![]() ![]() ![]() ![]() ![]() Join Date: Jan 2001
Member: 3041 Status: Offline Thanks: 0
One minute good signal, and one minute none ignal. What chagne ? Or what check ? Tthanx)))
![]() ![]() ![]() ![]() Join Date: May 2001
Member: 4544 Status: Offline Thanks: 0
Signal lost
Hallo Orbitel
I have same problem with alcatel 511 and its only one reason. Take antena conector(for extern antenna)and measure is it good or not ,you know how???? It must be conection between 2 contact at this conector and when you push this little pin inside conector,conection must be broken if not then clean this conector and check again.After you give back to the PCB and must working well. Second problem is antenna switch. Its all my friend Regards
Hi dedek,
yes really is this with antena connector. I try another antena and ) |
![]() ![]() ![]() ![]() ![]() Join Date: Jul 2002
Member: 13932 Status: Offline Thanks: 8
try to sold 2 contacts in antenna connector with tin wire..
