Member: 849244 Status: Offline Sonork: w980
Problem with Flashing W980i, configuration error!
hi,
i bought some credit for SE in KKclient, 'cause i have a w980i from O2 Germany, and i would flash it to chinese. i have choosen the file: 1, W980i_R3CA038_FS_APAC-ANZ_CID52.fsm 2, W980i_R3CA038_MAIN_CHINA_MD_CID52.min **the kk-clientis: 1.96 / language.ini 1.86 **the cda i wanna use is: 1209-5271 **the usb cable is DCU 65 (dont have 60) **i chose in the kk-klient: DB3150(A2), finalization--yes cda---1209-5271 i can see there infos after flashing: ******************************* Hold 'C' or '@'-(PDA) or '2'-(W88x) or '2+5'(W760) or '6'(W350) key and plug DCU60 USB cable. Phone Connected... Detected: DB3150: A2 Series Phone IMEI: 35535302-138903-0 Color: Red ; OTP CID: 52 EROM CID: 52 Phone Model: W980 Operator: WESTERN-EUROPE CDA: 1210-2866 / R9A Phone Firmware: R3CA033 MCC+MNC: 000-000 NCK: - Unlocked - 5 NSCK: - Unlocked - 5 SPCK: - Unlocked - 5 CCK: - Unlocked - 5 PCK: - Unlocked - 5 ESL: - Unlocked - 5 Phone Code: - Empty Phone Code lock state: - Unlocked EROM Version: 1200-4341 SEMCBOOT R6A016 Sending Loaders... Loading Main File... Loading FS File... Flashing Main... Main Flashed Successfully. - Time: 00:03:56 Flash certificate(s) verification process, please wait... Flash certificate(s) verification status: Accepted Flashing FS... FS Flashed Successfully. - Time: 00:06:42 Flash certificate(s) verification process, please wait... Flash certificate(s) verification status: Accepted Flashing process finalization, please wait... Connecting to server... >> No more credits. Communication Closed. ***************************** i tried several times but after boot it always tells me "configuration error, call for sevice". i dont know what i can do, help.................. ![]() ![]() ![]() ![]()
hi again....
i just realized where the problem can be.... at the first time, i forgot to choose "finalization", and the flashing was done. then i wanted to flash it again, with "finalization", but server tells me that i dont have credit any more... what can i do???? dont let me pay 8 euro again please..... thank u......help................ |
![]() ![]() ![]() ![]() ![]() Join Date: Feb 2007
Member: 449518 Status: Offline Thanks: 20
EDIT by KulanKendi
Sorry it's KK subforum, mixing solutions make users confused Last edited by KulanKendi; 09-01-2008 at 15:36. |
![]() ![]() ![]() ![]() Join Date: Jun 2006
Member: 302596 Status: Offline Thanks: 58
If you use cruiser you need to tick cotumize fs after flash... if you user setool just check the complate phone after flash... your problem will be solved
thanks for answering me !
but what is cotumize??? i was using kk client...... |
![]() ![]() ![]() Join Date: Nov 2006
Member: 384655 Status: Offline Thanks: 2
| The Following User Says Thank You to KulanKendi For This Useful Post: |
i dont know exactly where the problem is. after flashing my w980, i cant turn on it, it shows on the display always "configuration problem". i think it's because that i didnt choose the "finalization" on the control panel on KK.
althaugh the flashing is done (the only one credit is also gone...), the phone was not finished with "finalization". that is the problem, i think.... i guess, if i flash it again with kk, this error can be solved, but my problem is, i must pay 8 euro again....is there any solution for me? dont let me pay again.please..... thank u kulankendi........ |
#8 | |
Yes for correct flashing U need select FINALIZATION option.
U don't need to pay 8euro more U still have 2 more free operations(half-active account) :-) so select now ONLY FINALIZATON (do not load flash files) and click EXECUTE, it will do finalization only and now power on phone and tell result. b.r Quote:
it tells me still "no more" credits, like here:
Connecting to server... Checking Account Balance... >> No more credits. Communication Closed. and, i didnt find the bottom "execute", do u mean "flash phone"? it comes a message with "finalization without flashing selected" . is that correct??? |
#10 | |
yes sorry mistake, correct is "Flash phone"
![]() send me PM with login b.r. Quote:
hi kulankendi,
thank u so much!!!!!!! now the phone works,finally!!! but i still have a question: if i check the CDA of my w980, it shows: 1210-2866 R9A 1204-1255 R3CA033 Western-EURO but i think i flashed it with: 1, W980i_R3CA038_FS_APAC-ANZ_CID52.fsm 2, W980i_R3CA038_MAIN_CHINA_MD_CID52 why does it show always "western euro". if i use the "update service", the phone will be updated to german again? confused.... b.r. |
#12 | |
CDA is not changed while flashing, if U want to change it then U must select Change CDA and write desired CDA number(before flashing)
Yes now update service will back to German. So if U know correct CDA then flash phone again b.r. Quote:
i tried again this evening, and it works now
![]() ![]() ![]() now the w980 shows: 1209-5271 R11A 1204-1255 R3CA038 1E0W APAC-ANZ thank u so much, kulankendi!!! ![]() ![]() ![]() ![]()
