Go Back   GSM-Forum > Product Support Sections > No More Support/Temporarily Closed > KULANKENDI Server
Old 08-02-2008, 21:57   #1
jose79
Member: 828489
Problem With U700v
Hi:
I have a SGH-U700v, I ran the Kulankendi app, and applied the different unlock codes with no errors. Still the phone is turned on, it recognizes the network but it only allows emergency calls, signal bar is full.
Help!
Old 08-02-2008, 22:00   #2
jose79
Member: 828489
This is what I got from KK:
Looking for phone...
Phone detected. Mode: Qualcomm
Phone Model: SGH-U700
Phone IMEI: 35***2-**-180***-*
Firmware Version: U700AEGF1
MCC+MNC: 000 00
MSL Reading...
Reading data...
Connecting to server...
Server calculation result:
Unlock P.Freeze: 20751950
Unlock Network: #7465625*638*28513973#
Unlock Subset: #7465625*782*00000000#
Unlock SP: #7465625*77*00000000#
Unlock CP: #7465625*27*00000000#
Unlock SIM: #7465625*746*12369874#
Unlock Activa: #7465625*228*12369874#
For unlock Phone Freeze,insert other operator SimCard.Enter Code(it will not be visible) and accept with OK key
For unlock simlock:
1. If simcard is inserted then enter ONLY code(Network example: 28513973 ) and accept with OK key
2. If simcard is not inserted then enter full code(Network example: #7465625*638*28513973# )
All Done! - Time:12:00:06 AM
Old 08-03-2008, 01:10   #3
KulanKendi
Member: 384655
hmm dont understand a bit...
oka do this:
enter code: #7465625*638*28513973#
and tell me what phone say, if phone says: "Freezed" or similar then U need to insert any simcard(put pin if needed) and enter this code: 20751950 (this code will not be visible while entering so do not mistake) and accept by OK key, now phone will ask for NETWORK lock so enter only same code readed so: 28513973 and accept by OK key.
This what I wrote is explained while U select U700V model in KK software.
let me know
b.r
Originally Posted by jose79 View Post
Hi:
Help!
Old 08-03-2008, 13:50   #4
jose79
Member: 828489
Turned the phone on, it asked for a Sim Card. I entered the code #7465625*638*28513973#, the phone message was: "Network Lock: Deactivated". I inserted the Sim Card, got no message. It found the Sun Com network (GSM 1800MHz, owned by T-Mobile in Puerto Rico and southern states of the US) and it picked up the max signal strength. Tried to make a phone call, call did not go through. After about 1 min, the symbol of the phone crossed out appeared next to the edge GPRS icon at the top of the display and when I try making phone calls again I get the message emergency calls only. Should I try using a different updated firmware? Maybe from another country, it appears mine us from France U700AEGF1, Quicknote apparently my phone was already unlocked because I didn't have any "freezed" message and the phone recognizes my network.
Old 08-03-2008, 14:02   #5
jose79
Member: 828489
Sorry Network Frequency is 1900MHz, not 1800 Mhz.
Old 08-04-2008, 15:54   #6
KulanKendi
Member: 384655
so unlocking went ok, check in menu for band selection maybe there is problem
b.r.
Old 08-04-2008, 18:28   #7
jose79
Member: 828489
I have tries both settings (Automatic, GSM 1900) and problem persists. Do you think there may be a problem with the IMEI in the network?
Old 08-06-2008, 01:14   #8
jose79
Member: 828489
Any suggestions for this problem???
Old 08-06-2008, 12:14   #9
KulanKendi
Member: 384655
if IMEI problem then network should disconnect faster. It can be hardware problem or software too(broken radio settings). Hope some samsung experienced repairers will answer here.
b.r.
Page generated in 0.09851 seconds with 6 queries
