09-15-2008, 12:36 | #1 (permalink) |
No Life Poster Join Date: Jul 2007 Location: Indonesia Age: 47
Member: 551188 Status: Offline Sonork: 100.1580118 Thanks Meter: 59 | Cannot Connect phone using RJ45 I try to connect with correct phone Rx Tx and Gnd using RJ45 cable 10 pinout like your attached pic but never connect with software. RJ45 cable 1..............10 Rx : 4 Tx : 6 Gnd: 7 The factory not include package of SpiderMan Box with 10 pin adapter. It is only 8 pin rj45 to rj45. Please advice me the correct pinout to connect with rj45 cable. Sincerely Yours, Nasagih |
09-15-2008, 16:21 | #3 (permalink) |
No Life Poster Join Date: Apr 2004 Location: MOON
Member: 60899 Status: Offline Thanks Meter: 792 | modified rj45 connecter inside spiderman box for common chinese cables: rx tx gnd with pin 2 3 and 8 working 100% |
The Following User Says Thank You to mrfixit For This Useful Post: |
09-19-2008, 13:57 | #5 (permalink) |
Member: 60899 Status: Offline Thanks Meter: 792 | remember: spiderman box pinout: RJ45 cable 1..............10 Rx : 4 Tx : 6 Gnd: 7 above is for 10 pin conector but 8 pin connector dont use pin 1 and 10 so rx pin 4 is rx pin3 at 8 pin connector and not mod needed here but tx 6 need to cut and rewired to tx pin3 at spiderman box which is pin 2 if u put 8 pin plug into box, also gnd7 need to cut since it would be pin6 at plug and make gnd connection in spiderman box for pin9 which is pin8 at 8-pin plug, then this little mod works for common china cables like infinity, vygis etc. will post picture a little later, for those ppl I sound confusing |
09-20-2008, 12:21 | #6 (permalink) | |
Member: 551188 Status: Offline Sonork: 100.1580118 Thanks Meter: 59 | Quote:
ok sir will wait for your pic....for your information I use 10 pin RJ45 cable... | |
09-23-2008, 05:40 | #10 (permalink) |
Member: 60899 Status: Offline Thanks Meter: 792 | same connector but different angle view, after this small modification yes I can use infinity cables, I edit previous pictures with some lables so its better to understand. but maybe better to use adapter like mt-box is using from 10pin to 8-pin external, so spiderman box stay original, its up to you and ur own risk. Last edited by mrfixit; 09-23-2008 at 05:45. |
09-23-2008, 08:53 | #11 (permalink) | |
Freak Poster Join Date: Apr 2008
Member: 739232 Status: Offline Thanks Meter: 41 | Quote:
thz | |
I can not connect phones via rj45 cable | HADRIAN0141 | VygisToolbox | 6 | 01-21-2010 09:13 |
cannot connect phone | ZIYAAD STRYKER | SMTi | 3 | 08-27-2009 02:21 |
6131 \6126 cannot connect phone is ok | rohit50 | HWK | 1 | 02-08-2009 05:14 |
How to connect phone using Samsung Rocker | silverlink | Rocker Dongle (By Legija) | 1 | 01-09-2009 08:40 |
