Member: 836308 Status: Offline Thanks: 0
problem unlocking OPTION ICON 225 - GIO225 from T-Online, Germany
I am getting the following messages:
Phone detected. Phone Model: OPTION ICON 225 - GIO225 (DR) Firmware serie: GlobeTrotter HSDPA Modem Phone IMEI: 359741-01-136086-0 Serial number: DR2981239W Firmware Version: 2.4.6Hd (Date: Oct 04 2007, Time: 14:11:38) Simlock status: Enabled All Done! - Time:12:00:02 AM Looking for phone... Phone detected. Phone Model: OPTION ICON 225 - GIO225 (DR) Firmware serie: GlobeTrotter HSDPA Modem Phone IMEI: 359741-01-136086-0 Serial number: DR2981239W Firmware Version: 2.4.6Hd (Date: Oct 04 2007, Time: 14:11:38) Simlock status: Enabled Connecting to server... Phone detected. Switching to BootMode... Sending loader... Error: Sending Loader! Looking for phone... Phone detected. Phone Model: OPTION ICON 225 - GIO225 (DR) Firmware serie: GlobeTrotter HSDPA Modem Phone IMEI: 359741-01-136086-0 Serial number: DR2981239W Firmware Version: 2.4.6Hd (Date: Oct 04 2007, Time: 14:11:38) Simlock status: Enabled Connecting to server... Reading data... EFS not found! - Contact with author! What can I do? Thx |
Can I get an answer please?!?
Can I get an answer please? I've purchased credits because the model was specified. Why is it not working? Is this just a scam? Should I take action on this direction?
#3 | |
![]() ![]() ![]() Join Date: Nov 2006
Member: 384655 Status: Offline Thanks: 2
disable all huawei software please (or uninstall)
otherwise it block com ports and KK can't detect it in boot mode b.r. Quote:
still frustratingly not working
I’ve uninstalled the web’n’walk application. Installed the driver from your support, respectively the one from folder Option/Edna/NDIS , the only one that worked. It appears with an exclamation mark in Device Manager, GlobeTrotter HSDPA 7.2. In properties, “This device cannot start. (Code 10)”. Obviously, the program doesn’t work - Looking for phone...
Error: Modem port unavailable or busy! Please give me a detailed procedure – obviously there is something here that I should do and I don’t. I mention here that I have WinXP SP3, device is from T-online Germany, and when I plug it in an installation auto-starts. PS - when you say - install the drivers from our support page, can you please mention..what drivers? .
#5 | |
this modem have build in flash memory (like pendrive) so U have drivers there, problem is that after uninstall web’n’walk application it will uninstall drivers too
so best way is install it again, and system will find correct drivers. After close that application and other (if any). I had one client with 100% same problem and he claim he closed all application for modem but he didn't and had same error. If there is exclamation mark then is wrong driver.Not all cards have drivers with connectivity sw so I put to ftp what exists ![]() b.r. Quote:
#6 | |
Member: 861927 Status: Offline Thanks: 0
I just tryed to reinstall drivers (and before reboot) killed all runned applications - std-something.exe.
It was same trouble with writting bootloader. So looks like trouble not here - but at new firmware I think. Quote:
oka please give me 1-2 day max, I go today for modem and will fix it finally oki?
b.r. |
Member: 904696 Status: Offline Thanks: 0
hi you all, i´m new to this forum, i have purchased a t mobile web´n´walk stick, tu use in germany with T mobile
i would like to unlock it, to use with another provider, in Argentina. to use it with Movistar. what can i do to unlock it. thanks in advance |
