Member: 856441 Status: Offline Sonork: w980
Problem with Flashing W980i
1. i bought some credit for SE in KKclient, 'cause i have a w980i from Telekom, and i would flash it to chinese.
2.i have choosen the file: W980i_R3CA038_FS_APAC-ANZ_CID52.fsm W980i_R3CA038_MAIN_CHINA_MD_CID52.min 3.**the kk-clientis: 1.96 / language.ini 1.86 **the cda i wanna use is: 1209-5271 **the usb cable is DCU 65 (dont have 60) **i chose in the kk-klient: DB3150(A2), finalization--yes cda---1209-5271 4.but, i forgot to choose "finalization", and the flashing was done. it always "configuration error, call for sevice". 5. i got to sony ericsson website, to new sofware update 6. it is OK, but alway connect not Net. now, i have only one try in KK. und i want to take die Handy to Germany oder Chinese. Help mir!!! ![]() ![]() ![]() ![]() ![]()
#2 | |
![]() ![]() ![]() Join Date: Nov 2006
Member: 384655 Status: Offline Thanks: 2
so now go to A2 Tab again and mark FINALIZATION, do not load any files and click FLASH and connect phone, wait till finish and try now use phone. if not works then again flash phone with same CDA and this time select FINALIZATION
b.r. Quote:
thank you.
i go to A2 Tab again and mark FINALIZATION, do not load any files and click FLASH and connect phone, now, it is better. but i check mein Handy info. Hold 'C' or '@'-(PDA) or '2'-(W88x) or '2+5'(W760) or '6'(W350) key and plug DCU60 USB cable. Phone Connected... Detected: DB3150: A2 Series Phone IMEI: 35535302-xxxxxx-x Color: Red ; OTP CID: 52 EROM CID: 52 Phone Model: W980 Operator: APAC-ANZ CDA: 1209-5271 / R2A Phone Firmware: R3CA038 MCC+MNC: 000-000 NCK: - Unlocked - 5 NSCK: - Unlocked - 5 SPCK: - Unlocked - 5 CCK: - Unlocked - 5 PCK: - Unlocked - 5 ESL: - Unlocked - 5 Phone Code: - Empty Phone Code lock state: - Unlocked EROM Version: 1200-4341 SEMCBOOT R6A016 All Done! - Time:00:00:00 CDA is now APAC. nicht wrst europa. but meie Handy ist still in Germay. was is the Problem? |
Member: 849244 Status: Offline Sonork: w980
hello cjorange,
i think you are using "mixed english and german". it's "is"(not "ist"), "my"(not "meine"), "what"(not "was"). hehehe.dont be confused with "english+deutsch". i had the same problem, u need to flash the phone again, it doesnt work only with "finaliation".that means, do again"cda-change and finaliation" together!!! |
thank you very much.
my english is so poor. i try again. hope these time will succeed. |
haha....
A2 Tab :mark FINALIZATION, CDA change: cda---1209-5271 Phone Connected... Detected: DB3150: A2 Series Phone IMEI: 35535302-xxxxxx-x Color: Red ; OTP CID: 52 EROM CID: 52 Phone Model: W980 Operator: WESTERN-EUROPE CDA: 1209-5271 / R11A Phone Firmware: R3CA033 MCC+MNC: 000-000 NCK: - Unlocked - 5 NSCK: - Unlocked - 5 SPCK: - Unlocked - 5 CCK: - Unlocked - 5 PCK: - Unlocked - 5 ESL: - Unlocked - 5 Phone Code: - Empty Phone Code lock state: - Unlocked EROM Version: 1200-4341 SEMCBOOT R6A016 All Done! - Time:00:00:00 now es ist west europa, but cad ist 1209-5271 handy is still in germay. |
#7 | |
CDA change need phone flashing, it not work fast like in DB2020
Did Finalization fix "configuration error" ? br. Quote:
now what can i do?
erst ,1. DB2020(A1) mark Finailization /oder DB3150(A2) mark Finailization ---> Flash Phone dann, 2. DB3150(A2) mark Finailization , cda change ,load FS MA----> Flash Phone ?? |
please use brain some and read what KK show U:
Detected: DB3150: A2 Series it mean that U have A2 phone and U need to switch to A2 tab and there 1. mark Finalization 2. mark change CDA and write CDA 3. Load FS+Main 4. click Flash phone b.r. |
