Go Back   GSM-Forum > GSM Mobile Brands -Software Area- > Nokia > Nokia Multimedia
Nokia Multimedia No Unlocking or Flashing Programs here, this section for Ringtones, Wallpaper and other media Files and Java/Symbian games and applications.
Old 07-19-2008, 01:17   #1
almostdone
Member: 689101
VERY EASY WAY TO SIGN UNSIGNED APPS!! Even my grandma can do it!!
Now this is what i call a fast signing procedure of unsigned applications. It doesnt take more than 5 seconds and 4 clicks on your computer to sign a unsigned application!
First, install 2 sis application on your phone.
Then open the RootSign.exe on your computer
Choose the unsigned application that you want to sign.
And its done!
In order to install “Unsigned” releases, you need to go through a one-time procedure. You will need to run the in the release included “SecMan.exe”. This program allows you to install our future “Unsigned” releases, without signing them every time.
For this, you will need to have TRK (included in this package) installed, and connected to your pc via USB connection.
s60_3_0_app_trk_2_8_6.sisx for SymbianOS9 devices WITHOUT FP1 s60_3_1_app_trk_2_8_6.sisx for SymbianOS9 devices WITH FP1
To get this app properly running, make sure you have installed the newest Nokia PC Suite, and your phone connected via “PC Suite” mode. On the phone, run the TRK app, in applications folder. When it asks for bluetooth connection, don’t turn it on, and change connection settings to USB. After you have done that, click “Next” and follow the instructions on screen.
When the installation is done, look in the Applications folder on your phone, and find SecMan. Open it, and click on “Install Root Certificate”.
After this is done, you will be able to install our future “Unsigned” releases like normal “Signed” applications.
Please keep in mind, if you format / upgrade your phones firmware, you’ll need to do this step again and after that manually install those apps from Application Manager.
NOTE: To install previous unsigned releases, use RootSiGN v1.0 (Included in the package) first to sign these releases with our root certificate. This can be used to sign and install any unsigned .sis(x) file
Thx to X.Factor for the info and BiNPDA for creating this app!
Download the needed file to sign your unsigned applications
The Following 177 Users Say Thank You to almostdone For This Useful Post:
..::AppleLinks::.., ..::Sniper01::., 011271, 18279, 3stanGsm, 4GSM, 68camaro, @matrix@, a.rasool, aaaa1234, aanshu55, abbas9, abduldon, abushams, adam621, alifahad, alphaonline, alternatif, amigoxix, ankitg2004, antoniovieira, aoc, APOCALYPTIST, apop82, Ash.Smith, ashwin kumar, asim_quazi, aslam rangrej, asrinu, avi_boom, azhar930, bacwolf, bakhtiarb, bangabashi, bhairav, bhateeja, biddut1979, bobaker, bobbyng, chand_gee, chetangajjar, chikku paul, chinny1982, chronicels, cmpnetman, collection_GSM, commandoo, damshipscrew, de Bell, delax2006, demonstag, desijan, devenleo, djstathis, DrJPB, drsas, Dr_Wolodya, dublinz, ductungoanh, fahed1, ficotdy, Filipebatista, ForestGriffin, Fortune_Teller, frooze_angel, gagac, garrypotter, ghoztup, gigs, gothca, Grim, gsm20g, gsm4sp, habeeb95, helal_786, hillagesa, huyentran, hva8, HZZORY4GSM, jafar_siva, jaigurudev, jameel1998, jerryy png, jewelzeem, jinu, JiPaNX, joni786, karim1980, KoksiSCG, kwnstadin, leirehj_16, limmobile, linekbp, london_n96, lucibln, luvshrestha, lynxnoon, makis19, Marc420, maritoM, martinzx13, masood1995, masterf*ck, max0066, max_sooo, mazo, md jawad, mizmatch, mohA™, morgoph, mrnazam, Mudassar_ali, murrystores, m_zidane1, n13lz, najim uddin, najm, nilam550, NokiaMobileCare, norah_carlina, pal707, parvezjk, ph4nt0m, pradeep pk, quickgsm, Rabatu, rahmathulla, raismehboob, SAB2000, sadiqali540, safkhan, sajidfine, sammyx, sanku, scamovic, send2ashish, senkron24, shadi0906, shahzad_786, shaikhaltaf_m, shatou, sheik_dgl, shohelht, sidhugurmeet, sirfnomi, smartprotect, smilesking, smnokia, Softway, sorryabout, soten, soulpilot, strainfactor, suganmural, surovi, surya910, svgasathik, sweet_raj7, syorz, tanthucdat, Tariq Khan, Teddybear, tee_beat, togex, tomcat_sniper, topcomgsm, Tring, Tuhinrt, udai, Vijay Arora, vinyl, vòuanquynh, wasif_naqvi, yajangelika, yogesh_2008, zulfi
Old 07-22-2008, 09:54   #2
dynamic-gsm
dynamic-gsm's Avatar
Member: 166385
Easy!! maybe ! to do this u need PC , cable , PC_Suite , driver..and it is old solution , i have already post a easy one without use PC , cable or anything and tested by many menbers .. ( http://forum.gsmhosting.com/vbb/showthread.php?t=553602 )
I forget , plz modertaor , can you say me wich the standards of sticky thread ? we must knwo , to do better for our forum
The Following 18 Users Say Thank You to dynamic-gsm For This Useful Post:
Old 07-22-2008, 17:06   #3
DrJPB
Member: 741877
Thanks to both of you, dynamic-gsm, you was was very lengthy, no hard feeling.
The Following 6 Users Say Thank You to DrJPB For This Useful Post:
Old 07-23-2008, 19:28   #4
aycan555
Member: 291160
Thanx you for your sharing, i tried to install the two sis file onto my 6220 Classic phone it gives me an error message says "component is built-in" what should i do now?
The Following 6 Users Say Thank You to aycan555 For This Useful Post:
Old 07-24-2008, 20:52   #5
sammyx
Member: 498507
Finally, got it to work on the n95 8gig. Many thanks
The Following 3 Users Say Thank You to sammyx For This Useful Post:
Old 07-25-2008, 19:09   #6
amrutbairy
amrutbairy's Avatar
Member: 153229
And its done!
Link to download the file is not working........pls upload the proper link
The Following 9 Users Say Thank You to amrutbairy For This Useful Post:
Old 07-25-2008, 19:35   #7
Formingus
Formingus's Avatar
Member: 322417
link working fine chk again
The Following 4 Users Say Thank You to Formingus For This Useful Post:
Old 07-26-2008, 09:58   #8
HeavyHMS
Member: 56216
same error on my E71
The Following 2 Users Say Thank You to HeavyHMS For This Useful Post:
Old 07-26-2008, 10:03   #9
simpleboy
Member: 810101
thanks mate.............
The Following 3 Users Say Thank You to simpleboy For This Useful Post:
Old 07-26-2008, 13:44   #10
amrutbairy
amrutbairy's Avatar
Member: 153229
Checked the link again still not working........
The Following 2 Users Say Thank You to amrutbairy For This Useful Post:
Old 07-29-2008, 21:37   #11
almostdone
Member: 689101
The link is working fine for me but anyway here is a mirror:
http://rs303.rapidshare.com/files/13...ymobile.se.rar
The Following 5 Users Say Thank You to almostdone For This Useful Post:
Old 07-30-2008, 09:14   #12
jk,zlh.i
Member: 823982
works perfect thanks
The Following 4 Users Say Thank You to jk,zlh.i For This Useful Post:
Old 07-30-2008, 11:11   #13
almostdone
Member: 689101
6220 Classic and E71 is both FP2 (Feature Pack 2) devices. This if for non-FP1 (devices before FP1) and FP1...
My only suggestion is to try use other hacks available. If still doesn't work you need to wait for hack to become available for FP2...
The Following 3 Users Say Thank You to almostdone For This Useful Post:
Old 07-30-2008, 12:55   #14
almostdone
Member: 689101
EDIT: E71 is FP1 but with some FP2 features. I guess it's the FP2 features that are causing the same error message as 6220c. These are the latest OS9.3 devices so you'll have to wait until new hack is available...
The Following 2 Users Say Thank You to almostdone For This Useful Post:
Old 08-01-2008, 21:58   #15
HeavyHMS
Member: 56216
the problem is s60_3_0_app_trk_2_8_6.sisx: this version is not compatibile with new phones, but the new protection is included in s60_3_0_app_trk_2_8_9.sisx (compatible with fp2 and "hibrid" E71)
If i install this version in a old phone Signsis was unable to recognize the device, but s60_3_0_app_trk_2_8_6.sisx works.
The Following 4 Users Say Thank You to HeavyHMS For This Useful Post:
Page generated in 0.08754 seconds with 7 queries
