Go Back   GSM-Forum > GSM Mobile Brands -Software Area- > Chinese Models & Cloned Phones
Old 08-07-2008, 13:19   #1
GOODNESS
GOODNESS's Avatar
Member: 89584
n95 double sim 2x6 pins always on searching
i need rx and tx testpoint in pcb.i need to format the second cpu for the phone to work.i have formated the the first cpu and fullflash it,is still on searching mode always.i attached the pcd here.can anyone tell me the testpoint from the pcb points?
Old 08-07-2008, 14:57   #2
tkowsar
Moderator
tkowsar's Avatar
Member: 233205
Sonork: 100.1578108
sorry not found,
many many device have in market which can able to find out both cpu tx rx. you can use them.
also though you have no device plz try with this method, may you can find it. see pic-
Old 08-07-2008, 15:11   #3
GOODNESS
GOODNESS's Avatar
Member: 89584
i have infinity.i can only detect rx and tx for the first cpu,but cant get cpu2 rx and tx
Old 08-08-2008, 21:12   #4
Unknown®
Unknown®'s Avatar
Member: 440163
Sonork: 100.1576002
to find second cpu pins ,(also ı hope you have infinity pinfinder)just when you click search dont use power on button open your set you will see "POWER B" POİNT hold it with gnd and u will get second pinout for your set.
Old 08-09-2008, 23:44   #5
malikasim
malikasim's Avatar
Member: 269126
simple way to find manual pinouts just put a gnd at PCB and putt connector into the phone keep press the power button if phone is dead other just on the phone and find through a digital meter put meter gnd at pcb and start searching the pinout RX and TX have both the range of volts 2.71 to 2.84 its 100000000000000000000000000% tested alyways find through this method...................
Page generated in 0.08049 seconds with 7 queries
