GPS devices , Navigators & Maps Find here all threads related to Global Positioning Systems (GPS), Navigators, GPS receivers, Settings, Maps and GPS modes.. etc |
01-15-2009, 09:38 | #287 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: Denmark Age: 57
Member: 385577 Status: Offline Thanks Meter: 656 | Quote:
If you want rapidshare try to check here: http://xwarezzz.com/utilities/1873/g...ial-patch.html or here: http://www.passiondownload.com/forum..._full_dvd.html or here: http://www.freshwap.net/forums/appli...-2009-dvd.html Regards Mike | |
01-15-2009, 16:43 | #288 (permalink) |
Freak Poster Join Date: Jan 2009
Member: 944132 Status: Offline Thanks Meter: 45 | Garmin Japan RoadNavi 25000 v2 Map ID: 5041 Code: http://rapidshare.com/files/183304871/Jenas_Japan25K.part1.rar http://rapidshare.com/files/183329996/Jenas_Japan25K.part2.rar http://rapidshare.com/files/183420326/Jenas_Japan25K.part3.rar http://rapidshare.com/files/183438966/Jenas_Japan25K.part4.rar http://rapidshare.com/files/183279000/Jenas_Japan25K.part5.rar |
The Following User Says Thank You to jenas For This Useful Post: |
01-17-2009, 18:26 | #294 (permalink) |
Member: 385577 Status: Offline Thanks Meter: 656 | Let us all share our maps Requirements for maps to be included in the list: 1) All maps must be MAPSOURCE versions - not gmapsupp.img. 2) The map must be routable, and may not be prepared from a gmapsupp.img map. 3) New / Other maps to be included in the list must be in a better resolution than the existing maps. If you have a map, or have knowledge of a map that meets these requirements, please post the link here..... What is the advantage of using Mapsource? I think the MapSource program is pretty much a "must have". In addition to the ability to load maps, the MapSource software has a lot of other capabilities, for example: - Maybe you are lucky. Maybe you can have up till 6 maps on your phone at the same time eg. gmapbmap.img (Basemap), gmapprom.img (internal map, used when you have US or EU maps), gmapprom1.img (internal map, used when you have both US and EU maps), gmapsupp.img (Supplemental maps, will be overwritten when you add new maps), gmapsup2.img and gmapoem.img (For OEM Company). But with MapSource you can have as many as you want!!!!! You just merge more maps together so they will appear as one file (gmapsupp.img) on your device - See all the Cities, selected map details and POI's on your computer - Set up routes and find out distances. Helps you get an overall picture - Create and transfer waypoints to your device - Backup your waypoints from your device to a database (*.gdb) file on your computer. - Find the lat/long positions of waypoints. - Add description comments to your favorites/waypoints, like addresses and phone numbers. Feel free to download the maps you need..... If you find this post useful, please say thanks you..... ----------------------------------------------------------------------- How to: Installation of software on a phone (Symbian S60 3rd Edition): Install Garmin Mobile XT Free Basemap: http://www8.garmin.com/software/Garm...emap_4xxxx.exe Install Garmin Mobile XT Support Files: http://www8.garmin.com/software/Garm...iles_4xxxx.exe Install Garmin Mobile XT for Symbian S60 3rd Edition: http://www8.garmin.com/software/Garm...tion_50020.exe Execute GarminMobileXT.sis on your phone. It is located in the root of your phone or SD-card. Start the application. Select settings for text language, voice, unit and for Garmin Online. Exit the application. Open the file called GarminDevice.xml. It is located in the Garmin folder. Look for <Id>XXXXXXXXXX</Id> Use the keygenerator (http://forum.gsmhosting.com/vbb/show...04&postcount=4) to generate an unlock key for the application, and save the key in a file called SW.UNL (not SW.UNL.txt) using Notepad. The file should be saved in the Garmin folder. More info here: http://www.megaupload.com/?d=UF9MMFF3 (Thank you Fugglefeet) Installation of maps: Download version 6.13.7 of MapSource: http://www8.garmin.com/software/MapSource_6137.exe (Don't use the latest version - it is not compatible with all the maps). Follow the following trick to hack the setup file so that it can be used to install MapSource clean and fresh without any prior installation of MapSource. Unpack or extract the content of MapSource_6137.exe downloaded using WinRAR. From the extracted files, run MAIN.msi. Then, run Setup.exe. Note: The sequence to execute Main.msi and then Setup.exe is important to avoid “Previous MapSource not found!” error. Garmin MapSource now installed. Download the map you want from here. Install the map using the file called something with XXXXXX_ENU.msi - Not the Setup.exe - This will install the map only. Launch MapSource and unlock the map, use a key generator which you can find here: http://forum.gsmhosting.com/vbb/show...04&postcount=4 Enter your GPS's ID number and mapid in the key generator, and you have the unlock-code. In Mapsource, click Utilities > Manage Map Products. Select the Unlock Regions tab, and click Add. Enter your 25-character unlock code and then a comment, if desired. Click OK. For more info look in the user guide for Mapsource: http://www8.garmin.com/manuals/MapSo...UsersGuide.pdf Then you transfer the part of the map (e.g. Spain) you would like to your GPS. If you would like to have more maps, e.g. Garmin City Navigator Europe NT 2009 and Garmin City Navigator North America NT 2009 you can combine the maps and transfer them to you GPS. Try it..... ----------------------------------------------------------------------- Map list: AdriaROUTE 2.20 - Mapid: 708 Download SCG Route 1.90 - Mapid: 929 Download Mirror, torrent Slovakia Roads v6 - Mapid: 1315 Download R.O.AD.2008 v3.01 (Roads of Romania) - Mapid: 1189 Download, part 1 Download, part 2 Download, part 3 Download, part 4 Download, part 5 Mirror, torrent Garmin Navcity Turkey 2008.07 - Mapid: 848 Download Mirror, part 1 (Password: tom1807) Mirror, part 2 (Password: tom1807) Garmin Mapsource World Map 4.06 Download OFRM Bulgaria v4.70 - Mapid: 5028 Download NaviGuide Hungary 5.1 NT - Mapid: 709 Download CarteBlanche Ukraine 3.50 - Mapid: 575 Download Venezuela Venrut 4.1 - Free map Download Mirror Mapear V7.50-Mapas Electronicos Argentinos - Mapid: 900 Download Philippine Islands - Free map Download Laos/Vietnam - Free map Download Samoa - Free map Download Indonesia 0.66 - Free map Download Greece 8.11 - Free map Download Cyprus - Free map Download Peru 0.49 (20/12/08) - Free map Download Garmin City Navigator Europe NT 2009 - Mapid: 378 Download (Torrent) Garmin City Navigator North America NT 2009 - Mapid: 325 Download (Torrent) Garmin Chile Streets 2007 - Mapid: 724 Download (Torrent) Garmin City Navigator Australia NT 2009 - Mapid: 358 Download (Torrent) Garmin City Navigator Middle East NT 2008 - Mapid: 329 Download Mirror Garmin City Navigator Mexico NT 2008 - Mapid: 278 Download, part 1 Download, part 2 Download, part 3 Garmin Mexico GPS Atlas v3.1 - Mapid: 5080 Download, part 1 Download, part 2 Garmin Mexico GPS Atlas v4.2 - Mapid: 12080 (How do you unlock that?) Download Garmin City Navigator NT New Zealand 2009 - Mapid: 499 Download GARMAP Southern Africa Streetmaps, Topo & Rec, March 2008 Mirror (Torrent) GARMAP Indian Ocean Islands Streetmaps Version 1 Mauritius - Mapid: 1148 Download Mirror (Torrent) GARMAP East Africa Street Maps Version 1 - Mapid: 1095 Download Mirror (Torrent) GARMAP Nigeria Streetmaps, Topo & Rec Version 2 - Mapid: 807 Download Mirror (Torrent) GARMAP Southern Africa Streetmaps, March 2008 - Mapid: 1214 Download Mirror (Torrent) Roads of Russia with Routing 4.03 - Mapid: 1120 Download (Torrent) Mirror, part 1 Mirror, part 2 Mirror, part 3 Mirror, part 4 Mirror, part 5 Mirror, part 6 Moldova 20.12.2008 - Free map Download Garmin Polska GPMapa 2008.3 - Mapid: 1326 Download Garmin EU SpeedCams 2008 update 11 Download MapSource Taiwan City Navigator ver 8.51 English - Mapid: 287 Download Garmin Iceland GPS Kort v3.5 - Mapid: 830 Download (Torrent) Czech Republic (ATLAS TJEKKISKE v7 NT) - Mapid: 579 Download (Torrent) Map of Sri Lanka (Sri Lanka Route) - Free map Download (Torrent) Garmin Mapsource City Navigator Brazil NT v4 - Mapid: 334 Download, part 1 Download, part 2 Download, part 3 Download, part 4 TrackSource Brasil 5.12 - Free map Download Lithuania Topo 1.06 - Mapid: 857 Download (Torrent) GM-MySin Installer v2.30 (Malaysia and Singapore) - Mapid: 5088 Download GM-Borneo Installer v2.30 - Mapid: 5099 Download |
The Following 4 Users Say Thank You to mike2111 For This Useful Post: |
01-17-2009, 23:44 | #297 (permalink) |
Member: 944132 Status: Offline Thanks Meter: 45 | Garmin Greece Toponavigator Anavasi v3.90 routable Code: http://rapidshare.com/files/185134036/Jenas_Anavasi390.part1.rar http://rapidshare.com/files/185111213/Jenas_Anavasi390.part2.rar |
01-18-2009, 15:15 | #299 (permalink) |
Major Poster Join Date: Dec 2008 Location: West side of east Europe
Member: 921590 Status: Offline Thanks Meter: 3 | @jenas, I have downloaded Greece Anavasi v3.90 and i have tried to install it. I copied the unpacked map in the Garmin folder (mine is on E:\Garmin) and I ran the anavasi.reg and "destroied" my mapsource. I had to enter in regedit to make it work, becouse even if I reinstalled a new mapsource it didn't work. It had showed me a message like there is a problem with the "800" and to try to reinstall the mapsource. I've realised that there is a problem with the map, becouse the mapID is 800. Thanks and hope you can help me. Dacian |
LinkBacks (?)
LinkBack to this Thread: https://forum.gsmhosting.com/vbb/f491/garmin-xt-maps-mapsource-version-632595/ | ||||
Posted By | For | Type | Date | |
What is GARMIN XT V5 MIDDLE EAST? | This thread | Refback | 06-29-2013 08:06 |
malaysia map for garmin xt | carrotboy88 | GPS devices , Navigators & Maps | 1 | 01-19-2012 08:18 |
Garmin XT Canada Map | jati_grewal | GPS devices , Navigators & Maps | 2 | 07-18-2009 13:10 |
maps for garmin xt | billyprepo | GPS devices , Navigators & Maps | 1 | 03-11-2009 10:33 |
Need help with N95-2 & Garmin XT 4.10.60 maps | wizard4it | GPS devices , Navigators & Maps | 1 | 10-14-2008 17:45 |
Garmin XT Canada Maps 2009 | s3lekta | Nokia Multimedia | 0 | 09-21-2008 19:45 |
