QUALCOMM Models (3G) SGH-Z105x, SGH-Z107x, Z110, Z130, Z140, Z300, Z320i, Z500, Z510, ZM60, ZV10, ZV30, ZX10. |
08-14-2008, 21:36 | #1 (permalink) |
Junior Member Join Date: Mar 2007
Member: 469515 Status: Offline Thanks Meter: 8 | Increase speaker volume for F480, U900... - It will bring up a menu. - Load Params. - Dump Params. - Call Config. - Press Back & it will bring up another longer menu. - Key in 3 to bring up SPK Config Menu. - Then key in 4 to bring up have-QTune (MP3) menu. - Key in 1 to bring up SPK MP3 Vol. Menu. - Key in 6 to change the max. Volume. - You can always load default values. - For F480 touch the input area and then input values, and then press ok. |
08-14-2008, 22:08 | #3 (permalink) |
Member: 469515 Status: Offline Thanks Meter: 8 | For F480 default max volume is -8.5 db. And for U900 3.0 db. For F480 I recommend 0.0 to 3.0, and for U900 not over 6.0. There is speaker rebuild all command so you can reset values to default. |
The Following User Says Thank You to nedooo For This Useful Post: |
12-01-2008, 02:43 | #12 (permalink) |
Junior Member Join Date: Nov 2008
Member: 913060 Status: Offline Sonork: laurence0220 Thanks Meter: 0 | - Type *#0002*28346#. - It will bring up a menu. - Load Params. - Dump Params. - Call Config. - Press Back & it will bring up another longer menu. - Key in 3 to bring up SPK Config Menu. - Then key in 4 to bring up have-QTune (MP3) menu. - Key in 1 to bring up SPK MP3 Vol. Menu. - Key in 6 to change the max. Volume. noob here!!! after this i what will i do? my phone is F480 it seems that the phone need to input 123=12.3 i dot get it please guide me to max the volume of my tocco |
12-27-2008, 18:48 | #13 (permalink) |
Junior Member Join Date: Dec 2008
Member: 933067 Status: Offline Thanks Meter: 0 | Central shortcut key does not reveal Menu during a call in F480 Hi, I hope to get some help here. I cant access my menu and other applications during a call. Say, if I want to access calender I cant access that during a call. The shortcut key only provides four shortcuts that is music, browser, messages, and Call. Menu button which is there in the idle mode is not seen during call. Is this a bug or non configurable feature? I also want to change the shortcurts shown by the shortcut key. Kindly help. Thanks in advance. |
12-31-2008, 23:14 | #15 (permalink) | |
Member: 936193 Status: Offline Sonork: BL2 1JD Thanks Meter: 0 | Quote:
Hope this helps | |
help with Increase speaker volume for t639 | joorony | QUALCOMM Models (3G) | 0 | 01-15-2009 21:59 |
Samsung E-490 How to increase speaker volume | rizwan65 | Samsung Flashers, Software, Firmware. | 0 | 07-19-2008 08:55 |
Increase speaker volume-please help | chuoixanh | x1x to x45/x50 | 6 | 08-24-2003 07:53 |
Increasing speaker and ringer volume??? | Abe | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 03-04-2002 09:29 |
Increasing speaker volume of a Nokia 3310 | mag | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 12-23-2001 04:52 |
