date and Time: 31/07/2008 22:49:20 Source: BTHUSB Event ID: 3 Task: None Category: A command sent to the adapter has timed out. The adapter did not respond. I also noticed in the properties that Vista detects the dongle as a Bluetooth 2.0 device rather than 1.2, it's certainly 1.2. I wonder if Widcomm 6.0 screwed up the firmware somehow? |
