BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs. |
12-02-2008, 13:54 | #1 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: Hong Kong | USA Age: 35
Member: 258172 Status: Offline Thanks Meter: 10,367 | No Software Update is required for your device ((Solution here)) 1. Make sure you have instle on your pc the blackberry flashfile which blackberry model you need to work , if that flash file downgrade or upgrade no matter , should be correct blackberry model flashfile 2. Instle Latest Blackberry Desktopmanager version 4.7.0.32 WITHOUT select Automatic Update service 3. go to C:\Program Files\Common Files\Research In Motion\Shared\Loader Files remove/delete other bb model os from there if you already instled , make sure only there have the blackberry os file which model you want to do update 4. Be sure the blackberry not live in cal mode , if the blackberry on cal mode you should be type start to out cal mode Remove battery from blackberry & connect without battery to pc then Windows XP: Start / Run... type > cmd You will see a black window similar to this. I have used UPPERCASE to highlight the typed commands. Quote:
After When you hit enter at the last command a forced will start application loder then update os your blackberry , when application loder come this massage like on pic > wait for device initialize , then insert battery on blackberry , dont touch/disconnect cable by the way can be solve this problem tested by me Wbr ::.::RAMJAN::.:: @TRUST GSM™ Last edited by ::.::RAMJAN::.::; 11-27-2009 at 10:24. Reason: info update | |
The Following 345 Users Say Thank You to ::.::RAMJAN::.:: For This Useful Post: |
12-02-2008, 14:36 | #2 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Wien,Austria
Member: 45985 Status: Offline Thanks Meter: 96 | I had EXACTLY the same problem last night and i solved it like that but i didnīt had to remove other models/sw ??? Is it really necessary to delete it? BR |
The Following 2 Users Say Thank You to gjurobrod For This Useful Post: |
12-02-2008, 15:56 | #3 (permalink) |
Freak Poster Join Date: Oct 2005 Location: mexico
Member: 194712 Status: Offline Sonork: 100.1580741 Thanks Meter: 212 | hi Quote: CD \ CD PROGRA~1 CD COMMON~1 CD RESEAR~1 CD APPLOA~1 LOADER /NOJVM copy and past this text sorry for my mistake where paste thist text i dont understand b.r aleon |
The Following User Says Thank You to aleon For This Useful Post: |
12-02-2008, 16:30 | #4 (permalink) |
Member: 258172 Status: Offline Thanks Meter: 10,367 | @aleon just look on black screen, not so hard !! Last edited by ::.::RAMJAN::.::; 12-11-2008 at 21:02. |
The Following 14 Users Say Thank You to ::.::RAMJAN::.:: For This Useful Post: |
12-02-2008, 17:47 | #7 (permalink) | ||
Freak Poster Join Date: Feb 2007 Location: Colombia
Member: 448639 Status: Offline Thanks Meter: 165 | Quote:
Last edited by ::.::RAMJAN::.::; 12-11-2008 at 21:01. Reason: link was dead so info past here | ||
The Following 9 Users Say Thank You to J3soft For This Useful Post: |
12-04-2008, 17:25 | #9 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | when i add firmware in *.xls *.ali format its show error my device 8100 N its show only batter logo |
The Following User Says Thank You to ..::Angel::.. For This Useful Post: |
12-06-2008, 18:09 | #11 (permalink) |
Freak Poster Join Date: Jun 2003 Location: tunisia - sousse Age: 45
Member: 32529 Status: Offline Thanks Meter: 23 | i have problem during update when he waiting to initialise phone the BB cannot conect when the phone is powered on .. he say "catastrophic assertion failure" |
12-07-2008, 02:22 | #12 (permalink) | |
Cheater -Don't Deal with him- Join Date: Nov 2002 Location: Tunisia Age: 45
Member: 18022 Status: Offline Sonork: 1574868 Thanks Meter: 192 | Quote:
br Last edited by ::.::RAMJAN::.::; 12-11-2008 at 20:53. Reason: Quote remove | |
12-07-2008, 11:55 | #14 (permalink) |
Registered User Join Date: Sep 2003 Location: Palestine Age: 50
Member: 39208 Status: Offline Thanks Meter: 152 | i did excatly as u mentioned, but this is my problem when i run loader /nojvm the welcome message appear then i press next i have to choose the connection usb-pin:2417A26b i press next then i got ( device application selection ) there is no update process at all!!!! pls help Last edited by ::.::RAMJAN::.::; 12-11-2008 at 20:50. Reason: Quote remove |
The Following User Says Thank You to Byte For This Useful Post: |
12-07-2008, 16:25 | #15 (permalink) |
No Life Poster Join Date: Jun 2004 Location: MACEDONIA
Member: 67805 Status: Offline Thanks Meter: 364 | @Byte I was had same problem and then I try on other pc and phone was software updatet directly with desktop menager without this cmd and battery out/in. So try another PC |
The Following User Says Thank You to MOBICOM For This Useful Post: |
Probleme:blackberry:no software update is required for your device | karim8 | BlackBerry (RIM) | 4 | 03-06-2009 00:34 |
Lowering the correct flash for your device | LuisinhoCell | Infinity-Box | 0 | 01-25-2009 15:13 |
New Installer for Update+unlock utility. No .net Framework is required anymore | .:Spitfire:. | Ultimate-Sam | 8 | 07-01-2008 12:30 |
motorola software update locked my motokrzr k1 | martindale024 | Motorola P2k | 0 | 05-01-2008 02:20 |
furious-gold for lg k800 update is required !!! | wardak | LG | 2 | 11-25-2006 01:30 |
