| Apple IPhone Iphone & Apple Products are here. |
Member: 826439 Status: Offline Thanks: 0
I've built my own 5 volt battery backup iPhone charger but when I plug the iPhone usb connector into it the iPhone does not even see it. It's as if it's not there. I suspect that the other 2 USB connector contacts provide some other information to the iPhone so that it will acknowledge a charging source. I'm using a simple 7805 voltage regulator supplied by a 9 volt battery. I'm getting the 5 volts and ground at the correct pins on the USB connector. Any idea what the iphone is looking for on the other 2 USB pins (or why my backup isn't working)?
![]() ![]() ![]() ![]() Join Date: Mar 2002
Location: Getting it to work is easy... making it do the things you want is another thing.
Member: 9824 Status: Offline Thanks: 0
Hello,
if you need a project to build your own Battery device like on the picture below, you might want to click here: http://www.ladyada.net/make/mintyboost/index.html ![]() If you don't want to build your own Battery Pack, you could buy a ready product that includes a Lithium Ion Battery, is approved to work with iPhones and comes with its own wall/USB charger. The price is less than 50 US$ (with free shipping in the USA). ![]() Description and Demonstration of the Battery Pack: http://www.youtube.com/watch?v=1zApPIe8ZLE Best regards, Ch@in |
Forget about the DO IT YOURSELF Battery solution...it won't work on an iPhone. I googled around and found out you would need an iPhone adaptor to make it work with a dumb Power supply (not Apple made).
No idea what this adaptor changes on the signal to make it work with an iPhone, but if someone will find out, please post a reply. Best Regards, Ch@in |
Moderator
![]() Join Date: Feb 2008
Member: 715227 Status: Offline Sonork: 100.1577103
iPhone seems to use more then 1 GND Connection,Normal Chargers have + and Ground,iPhone Cable has 2 GND Lines (and +,of course)
Thanks
Thanks to all for the input. I like DIY projects but it seems the iPhone is a bit of a challenge. I do like the DIY project mentioned (Minty Boost). It seems a little bit iffy for the iPhone as well based on the device compatibility list. Has anyone personally used this with an iPhone 3G?
#6 | |
I checked into eBay today and saw nice ready LIon 800 mAh packs for iPhones 2G/3G from Hong Kong for around 20 US $ (including shipping). I might order one. It's always good to have a spare Battery when you are away from home and I think it will come even cheaper than the DIY. Good luck, Ch@in |
