08-20-2006, 18:58 | #1 (permalink) |
No Life Poster Join Date: Sep 2001 Location: GSM-TOOL Age: 52
Member: 6328 Status: Offline Thanks Meter: 3,595 | INSTALLATION MANUAL FOR VygisToolbox and VPower box (NOT valid for old sentinel dongles) a - MOST IMPORTANT: DISCONNECT ANY BOX FROM YOUR PC !!! - Go to one of the automatic support areas: http://forum.gsmhosting.com/vbb/showthread.php?t=253789 Download Smartcarddongle drivers for Win98 or WinXP and install (run that exe file) on your PC. NOW Connect VygisToolbox (or VPower). It will ask also for driver for the USB part (communication). - Download this drivers from the support area and install them. Take care - the VygisToolboxes and Vpower boxes, using the SMALL BLACK USBox are needing on Win XP the special driver, also avaiable there. If they are installed properly --> then you will see in ''Device Manager'' in the USB section, the VygisUSB2RS232 port component. - Download the dongle ID reader from that site, and read the dongle ID - If you can read the dongle id ==> then your smartcarddongle drivers are installed properly SEND the Dongle ID to your reseller and he MUST send you the reg files for your order. NOBODY except your reseller can provide this for you DO NOT ASK ME FOR YOUR REG FILE !!! AFTER YOU RECEIVE THE REG FILES FROM YOUR RESELLER: b - Now go to one of the automatic support areas: http://forum.gsmhosting.com/vbb/showthread.php?t=253789 Download LG supporter software, for VygisToolbox (for VPower you have to use O2 reg file and O2 supporter software) from there and copy in a separate folder Copy LG reg file in same folder START Now the LG supporter software --> and you get acess to the LG support area. Download the LG softwares in different folders and copy a copy of the LG reg in each of this folders. c- If you have buyed extra activations or full pack, then you have more reg files like Alcatel (Full pack) , O2 (Extra payed) ..., then take from same automatic support areas, the corresponding supporter software (Ex: Alcatel supporter if you have alcatel reg)... and you get access at that support areas and download and install this softwares. d - Now your softwares should be installed, and the reg files copied in the correspondong folders ==> all is ready to run About the USB Box, Switches, What RJ45 connector to use and rest of infos --> please read here: http://forum.gsmhosting.com/vbb/show...1&postcount=23 Well, this should be complete and step by step INSTALLATION MANUAL. ALSO HERE HOW TO ACESS THE 2 AUTOMATIC AREAS DIRECTLY FROM SOFTWARE - CHECK ATACHEMENT regards, Gobi |
The Following 54 Users Say Thank You to Gobi For This Useful Post: |
Verry important for VygisToolbox and VPower users - DRIVERS FOR THE BLACK SMALL BOX | Gobi | VygisToolbox | 39 | 10-25-2010 16:07 |
Need cyclone box user manual for flashing and unlcoking | MUTUAL | Cyclonebox | 10 | 06-16-2009 10:37 |
FREE GIFT FOR ALL VygisToolbox and VPower users !!! | Gobi | VygisToolbox | 78 | 10-15-2008 23:15 |
INSTALLATION MANUAL FOR VygisToolbox and VPower box | Black_Daimond | VygisToolbox | 1 | 09-08-2006 07:14 |
Manual for VygisToolbox is ready | Gobi | VygisToolbox | 5 | 10-08-2004 20:10 |
