![]() ![]() ![]() ![]() Join Date: Jul 2007
Member: 548049 Status: Offline Thanks: 35
hi i have some probleam how to install se tools3 any idea pls give me video something picture pls send. help me pls.............
![]() ![]() ![]() ![]() Join Date: Jun 2006
Member: 288543 Status: Offline Thanks: 34
just make one folder on pc in c harddisk after extret the file in this folder after u on this folder and u see some folder u can on driversfolder and again on egate driversagain oextret egate-3.06xp2k drivers and after you conect box to pc thaen give him patch usb drivers and dont give him egate drivers patch this pc automaticle take after you can on press setool2g and unlocke any phone but see the satting how toset every phones
hello bro i install very well but dont know how to creat the probleam. u have demo samething pls send me
Member: 216690 Status: Offline Thanks: 19
what kind of problem you have |
check this out
- Step one: install Smart Card driver 1. Download Smart Card drivers 2. Extract the driver package in any available space on your system (for example, in a \downloads directory). This is a location for the driver software that you will identify when you configure the e-gate USB Smart Card to use the drivers. 3. Run the 'Axalto-egate-drivers-v3.0.6.0.msi' and follow-up the instruction. The installer will setup or upgrade the driver automatically. 4. Plug your SEtool2 Smart Card in USB port. - Step two: getting access to the SEtool2 support area 1. Go to www.setool.net 2. Download and extract archive 'supporter.rar' 3. Execute 'supporter.exe' - you should get this window 4. Press 'GO SUPPORT' - your default browser now should open SEtool2 support area - Step three: download and install SEtool2 software 1. Go to 'software files' directory on the support area, download latest SEtool2 distribution package 2. Extract package in a separate directory (for example, in a '\SEtool2' directory) 3. Important step for servicing CID49/50/51 SE phones: go to 'software files\original se tool2 rest files' directory on the support area, and download all 'rest' files (archives) 4. Extract all 'rest' archives in '%setool2%\rest' directory ('%setool2%' stands for directory created in step 2.) 5. You are ready to start SEtool2 software for the first time (execute 'setool2g.exe' in '%setool2%' directory). |
![]() ![]() ![]() ![]() Join Date: Jan 2007
Member: 433083 Status: Offline Thanks: 38
good work Thx for sharing....
br |
![]() ![]() ![]() ![]() ![]() Join Date: Jun 2008
Member: 789089 Status: Offline Thanks: 57
well for better working visit this link....http://www.setool.org/vtutorials.php
br Frenzy (like my suggestions..let me know by clicking thansk button)LOL |
| The Following User Says Thank You to Frenzy_2020 For This Useful Post: |
![]() ![]() Join Date: Dec 2007
Member: 645411 Status: Offline Thanks: 7
PHONE IS RED RETAIL PRODUCT having problem with ulocking z310 dis is de setiuation
FLASH CID detected:52 Speed:921600 OTP LOCKED:1 CID:51 PAF:1 IMEI:35905801136178 CERT:RED LDR:070212 1651 GENCXC1720441_R2A019_PNX5230_FLASHLOADER Flash ID check:2019 Flash props sent ok LDR:070503 1431 HANCXC1250610_R3A015_PNX5230_CSLOADER loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed BYPASS PACKAGE ABSENT FOR THAT FIRMWARE. "R1KC001_CXC1250790_VODAFONE_AL" Elapsed: 21 secs. |
find bypass package "R1KC001_CXC1250790_VODAFONE_AL" or flash the main in order to have bypass package so that you can unlock the phone
| The Following User Says Thank You to airchiew For This Useful Post: |
#10 | |
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Dec 2006
Member: 421117 Status: Offline Sonork: NO Need to mention
![]() anyway u tried to teach and that is good. |
| The Following User Says Thank You to Umair Rashid For This Useful Post: |
![]() ![]() Join Date: Dec 2008
Member: 921420 Status: Offline Thanks: 47
just get the setool2 v.914029(don't worry about having a setool3 box.i have the same box.it is the same).u need to get this version first before updating to new one.unpack it.install box from DRIVERS folder.open setool2g.exe .go support from there(from soft).get the latest version(915030 right now).unpack.open setool2g.exe and start killing phones
.it worked for me.if u search u will find links to both setool2 versions.if u don't or u'r just lasy pm me and i will give u both.hope to be of some help
00:57:25.453 Error: JAF dongle init failed
Changing mode...WARNING! Update your Pkey to increase life counter! Done! Detected P-KEY: 9001FE75 P-key nokia module version 01.02 Starting Card UPDATE... ............ 01:02:53.359 Error: JAF dongle init failed |
@arhin
move to jaf sub forum.it's setool section. |
