Old 09-08-2008, 22:06   #1
deXer
Member: 558034
bluesoleil last final 6 version
This crack for 6.2.227.11 version If want uninstall BlueSoleil software
need rename BsTrace.dll file inhere to the %SystemRoot%\system32 folder and reboot
The Following 5 Users Say Thank You to deXer For This Useful Post:
Old 09-09-2008, 01:14   #2
AlexG
Member: 5243
Instructions
  1. Install this version http://rapidshare.com/files/13568618...r-32bit-OS.rar
  2. copy BlueSoleil_crack.exe to the install folder (which by default is C:\Program Files\IVT Corporation\BlueSoleil)
  3. run BlueSoleil_crack.exe
  4. Click patch
  5. Click ok
  6. Restart PC
All should be working well, just tested now
The Following 3 Users Say Thank You to AlexG For This Useful Post:
Old 09-09-2008, 14:48   #3
ali.baydur
ali.baydur's Avatar
Member: 687932
all %100 working ok.%100 tested
Old 09-09-2008, 16:12   #4
kteruya
Member: 457626
DeXer... tried to apply your crack with version 6.2.227.11 an it reports not using version 6.2.227.10. Crack is not applied.
Using your BSTrace.dll over the one in version 6.2.227.11 will result in Explorer.exe error.
Am I doing something wrong?
Thanks
Kenji
Old 09-09-2008, 16:35   #5
ppp1ppp2
Member: 579470
Thanks
Kenji
You are right!
I found the same problem!
Old 09-10-2008, 00:49   #6
AlexG
Member: 5243
Thats because its crack for 6.2.227.10 and NOT 6.2.227.11 as I said above.
Alex
Old 09-11-2008, 06:51   #7
lancechou
Member: 110004
Crack_BsTrace.rar working great with 6.2.227.11
just copy to system32,don't need to run BlueSoleil_crack.zip
Old 09-17-2008, 21:42   #8
kteruya
Member: 457626
In fact crack works great with version 6.2.227.10!!!
But BStrace.dll + 6.2.227.11 always make my explorer.exe crash. I'm using XP SP2.
Just want to upgrade, from version 6.2.227.10 to 6.2.227.11, but new "crack" doesn't seem to work for me
Old 11-04-2008, 20:47   #9
kteruya
Member: 457626
deXer,
Version 6.4.237.0 is out. Is there any possibility to make a new "fix"?
thanks
Old 11-19-2008, 10:56   #10
sinelatwork
Member: 293127
I just can't download the 6.2 version but only the 6.4... Any crack working for the latest version ?
[IMG] code is Off
Page generated in 0.08263 seconds with 7 queries
