![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2006
Member: 249300 Status: Offline Sonork: 10101010
Hi sir
I have two samsung e250. that on sound is ok but no speaker and earpiece sound and always show memory card simple in display without memory card any solution to this problem thx Sharaz |
Member: 751785 Status: Offline Thanks: 0
U Change Software E250D Ver E250D_27_BDGI1
Sound ok And MMC hardware prb |
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2006
Member: 295886 Status: Offline Sonork: 100.1583369
first flash ur phone with E250D files
than write E250D epporrom both problem will soloved |
#4 | |
![]() ![]() ![]() ![]() ![]() Join Date: Feb 2008
Member: 705991 Status: Offline Thanks: 75
i have flashed the phone with both e250d files but still the same problem when i was flashed my phone with e250 files so both sound and memory card was working ok but incoming and outgoing problem i have write all type of eeprom but still the same. when i was flashed my mobile e250d files so incoming and outgoing ok but memory card show, i want to know what is the problem in it, i have tried all the flash files with e250d and e250 but still the same. have any other solution? |
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2006
Member: 222009 Status: Online Sonork: 100.1576751
flash it with E250D_27_JBGJ1.sfl and E250D_27_JBGJ1.sff
first check on erase full flash cheap eep/mcu and then flah with this file ur problem will be solved but u will get imei 000000000000000 no problem everythin will work fine and if u want to rebuild imei then u must write a good imei .. u may get here http://forum.gsmhosting.com/vbb/show...8&postcount=15 and then u should rebuild with original imei tested many times
#6 | |
i have solved many phones with this above method but this unit can't solved yet |
Member: 1000596 Status: Offline Thanks: 0
hey guys i still have the same problem at first i flashed the phone and also tried to change the flex cable but nothing worked..
#8 | |
![]() ![]() ![]() ![]() Join Date: Aug 2005
Member: 174830 Status: Offline Thanks: 42
