Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included |
11-20-2008, 10:46 | #1 (permalink) |
Junior Member Join Date: Nov 2008 Location: Hong Kong
Member: 895533 Status: Offline Thanks Meter: 0 | i68+ engineer mode I'm able to access the i68+ engineer mode but i don't know how to use the functions listed in. Is there anyone can help to tell me the exact menu functions? Heard that tunning in the engineer mode can't solve kinda problem likes earpiece echo. |
11-20-2008, 11:58 | #2 (permalink) |
Insane Poster Join Date: Jun 2008
Member: 792296 Status: Offline Thanks Meter: 39 | If you want to fix the echo, go to: Audio - Normal Mode - side tone Set it to 0 (ZERO) Be VERY careful with other things in the engineer mode, you can brick your phone!!!! |
The Following User Says Thank You to ColonelZap For This Useful Post: |
11-21-2008, 08:20 | #4 (permalink) | |
Member: 792296 Status: Offline Thanks Meter: 39 | Quote:
Audio - Normal Mode - Microphone Under Volume 0, I set a value of 204, the stadard was 168, just a higher number than 168. | |
The Following 2 Users Say Thank You to ColonelZap For This Useful Post: |
11-21-2008, 11:45 | #5 (permalink) |
Junior Member Join Date: Nov 2008 Location: FRANCE
Member: 906160 Status: Offline Thanks Meter: 0 | Sciphone i68+ Hi, please my new i68+ cant connect with my computer (vista) its no recognize no driver install ?? How can i knowing which cpu it is ? I dont find it in my pc. Many thanks for your answer. |
11-22-2008, 22:42 | #6 (permalink) |
Member: 903360 Status: Offline Thanks Meter: 0 | Thanks Colonel zap, but if I by volume from 0 to 9 can not change the parameters and if I go in 16 volume setting and try to change the parameters gives me an error how can I do? Help me |
11-23-2008, 10:37 | #7 (permalink) |
Member: 792296 Status: Offline Thanks Meter: 39 | As far as I know you only need to change the FIRST setting in that menu, on the ciPhone you can change the value by pressing the up and down switch on the side of the phone. |
01-02-2009, 21:03 | #9 (permalink) | |
Junior Member Join Date: Jan 2009
Member: 937708 Status: Offline Thanks Meter: 0 | echo Quote:
I have an i68+ with echo, and I can't remove it. I go into engineer menu, audio, normal mode, side tone, and the value set is 80. I can't find the way to change/edit this parameter, and no other either. I mean, if I touch 'set', I go to the back menu, the same if I touch back. The side keys of the phone don't do anything, and not only with this parameter but also with all of them. I need help! | |
01-03-2009, 14:09 | #10 (permalink) |
Member: 792296 Status: Offline Thanks Meter: 39 | Hi there I've heard before that people can't change the settings in the engineer mode, so the MTK Longcheer tool ist probably the only way to change the value. Some people have a hard time connecting the phone properly as a com port with their PC, some have been able to do this via Bluetooth. If all this doesn't work, I found a solution that is supposed to work. ----- 1.enter the engineer mode => device => set UART => UART setting . 2.on TST-PS Config make it UART 2 , 115200 3.on PS config make it USB Port , 115200 4.on TST-L1 Config make it none. 5.press ok, the phone will shut down , start the phone , when you connect it to the computer it will be in com-port automatically. 6. if you want the previous setting "mass storage or picture or webcam" change the PS config to UART 1 and press ok restart your phone and enjoy ----- Unfortunately I can't test this since I don't own a i68+ phone :-( Good luck!!! :-) |
01-04-2009, 01:05 | #11 (permalink) |
Member: 937708 Status: Offline Thanks Meter: 0 | Thanks for your help. Unfortunately I am not familiar with the MTK longcheer that you mentioned. I have tried to get it but I just found a reference in a german website that I can't understand. I was able to get a MTK tool v1.31 and installed it, but I think it is only for updating the phone with any other .bin file. I wonder if you could tell me how to get the tool that you mean, and then how to find and change the parameter 'side tone' that actually is set to '80' and I should change to '0'. I really appreciated your help |
01-12-2009, 02:03 | #15 (permalink) |
Member: 945189 Status: Offline Thanks Meter: 0 | Failed so Far Hello, I have had the I68 for two days trying to read and apply all the post that was discussing this issue here. What i did is i went to engineering mode and i tried to change the Tone from 80 to 0 and i couldn't so i downloaded the MTK long cheer and there was no response by adjesting the tone to 0 as i always get failed in red all the time. please if anyone can help me i will be deeply appricate to him. Thanks, |
Thread Tools | |
Display Modes | |
SCIphone I68+ Engineer Code | cristianoufo | Chinese Models & Cloned Phones | 0 | 12-06-2008 23:01 |
Lg-w3000 Engineering Mode | key | LG | 1 | 08-12-2005 05:54 |
Engineering Mode | Rheda31 | LG | 8 | 08-19-2004 04:52 |
Kenwood and engineer mode | svukov21 | Various | 0 | 07-11-2002 01:05 |
Test/Engineering mode | ddna | Motorola Old Legacy (EMMI) | 5 | 08-13-2001 07:30 |
