Member: 130995 Status: Offline Thanks: 5,394
Multilanguage user interface (MUI) for Infinity-Box Modules
Dear Friends,
Some time ago we have released Infinity-Box DongleManager with multilanguage support: http://forum.gsmhosting.com/vbb/showthread.php?t=620943 Now multilanguage user interface (MUI) for other Infinity-Box software modules released. Now you can use Infinity-Box software with your own language. Currently English and Russian languages is supported, more languages coming soon (f.e. Farsi translation is in progress etc.). How to install Infinity-Box multilanguage user interface (MUI): 1. download and install Infinity-Box Language module (v1.01 or higher) 2. download and install Infinity-Box Shell (v1.25 or higher) 3. run Shell, go to "Settings" page and select required language 4. Once you have selected new language it will be default language for all modules (you do not need to select language each time when you run modules) Infinity-Box modules should be updated to use multilanguage support. Currently the next modules is ready for new interface: 1. Shell v1.25 and higher 2. PinFinder v1.15 and higher 3. ChineseMiracle v2.68 and higher 4. MModule v2.38 and higher Other modules is on the way. Here is screenshots of translated modules: ![]() ![]() ![]() ![]() New languages will be added in some time. There is no any limitations, the only problem is correct text translation, so if you have an experience and you are ready to helps other users you can check messages for translation here: C:\Program Files\InfinityBox\Language How to make new translation: 1. go to C:\Program Files\InfinityBox\Language 2. copy English.ini to file with your language name (f.e. Deutsch.ini) 3. use any text editor (f.e. Notepad or Wordpad) and translate text [msg] section 4. run Shell, select your language and test results 5. Optional: if it will be any problems with some special characters you can try to modify "Charset" value in [common] section (list of charset samples is in file with English translation) We are waiting for translated files at InfinityBoxSupport@gmail.com |
| The Following 25 Users Say Thank You to InfinitySupport For This Useful Post: |
![]() ![]() ![]() ![]() Join Date: Jul 2006
Member: 306118 Status: Offline Thanks: 212
Thanks Infinity team.
good lock |
| The Following User Says Thank You to farshid-jan For This Useful Post: |
Member: 121938 Status: Offline Thanks: 68
Infinity team. you are the best team
![]() ![]() ![]() ![]() Join Date: Dec 2005
Member: 205679 Status: Offline Thanks: 19
I' m translate turkish language very happy turkish users..
![]() ![]() By Nehirelektronik adana.... |
| The Following User Says Thank You to volkangsm2 For This Useful Post: |
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2006
Member: 398557 Status: Offline Sonork: 100.1578489
Best box of the year,Best support of the year,
Infinity box always ahead Thanks to infinity team Br. Vijendra Saini. |
Member: 314847 Status: Offline Thanks: 6
thanx to infinity team for a great support.
![]() ![]() ![]() ![]() ![]() Join Date: May 2006
Member: 281857 Status: Offline Thanks: 234
thanx .......keep moving...
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2004
Member: 52828 Status: Offline Sonork: KHADIM100
great hardworking infinity team . thanks for update.
![]() ![]() ![]() ![]() ![]() Join Date: Oct 2005
Member: 194128 Status: Offline Thanks: 576
Infinity always on top.
BEST OF LUCK! yawarniazi |
![]() ![]() ![]() ![]() ![]() Join Date: Jan 2005
Member: 105817 Status: Online Thanks: 19
Good..........................
![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2005
Member: 161115 Status: Offline Sonork: No Optional
![]() ![]() ![]() ![]() ![]() Join Date: Sep 2005
Member: 178790 Status: Offline Thanks: 287
Here the Spanish language for next update...
and for all users LATINO AMERICANOS !! Traslated by .:: The_Dj ::. -Colombia ![]() saludos |
| The Following 5 Users Say Thank You to djafter For This Useful Post: |
Member: 198016 Status: Online Thanks: 207
Thanks Thanks to Infinity team
#14 | |
this is language withs bugs fixed !
| The Following 2 Users Say Thank You to djafter For This Useful Post: |
![]() ![]() ![]() ![]() ![]() Join Date: Oct 2004
Member: 85637 Status: Offline Sonork: 100.100.529
good work infinity team . thanks for update.
| The Following User Says Thank You to armany99 For This Useful Post: |
